Oscal Pilot 5 6.67-inch 120Hz Display Stereo Loud Speaker & Camping Light 15000mAh Rugged 5G Smartphone
Hurry up, only 6 items left in stock.
✔Stereo Loud Speaker, 140dB 5W Max Output
✔Built-in 410LM 30m Long-Range Camping Light
✔6.67" 120Hz AI Smart Refresh Rate Display
✔5G 6nm UNISOC T8100 Octa-core
✔15000mAh Battery & 33W Fast Charging
✔Industry-Leading IP69K & IP68 Waterproof & Dustproof
The OSCAL PILOT 5 is built for users who need dependable mobile performance in demanding environments. It combines a 6.67-inch 120Hz HD+ display with UNISOC T8100 5G performance and a 15000mAh battery with 33W fast charging for work, travel, navigation, and outdoor use. Key field-ready features include field-ready camera support, a 140dB speaker and 410LM 30m camping light, and IP68 & IP69K rugged protection. Designed for job sites, remote trips, and everyday toughness, it gives users the confidence to stay connected, capture details, and keep going when regular phones are not enough.
| Model | OSCAL PILOT 5 |
| Color | Black,Yellow |
| Dimension | 188.6*89.7*25.3mm |
| Weight | 570g |
| OS | DokeOS 5.0 Based on Android 16 |
| Display | 6.67-inch HD+ IPS, 720*1604 Resolution 120Hz AI Smart Refresh Rate |
| CPU | Octa-core 5G UNISOC T8100, 6nm, Up to 2.2GHz |
| RAM & ROM | 8GB RAM & 256GB ROM, LPDDR4X+UFS2.2 |
| RAM Expansion | Up to 24GB |
| TF Expansion | Up to 2TB |
| Battery | 15000mAh, 33W Fast Charging |
| Front Camera | 13MP |
| Rear Camera | 16MP |
| Speaker | 5W Smart-K BOX Speaker |
| Card Slot | Dual; 2* SIMs / 1* SIM + 1* TF Card |
| NFC | Support |
| WiFi & Wireless BT | (IEEE802.11a/b/g/n/ac)(2.4GHz/5GHz); BT5.0 |
| Network Connectivity | 2G Band: B2/B3/B5/B83G Band: WCDMA: B1/B2/B5/B84G Band: TDD:B38/B40/B41FDD: B1/B2/B3/B4/B5/B7/B8/B12/B17/B19/B20/B26/ 28A/28B/B665G Band: N1/2/3/5/7/8/20/26/ 28/38/40/41/66/77/78 |
How do I turn on the OSCAL PILOT 5’s camping light?
The yellow shortcut button on the side of the OSCAL PILOT 5 rugged phone is designated for the camping light function, allowing you to activate the light quickly. You can not only toggle the light on and off via the control interface but also adjust the brightness based on your surroundings.
You can choose from three modes: "Lighting Mode" for everyday illumination, or "SOS Mode" and "Rapid Flash Mode" for signaling. Whether you are setting up camp or searching for gear at night, you can select the lighting mode best suited to the task at hand.
What can I use the OSCAL PILOT 5’s camping light for?
The PILOT 5's camping light assists with tasks such as pitching a tent, locating gear, or working in low-light conditions. With a maximum brightness of 410 lumens, it serves as a convenient light source, illuminating nearby work areas without the need for a separate flashlight.
During power outages, it can be used to locate supplies or navigate dark rooms; simply place the phone securely and aim the light at the area requiring illumination. For prolonged activities, using a dedicated light source is recommended so that the phone remains free for calls and text messages.
Will the OSCAL PILOT 5 work with my mobile carrier?
The OSCAL PILOT 5 supports 4G and 5G networks, but compatibility depends on your mobile carrier and location. Before ordering, compare the phone’s supported network bands with those used by your carrier. You should also confirm that your carrier supports this model for voice calls, mobile data, and VoLTE.
If your carrier offers an online compatibility checker, follow its instructions to check the device. Matching network bands is important, but your plan and the carrier’s device requirements can also affect the services available. If you plan to use the phone abroad, check network compatibility and roaming options for your destination as well.
Does the OSCAL PILOT 5 have 32GB of physical RAM?
No, the OSCAL PILOT 5 is equipped with 8GB of physical RAM and supports virtual memory expansion of up to 24GB, resulting in a total of 32GB of available memory. This 32GB figure represents a combination of the built-in physical RAM and the expanded memory; it does not consist entirely of physical RAM.
The memory expansion feature utilizes a portion of the phone's 256GB internal storage to provide additional operating memory for multitasking. It complements the built-in 8GB of physical RAM; while its performance differs slightly from that of physical RAM, the expansion size can be adjusted in the phone's settings to suit daily usage needs.
Who should choose the OSCAL PILOT 5 as their everyday rugged phone?
The OSCAL PILOT 5 is an excellent choice for construction workers, agricultural professionals, maintenance technicians, and outdoor enthusiasts such as campers and anglers. It features a massive 15,000mAh battery designed for extended outdoor use, ensuring long-lasting power for calls, navigation, and various work-related applications.
Its built-in camping light helps technicians illuminate work areas and provides convenient lighting for campers organizing gear at night. Additionally, its rugged design and built-in speaker make it well-equipped to handle unexpected situations across a variety of environments.
How long does the OSCAL PILOT 5 last when using maps, calls, and mobile data throughout the day?
The OSCAL PILOT 5 is equipped with a massive 15,000mAh battery, providing ample power for navigation, calls, and mobile data usage during busy workdays and outdoor excursions. Test data indicates the battery supports up to 33 hours of web browsing or 49 hours of talk time.
Actual battery life will vary depending on your usage habits—such as switching between maps, calls, and other apps. Keeping the navigation screen constantly on, using high screen brightness, or using the network in areas with weak signals will increase power consumption.
What comes in the box, and does my regional package include a charger?
The OSCAL PILOT 5 package includes the phone, a charging cable, a SIM ejector tool, a lanyard, and a user manual. Charging accessories vary by regional version: non-EU versions include a power adapter, while EU versions do not.
If you choose the EU version, you can use a compatible charger you already own or purchase one separately. To utilize the maximum 33W wired fast charging capability, the charger and cable must meet the phone's specific charging requirements. Please contact us before placing your order if you need assistance selecting an adapter or confirming package contents.
How bulky is the OSCAL PILOT 5, and what is the best way to carry it?
The OSCAL PILOT 5 weighs approximately 570g and measures 188.6 × 89.7 × 25.3 mm. It packs a large 15,000mAh battery, a built-in speaker, a camping light, and various practical features into a single device.
For extended work shifts or outdoor excursions, it is recommended to use a suitably sized waist pack or travel bag, or to place it in an easily accessible compartment. Carrying it in a trouser pocket might cause your pants to sag or slip down. If you intend to use it for vehicle navigation, choose a mount capable of supporting the PILOT 5's size and weight.
Is the OSCAL PILOT 5’s camera suitable for photographing documents, equipment, and everyday scenes?
The OSCAL PILOT 5 features a 16MP rear camera capable of capturing moments from daily life and work-related imagery. You can use it to photograph equipment, document work progress, or quickly snap pictures of documents and labels for future reference.
For the best results, shoot in well-lit environments, keep the lens clean, and hold the phone steady. When capturing text or fine details, tap the subject on the screen to focus and check the image before moving the phone. Keeping the camera parallel to the document also makes the text easier to read.
How does the OSCAL PILOT 5’s speaker perform for music, calls, and navigation directions?
The OSCAL PILOT 5 rugged phone features a built-in 5W speaker that supports music playback, hands-free calling, and voice navigation prompts. Whether you are listening during a break or sharing audio while camping, you can easily play sound without needing an external speaker.
You can also adjust the volume based on your surroundings and the type of audio. Please note that call clarity depends on network connectivity and the quality of the other party's microphone, while music playback quality depends on the recording itself. In noisy environments, it is recommended to choose a comfortable listening distance rather than simply relying on maximum volume.
What is the difference between the PILOT 5’s 120Hz refresh rate and HD+ resolution?
The PILOT 5 combines a 120Hz refresh rate with an HD+ resolution of 720 × 1604. The 120Hz refresh rate enhances the smoothness of scrolling, menu navigation, and animations that support this feature, whereas resolution refers to the number of pixels used to display text, photos, and other content.
These two specifications complement each other but serve different purposes. Selecting the 120Hz mode offers a smoother user experience, though the actual effect depends on the specific application and content; please note that not all games or videos run at 120 frames per second. Display settings can be adjusted to strike a balance between smoothness and battery life.
Can the OSCAL PILOT 5 serve as a backup phone and power source during a power outage?
Yes. The OSCAL PILOT 5 features a large 15,000mAh battery, making it an ideal emergency device to keep at home. You can use its camping light function for close-range illumination and power compatible devices via the reverse charging feature (up to 5W output; requires a suitable cable and necessary adapter).
During a power outage, it is recommended to prioritize essential functions. For example, using the light or charging other devices consumes power that could otherwise be used for calls and text messages. Additionally, reverse charging is intended for occasional emergency top-ups, and mobile communication relies on the continued operation of carrier networks.
Can I use offline maps on the OSCAL PILOT 5 when mobile coverage is unavailable?
Yes. You can use the OSCAL PILOT 5 with navigation apps that support offline map functionality. Before leaving an area with signal coverage, download the necessary map data and save your destination information. This allows the phone to use satellite positioning for location tracking without a mobile data connection, while the downloaded map data provides information about the surrounding area.
Offline capabilities vary by app, so please verify that your chosen app supports the necessary route planning and search functions. Real-time traffic updates and other online content require an internet connection. We recommend testing the offline features beforehand and ensuring the battery is sufficiently charged for extended navigation.
What is available when I buy the OSCAL PILOT 5 from the Blackview Official Store?
Purchasing the OSCAL PILOT 5 from the official Blackview store entitles you to a 12-month repair warranty covering eligible malfunctions. For assistance, please contact our customer service team with your order details and a description of the issue; please also provide photos or a short video to help us assess the problem.
Be sure to contact us before sending the phone back so we can confirm warranty eligibility and provide return instructions. For warranty-eligible repairs, you are responsible for the shipping costs to send the device to us, while we cover the cost of shipping the repaired phone back to you. Accidental damage, misuse, and other exclusions listed in the warranty policy are not covered by free repair services.
