OSCAL Pad 70 10.1-Inch Display Rockchip RK3566 Quad-core 4GB+64GB/128GB 6580mAh Android 12 WiFi Tablet
Out of stock
Pad 70
Efficient for on-the-go use.
10.1-inch
Dual Box Speakers with Smart PA
8MP Front+ 13MP Rear Cameras
Light520.5g
Thin9.9mm
Quad-core Rockchip RK3566
6580mAh Battery
DokeOS_P 3.0 Based on Android 12
Modern Design with Redefined Elegance
With rounded corners that complement its symmetrical frame precisely, Pad 70 is intended to be the epitome of elegance. It is so thin and light that you can carry it in hand or put it in a tote to take it anywhere easily.
Light520.5g
Thin9.9mm
Misty Blue
Meteorite Grey
Plunge Into the Large Vision
The 10.1-inch HD+ Display built into the Pad 70 presents the most accurate scenario with sharp details and vibrant color, making it perfect for reading, binge-watching, online conferences and classes.
Screen Size10.1-inch -
Resolution800*1280 -
Aspect Ratio16:10 -
Screen-to-body Ratio79% -
Brightness300 nit -
Panel TypeHD+ IPS
Release Your Enthusiasm with Great Performance
Your daily work and entertainment needs are adequately satisfied by the quad-core Rockchip RK3566, which offers improved performance whether you're watching movies, playing games, or multitasking.
Rockchip RK3566
Mali-G52
Quad-core Cortex-A55 1.8GHZ
LPDDR3 4GB+up to 3GB Expansion
EMMC
64GB/128GB+ up to 1TB Expansion
Raise The Bar On Your Fun Experience.
With the help of Memory Expansion Technology, Pad 70 offers up to 3GB of visible RAM, allowing you to expand the RAM to up to 7GB, assuring a fluid experience when using multiple apps at once.
Big Storage, Big Possibilities.
Unleash the full potential of your tablet- with our Pad 70 boasting up to 128GB of internal storage, and expandable memory of up to 1TB. Keep all your beloved photos, videos, and apps at your fingertips, without worrying about limited space.
Prolonged Fun by Durable Power.
With 6580mAh of mega power beneath the hood, Pad 70 will be your dependable travel companion for surfing or streaming, providing 6.2 hours of website browsing and 4.7 hours of movie playback.
553hrsStandby -
14.5hrsMusic -
6.2hrsWeb -
4.7hrsVideo -
3.4hrsGame
*Battery life will vary based on device settings, environment, and other conditions.
Rear Cameras
Picture-perfect Memories at Your Fingertips.
Get ready to explore new horizons of photography with Pad 70. Perfect for taking notes, scanning documents, and making video calls, which is an essential tool for today's multitaskers.
The Sound that Moves You.
Whether you're streaming music or watching a movie, the dual speakers with smart PA deliver crystal-clear sound with stunning clarity, transporting you to another world.
Upgraded Convenience & Smoothness
Try to swipe up, down, left, or right to find out all the magic tricks of DokeOS_P 3.0 .
Swipe down for the control panelDrop down the menu to take a screenshot or switch between Ring/Mute.
Press the volume button for the pop-up window on the rightQuick access to sound adjustment of media, alarms, and notifications.
Refined Animation
DokeOS_P 3.0 witnesses faster and smoother animation of screenshots and all types of floating windows. Always be in sync with you without latency.
Note-taking AppInstantly create a memo or a to-do list with words and pictures.
Pre-installed WPS Office SuiteWith WPS Office installed, Pad 70 makes it easier to work with Excel, Word, and PowerPoint on a regular basis for calculating data or editing presentations.
Split Screen ViewSplit the screen in half to allow for the simultaneous use of two programs, allowing you to chat with friends while watching movies or working together with two concurrent WPS tasks. -
Eye Protection with Dark Mode and Reading ModePad 70 is built with a reading mode and a multi-layered dark mode to relieve eye strain from extended study or work, meeting your needs for eye protection.
ModelPad 70
ColorMisty Blue, Meteorite Grey
Dimension246.5*163*9.9mm
Weight520.5g
OSDokeOS_P 3.0 Based on Android 12
Display10.1-inch, HD+ IPS, 800*1280, 79% Screen-to-body Ratio
CPUQuad-core Rockchip RK3566
ROM & RAM4GB LPDDR3, 64GB/128GB EMMC
RAM ExpansionUp to 3GB
Max TF Card Storage1TB
Battery Capacity6580mAh; 10W Charge
Camera8MP Front + 13MP Rear
WiFi & Bluetooth802.11a/b/g/n/ac/ax, BT5.0
Earphone Type3.5mm Jack
Speaker1217 2PCS BOX Speakers
Card Slot1 TF Card Slot
