Oscal Pilot 1 6.67-Inch Stereo Loud Speaker & Dual-LED Flashlight 6+256GB MediaTek Helio G81 Octa-core Rugged 4G Phone
Hurry up, only 6 items left in stock.
✔Stereo Loud Speaker, 138dB 5W Max Output
✔Built-in 170LM Dual LED Flashlight
✔15000mAh Battery & 33W Fast Charging
✔Stylish Design, Inspired by Formula Racing
OSCAL PILOT 1 is built for explorers who need powerful sound, lighting, endurance and rugged reliability. Its 5W 138dB Smart-K speaker and dual LED torch support safety outdoors, while the 15000mAh battery with 33W fast charging keeps adventures moving. A 6.67-inch 90Hz display, Helio G81, 6GB RAM, 256GB ROM, 2TB expansion, 50MP main camera, 32MP selfie camera, IP68/IP69K and MIL-STD-810H durability make it ready for harsh journeys in any terrain.
| Model | OSCAL PILOT 1 |
| Color | Black, Orange |
| Dimension | 185.5*85*22mm |
| Weight | 540g |
| OS | DokeOS 4.0 Based on Android 14 |
| Main Display | 6.67-inch HD+, 720*1604 Resolution Corning® Gorilla® Glass 5 90Hz Smart Refresh Rate |
| CPU | Octa-core MediaTek Helio G81, 12nm, Up to 2.0GHz |
| RAM & ROM | 6GB RAM & 256GB ROM, LPDDR4x+EMMC5.1 |
| RAM Expansion | Up to 12GB |
| TF Expansion | Up to 2TB |
| Battery | 15000mAh, 33W Fast Charging |
| Front Camera | 32MP |
| Rear Camera | 50MP (Samsung® ISOCELL JN1) 2MP (Depth Camera) |
| Speaker | 5W R36 Smart-K BOX Speaker |
| Navigation | GPS+Beidou+Glonass+Galileo |
| Card Slot | Dual; 2* SIMs / 1* SIM +1* TF Card |
| Glove Mode | Support |
| NFC | Support |
| WiFi | 802.11 a/b/g/n/ac(2.4GHz/5.0GHz) |
| Wireless BT | BT5.3 |
| Network Connectivity | 2G Band: 850/900/1800/1900(B2/B3/B5/B8) 3G Band: Bl/B2/B4/B5/B8 4G Band: LTE_FDD: Bl/B2/B3/B4/B5/B7/B8/Bl2/Bl3/Bl7/B20/ Bl9/B28A/B28B/B66 LTE-TDD: B40/B41/B38 |
Who is the OSCAL PILOT 1 rugged phone designed for?
The OSCAL PILOT 1 is well-suited for construction workers, maintenance technicians, farmers, delivery personnel (such as food or parcel couriers), as well as camping and hiking enthusiasts. It is ideal for anyone who spends long periods working or engaging in activities outdoors and requires features like a high-capacity battery, a powerful speaker, and built-in lighting.
It helps you stay connected throughout a busy day, ensures clear audio even in open-air environments, and provides illumination after dark. Its rugged, durable construction allows it to withstand various harsh conditions. Consequently, it is suitable not only for outdoor professional tasks but also for everyday communication needs.
What is the OSCAL PILOT 1’s loudspeaker useful for in everyday use?
The OSCAL PILOT 1 is equipped with a 5W speaker, which can be used for listening to navigation prompts, making hands-free calls, playing music, or watching videos. Its high volume ensures that audio remains clear even when the phone is placed 3–5 meters away.
You can also share audio with others during breaks or listen to navigation instructions without needing headphones. It is recommended to adjust the volume based on your surroundings rather than keeping it at the maximum level at all times. Please note that sound clarity may be affected by ambient noise, the distance from the phone, and the quality of the audio source itself.
What can I use the OSCAL PILOT 1’s dual-LED flashlight for?
The dual-LED flashlight on the OSCAL PILOT 1 is useful for tasks such as locating items in the dark, inspecting equipment, setting up a campsite, or providing illumination during power outages. With a brightness rating of 170 lumens, it effectively turns your phone into a portable light source whenever you need it.
For close-up tasks, simply direct the light toward the area you wish to see, and adjust the phone’s position to minimize shadows. It is a convenient solution whenever you need immediate lighting but don’t have a dedicated flashlight on hand.
Does the OSCAL PILOT 1 have a 15,000mAh battery?
Yes. The OSCAL PILOT 1 is equipped with a 15,000mAh battery, providing ample power for calls, navigation, messaging, and entertainment. It is ideal for users who may be away from a charger for extended periods or who simply require greater flexibility.
Battery life depends on how the device is used. For instance, continuous use of navigation, gaming, the flashlight, or the loudspeaker at high volume will consume more power. Before heading out, it is advisable to assess the remaining battery level and your expected return time to determine whether you need to bring along additional charging equipment.
How long does it take to fully charge the OSCAL PILOT 1?
Using 33W fast charging, it takes approximately 193 minutes (3 hours and 13 minutes) to fully charge the OSCAL PILOT 1 rugged phone, while charging from 0% to 20% takes about 27 minutes.
Please use a compatible charger and cable to enable fast charging. Actual charging times may vary depending on factors such as temperature, battery condition, and whether the phone is in use while charging. If you need a full charge before heading out, please ensure you allow sufficient time.
What mobile networks does the OSCAL PILOT 1 support?
The OSCAL PILOT 1 4G rugged smartphone supports 4G LTE, 3G, and 2G networks. By using a SIM card from a mobile carrier with an appropriate service plan, you can make calls, send and receive text messages, and access the mobile internet.
Before purchasing, please check the device specifications to ensure the supported frequency bands are compatible with your carrier’s network. You may also want to confirm with your carrier that they support voice calls and mobile data services for this device. The actual availability of services depends on local network coverage, your specific service plan, and any requirements set by your carrier.
How does the OSCAL PILOT 1 perform when running everyday apps?
The OSCAL PILOT 1 rugged smartphone easily handles daily tasks such as messaging, web browsing, navigation, watching videos, and managing emails. Equipped with a MediaTek Helio G81 processor and 6GB of physical RAM, it is well-suited for routine activities.
For optimal daily use, it is recommended to keep only the necessary applications open and avoid running resource-intensive tasks in the background. The device may experience temporary slowdowns during large file downloads, app updates, or when running multiple applications simultaneously. Additionally, the performance of online applications will depend on your network connection.
How easy is it to read the OSCAL PILOT 1’s screen outdoors?
With a screen brightness of up to 700 nits, the OSCAL PILOT 1 ensures that text, maps, and other information remain clearly visible even outdoors. It also features automatic brightness adjustment, which adapts the screen’s brightness to changing light conditions as you move between indoor and outdoor environments.
In direct sunlight, readability can be more challenging—for instance, due to reflections on the screen surface. When viewing detailed content, you can try adjusting your viewing angle or shielding the screen from direct light. Additionally, increasing the font size can make it easier to read information or navigation details without the need for constant zooming.
Can I use the OSCAL PILOT 1’s touchscreen while wearing gloves?
Yes. The OSCAL PILOT 1 supports "Glove Mode," which increases touch sensitivity, allowing for smooth operation of the screen even when you are wearing gloves—perfect for checking messages, answering calls, or browsing information while working outdoors.
You must enable "Glove Mode" in the phone's settings before use. Performance may vary depending on the material and thickness of your gloves; it is recommended to test the screen by tapping and swiping with the gloves you typically use. If your gloves are very thick or have a heavy insulating layer, you might find it somewhat difficult to perform tasks like typing or tapping small buttons.
What protection does the OSCAL PILOT 1 offer for outdoor work?
The OSCAL PILOT 1 features IP68 and IP69K ingress protection ratings and complies with the MIL-STD-810H testing standard. It is designed to withstand dust, moisture, and impacts, making it capable of handling various environments encountered during outdoor work.
To ensure optimal protection, please make sure the SIM card tray is properly inserted. If the device sustains a severe impact, check the body for any visible damage. If the phone gets wet, ensure the charging port is completely dry before connecting a charging cable. Please note that protective seals and materials may wear down over time; therefore, even though this is a rugged, durable device, it should still be handled with care during daily use.
What can I photograph with the OSCAL PILOT 1’s 50MP main camera?
The 50MP main camera on the OSCAL PILOT 1 can be used to photograph landscapes, objects, documents, and everyday scenes. It is also useful for documenting work-related tasks, capturing fine details, or taking photos during outdoor activities.
For the best results, keep the lens clean, tap the subject on the screen to focus, and ensure the phone remains steady. When photographing labels or documents, get close enough to the target to ensure the text is clear and legible, and be careful not to cast shadows on the frame. Additionally, good lighting conditions will help capture sharp details.
What does the OSCAL PILOT 1’s 2MP depth camera do?
When capturing portrait-style images, the 2-megapixel depth camera helps the phone distinguish the subject from the background. By applying a background blur (bokeh) effect, the subject—whether a person or an object—stands out more prominently.
The depth camera is not used independently to take photos; Rather, it is activated when using "Portrait Mode." For the most natural-looking results, ensure there is some distance between the subject and the background, and make sure the lighting is even.
What photo-editing tools are available on the OSCAL PILOT 1?
The OSCAL PILOT 1 features a variety of photo editing tools, including "AI Magic Eraser," "Sky Replacement," "Portrait Blur," "Color Focus," "Photo Unblur," and "Portrait Lighting Effects." These tools allow you to remove unwanted elements from your images, replace the sky background, adjust the intensity of background blur, highlight specific colors, reduce blurriness, and enhance lighting effects on portraits.
Choose the appropriate tool based on the effect you wish to achieve. When editing, carefully preview the results—paying close attention to faces, text, and the edges of objects. It is also recommended to keep the original photo, so you can revert to it later or try different editing approaches.
How can I take selfies in low light with the OSCAL PILOT 1?
When taking selfies in dim lighting, you can use the "face fill light" feature on the front-facing camera to enhance illumination. The OSCAL PILOT 1 rugged smartphone integrates this feature with its 32MP front camera, providing an effective solution for situations where there is insufficient light on your face.
Before taking a photo, switch to the front camera and enable the fill light feature; keep the phone steady while shooting. If an external light source is available, facing toward it is recommended—increasing the ambient light will help improve the quality of your photos.
What can I customize with the OSCAL PILOT 1’s shortcut button?
The shortcut key on the OSCAL PILOT 1 rugged phone can be assigned to specific actions, allowing for quicker access to frequently used features. It supports seven different functions, which you can configure according to your daily usage habits.
Go to "Settings" on your phone, locate the shortcut key options, and select the action you wish to assign. Once configured, test the button to ensure it performs as expected. Please note that some functions may require the phone to be unlocked before they can be used.
