Blackview Oscal PowerMax 3600 Rugged Power Station For Home & Outdoor Backup
✔World's 1st Rugged Power Station
✔Expand from 3600Wh to 57600Wh
✔3600W Output | 14 Versatile Outlets
✔3600W Input | 80% in Just 0.96Hrs
✔LiFePO4 | BMS | TI chip | 5MS UPS
✔Smart APP | LED Light | Morse Code Signal
Note: This is a EU/US Warehouse Stock item, it can just ship to these countries w/ FREE SHIPPING for 5-7 Working Day: United States, Germany, Italy, France, Spain, Ireland, Netherlands, Austria, Belgium, Sweden, Portugal, Poland, Czechia, Hungary, Denmark, Romania, Estonia, Latvia, Lithuania, Luxembourg, Slovakia, Slovenia, Bulgaria.
Note: This page currently does not support purchases for Puerto Rico
Expand from 3.6- 57.6 kWh Capacity
World's First Rugged Power Station
for Both Home and Outdoor Backup
Introducing Blackview Oscal
PowerMax 3600 & BP3600
Tired of soaring electricity costs during peak hours? Concerned about possible increases in energy prices? Worried about power outages when utility power is unavailable? No matter where you live, Blackview Oscal is on a mission to free you from the clutches of the power grid.
Get True Grid-Independence
Indoor or Outdoor
How does Blackview Oscal PowerMax 3600 help
ease energy shortages and save electricity bills?
● Portable energy for your camping or glamping.
● Consistent power solutions in
professional creative work.
● Reliable home backup power during unexpected power outages.
First Attempt! From Rugged Phone
to Rugged Power Station
Discharge Temperature from -20℃ to 55°C
Up to 10°C Higher / Lower Temperature
Resistance than Peers
Best under Conditions from -10℃ to 45℃
Drawing upon years of adeptness in crafting rugged phones , Blackview, renowned as a leader in the rugged phone industry, is embarking on a pioneering venture by infusing the unbreakable capabilities of rugged phones into power stations.
Certified by UL and RoHS (recast), the PC+ABS material in PowerMax 3600 has successfully achieved the ideal 7:3 ratio through extensive testing.
Tested through a variety of
professional
assessments.
0.8M Vertically Drop-Proof Design
Forged to match the harsh terrain of your expeditions, the PowerMax 3600 is meticulously crafted to withstand vertical falls from heights of up to 0.8 meters, alleviating concerns of unintended drops from your grasp while detaching it from the car or stairs.
Three shock-absorbing rubber material foot pads, effectively mitigating impact force on tires upon landing.
Multiple drop tests for
proven
durability.
Bump Test:
Test for 32km (4km/h*8Hrs ) with 10kg load(44kg+10kg)
Treadmill Test:
Test for 32km (2km/h*16Hrs ) with no load
Splash-Proof & Dust-Proof Body
From lakesides in the dewy morning to dusty desert at dusk, you can take it anywhere without worries – it effortlessly shields against vertical water droplets and certain solid particles from entering the enclosure.
By minimizing the diameter of the heat dissipation holes, particles larger than 2.0mm are prevented from entering the interior of the device.
Not Just for Lighting,
Also for
Emergency Communication
In addition to 5 standard LED light modes, information can be sent through light signals by varying the brightness and flashing patterns of the lights, which is helpful at night, in inclement weather, or in low visibility situations to convey signals, especially distress calls.
Large and Versatile Output
57600Wh Max Battery
Up to 30
Days of Power Supply
Catering to your various energy needs from outdoor to indoor activities, Blackview Oscal PowerMax 3600 offers the flexibility to tailor your battery capacity with a 100% modular design, ranging from 3.6 kWh to 57.6 kWh with up to 15 Battery packs ( 3600 Wh/per pack).
3600W Rated Power,
Power 99% of
Appliances
Rest assured that whatever you plug into the PowerMax 3600 will operate at its optimal capacity with its 3600W pure sine wave output, capable of handling power surges from pro tools in off-grid life like power drills and cutting machines to home life essentials such as microwaves, refrigerators, and air conditioner. (Note: 3600W for EU standard. 3000W for US/JP standard.)
What a Concept
An Energy Storage Solution for the Whole Home
OSCAL PowerMax 3600 redefines home energy storage by offering a rugged solution tailored for the entire house. With its customizable energy ecosystem, user-centric design, and revolutionary technology, PowerMax 3600 stands at the forefront of innovation, setting a fresh standard in home energy storage.
Large in Any Power Yet Easy on Any Move
One is Enough to Multitask
with
14 Devices Simultaneously
With a high-quality 3600W rated pure sine wave AC inverter, 14 outlet sources of Blackview Oscal PowerMax 3600 can satisfy all your outlet needs to run your entire party, camping trip, or even your whole house in the event of an unexpected outage.
Note: EU standard:3600W Output/2200W Input(Max);
US/JP standard:3000W Output/1800W Input(Max)
Fast and Green Input
6x Faster!
Fuel Up to 80% in Only 0.96 Hrs,
Charge in Any Way You Like
Charge the device quickly from a wall outlet at home or replenish it on the go from your car. Are you seeking eco-friendly energy from solar, wind, or water sources? We have your back. Are you looking for even more options? Blackview Oscal PowerMax 3600 is also compatible with an array of energy systems, encompassing EV charging stations, gas generators, and lead-acid batteries.
Live a Sustainable Life with
Green and “Zero-cost” Energy.
Save Up to $1612.8/Year!
Charge Time:
Up to 6 Times
Faster Than Others
Safe and Reliable Battery
EV-grade LFP Batteries,
The
25-Year Promise of Safety!
Safety and durability stand as the cornerstone of Blackview Oscal's mission. With Blackview Oscal PowerMax 3600, we've harnessed cutting-edge LiFePO4 battery chemistry, ensuring an impressive 3500+ cycles* of nearly 25 years when used every other day.
Lifespan cycles: Up to 5 Times More Durable Than Others
Intelligent BMS,
Eightfold
Safety Protection
Empowered by the intelligent Battery Management System, any potential glitches, be it overheating, overload discharging, or over-voltage issues, can be promptly fixed.
Working as Usual in Cold or Hot Weather
Be it the exploration of Alaska's glaciers or the vast Sahara deserts, Blackview Oscal PowerMax 3600 remains unaffected by the most extreme temperatures from -20~55°C(-4~131°F).
Temperature Resistance: Up to 10°C Higher/Lower than Others
*The high-temperature warning will be triggered at 55°C. The high-temperature overload protection will be activated at 58°C. Note: Best under conditions from -10°C~45°C(14~113°F)
45℃ Constant Temperature Cooling System
5ms Fast Switch,
24/7
Uninterrupted Power Station
When the home power source fails, the Blackview Oscal PowerMax 3600 will swiftly switch to work as the backup battery in only 5ms , so you hardly notice the slight flickering of the lights, delivering constant power to protect your computer from data loss and maintaining the uninterrupted operation of your fish tank, refrigerator, CPAP, and other essentials.
*The device will warn in advance if the power is about to run out.
Switch Time: 50% Faster than Others
Easy and Smart Operation
On-Unit Control+Smart App Control,
All in the Palm of Your Hands
Use Bluetooth or WiFi to access the PowerMax 3600's smart app for remote settings to check the status and manage your power consumption. Also, the large buttons let you maintain complete control of the gadget, and the easy-to-read LCD screen makes it straightforward to access all the information at a glance.
Button response time:10% Faster Than Peers
Eco-friendly and Ear-friendly Usage
Take Action for Our Beloved Planet,
Embrace Low Carbon Living
Blackview Oscal is actively committed to environmental protection, evident in its use of ROSH-certified eco-friendly materials . Unlike gas generators, Blackview Oscal PowerMax 3600 keeps your lights on without noise and fuel pollution, making it friendly to use whether you're at home, setting up a tent, or taking a road trip.
Note: Noise level when fully loaded: 62 dB (1.5M distance).
Brand New PM100 &
PM200
Solar Panel
Charge the Blackview Oscal PowerMax 3600 to full in just 2.25 Hrs from the sun with 8* 200W or 16*100W portable solar panels (Sold separately) while away from the grid. The Integrated MPPT charge controller gets the most efficient solar charge with up to 23% solar conversion efficiency.
Blackview Oscal PM100/200 Solar Panel Dimension
What Makes Blackview Oscal PowerMax 3600 Stand Out?
All of the above specifications are for EU Standard.
For US
Standard and JP Standard, there are some differences compared to EU Standard:
The rated power is 3000W. The
AC input power is1800W (Max).
Risks & Challenges
We hold this project in high regard to make it ready on Indiegogo. Currently, we are fully immersed in mass production and expect to improve it constantly. If the product specifications change while the campaign is in progress, we will let you know as soon as possible in the page's "Updates" section.
While we exert the utmost effort to minimize any potential logistical delays during transportation, we kindly request your understanding regarding unforeseen circumstances beyond our control that may impact delivery schedules.
If you've any further questions or problems, please check the FAQ section or contact us at allen@oscal.hk
Why Choose Blackview Oscal?
Blackview, founded in 2013, is an innovation-driven tech company with extensive industry experience in rugged smart devices. As one of the leaders in the rugged smart devices sector, Blackview has been dedicated for a decade to the research and development of rugged smart devices, allowing users to embrace a rugged lifestyle with devices that can withstand drops from up to 60 meters, resist water at depths of 15 meters, capture photos underwater at depths of 8 meters, bear a load of up to 20 tons, or survive extreme temperatures ranging from -20°C to 80°C. Over the past decade, Blackview has been breaking many new grounds in the rugged smart device field with a slew of industry firsts: the first rugged phone with thermal imaging-BV9800 Pro, the first rugged phone with night vision-BV8800, the first rugged phone with 40M laser rangefinder and 100-lumen flashlight-BV9300. Not to mention the N6000, the first mini rugged phone, and the Active 8 Pro, the first rugged tablet. All of them are warmly welcomed and loved by people from over 80 countries worldwide.
Highly Praised by Users.
In recent years, with the surge in energy costs caused by wars and the growing demand for low-cost (solar, hydro, wind) energy solutions, Blackview & Oscal, driven by the determination to meet users' electricity needs, have successively launched the PowerMax 700 and PowerMax 300 in the portable power station market, which immediately became well-known as top sellers among users worldwide. Drawing from their experience in portable power stations and rugged smart devices, their R&D team recently undertook a pioneering effort to integrate rugged capabilities from rugged phones into power stations. As a result, the PowerMax3600, the first attempt at the rugged portable power station in the world was introduced.
Oscal After-Sales Service Center
What the Experts are Saying?
See Who's Talking About Us
