Color_Orange
Blackview OSCAL S60 5.7 inch 3+16GB Drop-proof Ruggedized 4G Cellphone
Sale price £98.00 Regular price £105.00
Note:
S60
Budget Rugged Phone King
  • IP68&IP69K&MIL-STD-810G
  • 5.7-inch
  • 3GB+16GB MediaTek A22
  • Underwater Mode
  • 5MP+8MP Camera
  • 4980mAh
  • Android 11 Doke OS 2.1
  • GPS+GLONASS+Beidou+Galileo
Rugged & Tough
Invincible from inside out
Constructed from durable TPU and reinforced polycarbonate with 10% Glass Fibers material and treated with various durability tests, S60, with a robust structure, can well protect itself from daily rough uses. Have peace of mind whether on construction sites or outdoors.
*Solid unibody to reduce risks of falling apart
  • *High-strength Panda glass for scratch and crack resistance
  • *Thickened jagged corners to buffer shocks and crashes
  • *Double-shot molding process for slip and drop resistance
IP68 & IP69K & MIL-STD-810G
Survive from Any Challenges
The solid build that cannot be compared by most delicate and fragile mainstream smartphones makes it exceptionally resistant to damage caused by falls, water immersion, shock and impact.
Waterproof
Waterproof up to 1.5m deep for 30mins
Oil & coffee splash resistant
Dustproof
Fully dustproof
Drop-proof
*Drop-proof up to 1.5m height
4980mAh Battery
Power Lasts Longer
Charge less and extend longer. The large 4980mAh battery with built-in smart battery management effectively avoids running out of juice in the middle of enjoyment even for heavy uses.
7hrs
Game
8hrs
HD video
11.5hrs
Web
24hrs
Calling
28hrs
Music
288hrs
*The battery data is tested by OSCAL Laboratory.
Everyday Companion You can Rely on
5.7" HD+ Display
Rugged to Resist, Clear to View
Make every frame clear and vivid on the large 5.7" HD+ display. On the exterior, it's covered with high-strength Panda glass to avoid daily screen scratches or breaks. Always get the pleasing and spellbinding visuals.
5.7" HD+ Display
5.7" Screen
720*1440 Resolution
77.6% Screen-to-body Ratio
Quad-core MediaTek Helio A22
Smooth & Responsive to Multitask
Powered by a quad-core CPU coupled with 3GB RAM and 16GB internal storage,
it's easy to execute your demands with enough efficiency and fluidity.
3GB
RAM
16GB
ROM
Up to 128GB
Expandable Storage
Underwater Mode
Capture the Beauty on Land or in Water
With the Underwater mode available, make awesome snaps for the splendid scenes or other wonderful life moments anywhere.
5MP Front Camera
8MP Rear Camera
Always Find Your Way
Coordinating 4 navigation satellite systems together, S60 is capable of providing more reliable and accurate positioning to help never lose the way especially in outdoor explorations.
  • GPS
  • Galileo
  • Glonass
  • Beidou
  • GPS
  • Galileo
  • Glonass
  • Beidou
Doke OS 2.1
Based on Android 11, Intuitive & Smooth
S60 combines the developed Doke OS 2.1 and Android 11 OS to boost interaction smoothness and efficiency.
  • Dual Artistic Themes
    Both are designed with exquisite wallpapers and app icons for aesthetics and intuitiveness.
  • System Manager
    Get better and smarter all-in-one control such as over the battery and app management.
  • Cold Room
    One click to put rogue apps in the Freezer and stop their stealthy background running.
  • Clone Phone
    Safely transfer all the data from old to new device even without Wi-Fi or mobile data.
  • Screenshot/Long Screenshot
    For important messages, make a screenshot or long screenshot and edit it easily.
  • Split View
    Support a multi-window view and help multitask effectively and productively.
Oasis Green
Flame Orange
Eclipse Black
