OSCAL Pad 15 10.36-Inch 2K Display Unisoc Tiger T606 Octa-core 8GB+256GB 8280mAh Widevine L1 Support 4G Android Tablet
Out of stock
PAD 15
20% Faster Start-up
Design ↑ Convenience ↑ Smoothness ↑ Safety ↑
Enhanced Linux
Cinema-like Levels of Sound Effect
10.3''Screen Size -
IncellTP Type -
FHD+ IPSPanel Type -
225PPI -
82%Screen-to-body Ratio -
5:3Aspect Ratio -
1200*2000Resolution
Up to 20 Days of Standby
Just 1 Hour
20% Faster Start-up
Up to 15% Speedier App Launching
17% More Fluent Multitasking
Fun and Efficiency
/Composing
The power to keep you going all day! —Experience uncompromised productivity, limitless entertainment and productive working with Oscal Pad 15.
5hrsVideo -
5hrsGame -
6hrsWeb -
18hrsMusic -
35hrsCalling -
20daysStandby
PredecessorOscal Pad 15
7,680mAh Battery8,280mAh Battery+600mAh Battery
432 hrs Standby480 hrs Standby+48 hrs Standby
Just 1 Hour
Oscal Pad 15 incorporates a Unisoc T606 octa-core processor for your speedy downloads and uploads and stunning graphics and photos with lower power consumption, whilst letting you do more simultaneously. From pixel-intensive games to multitasking, Pad 15 will be your faithful partner and a compliant assistant.
276,644
From running resource-intensive applications to creating a seamless browsing experience, up to 16GB RAM empowers your navigation with smoothness and responsiveness. Effortlessly switch between apps, or immerse yourself in graphics-rich content. Kick-start the gateway to work, play, and everything in between with new-level efficiency and fluency.
Oscal Pad 15 is equipped with 256GB ROM for your all favorite photos, e-books, videos, movies, and apps. It will not let you experience the need to change your phone due to insufficient ROM.
of Music Storage/ 2,000 Games Storage
With Smart Pre-loading, Pad 15 anticipates the application you are about to launch and helps to preload apps before opening without any lag. As a result, the average speed of app launching gets improved by 15%.
Atomized Memory is an ultra-fine RAM optimization engine. It analyzes the ways apps utilize memory and compresses the RAM apps use in the smallest process unit to maximize RAM performance at all times for faster app start-up and 17% more fluent multitasking.
Pad 15 takes its versatility to the next-level by supporting PC mode which will allow you to work with Pad 15 as if on a PC. Open multiple app windows or websites simultaneously in a breeze while offering longer battery life and greater portability, which are not achievable with a traditional PC of almost the same size.
Split the screen into two and you can launch two apps at once, allowing you to share your instant feelings with friends while watching live streaming, and type down the key point during remote conferencing.
From fine lines to bold strokes, the stylus pen offers a natural and intuitive writing and drawing experience. In addition to navigating the screen, or annotating documents with ease, you can also sketch whimsical pictures and record unforeseen bursts of inspiration - magnificent masterpieces are created by this pen.
*The stylus pen is included.
The 16MP SK Hynix® Front Camera with Re-mosaic Algorithms and Quad-Bayer color array filter renders higher image quality. From taking selfies to having video chats, it backs you up with 16 million pixels to show your confidence.
The 13MP rear camera on Pad 15 renders multiple filters offering diverse artistic styles for photos of food, landscape and subjects. Turn on the rear camera, create incredible pictures with a bunch of tricks, tackle your problem with Smart Google Lens, and record everyday life with 1080p videos.
Landmarks while traveling
Pad 15's camera comes with Google Smart Lens, which includes scanning, recognition, and translation. Simply turn on the camera and scan what you want to know, the camera will respond quickly and solve your problem, bringing great convenience to your daily life.
Translate the text you see Identify unknown animals/plants Solving homework queries Explore mysterious buildings
Face Unlock With access granted, you can easily get into Pad 15 with only a glance at the front camera.Preferences
Windows
Notebook
Assistant
Desktop
Protection
Enhanced Linux
Bella Flor
Aurora
Assign different language settings to individual apps on Pad 15, allowing you to seamlessly switch between languages, just like in real life.
DokeOS_P 3.0 renders all the magic tricks for saving your time. You can group apps together, dismiss folders, or lock desktop layouts in a breeze.
DokeOS_P 3.0 witnesses faster and smoother animation of screenshots and all types of floating windows. Always be in sync with you without latency.
Swipe up, down, right, left, or try more gestures to navigate DokeOS_P 3.0, which facilitates your control over OSCAL Pad 15 with smart floating windows. Each is designed for further convenient interaction.
Hold for Smart Sidebar Swipe Right for Minus
One Screen Press the Volume Button for
Pop-up Window on the Right
Free disk space by removing junk files from rarely-used apps and cleaning up the cache on demand for maximum tablet performance optimization.
Optimize game performance with one-tap Clean-up RAM for smooth and lag-free gameplay.
Power saving mode helps to reduce battery drain by reducing unnecessary background processes and disabling some unnecessary features, which contributes to the maintenance of battery life.
APP Management enables your complete control over apps, including authorized permission management, auto-start management, auto-cleanup option for apps, RAM fast start-up boost option, and more.
You can easily drag certain applications into the cold room installed on the Pad 15 without unloading to prevent consuming more juice and traffic.
Sometimes it might be inappropriate to express your feelings on social media and that’s why you need a private Notebook to type down your imaginative thoughts and scribbles, and to make to-do lists and agendas for everyday plans.
Data Migration Assistant helps your transfer data from an old OSCAL or Android device to Pad 15. Simply follow the prompts with a few taps, then you can start transferring the data you need to OSCAL Pad 15 after the old device scans the QR code.
Permission
While DAC(Discretionary Access Control) allows a lot of freedom for users and has several considerable limitations, Pad 15 sets up a second layer for next-level security with MAC (Mandatory Access Control), and its high level of privacy has been demonstrated by its application to the NSA.
Security-Enhanced Linux is a security policy based on forced access to secure system resources, which was applied by OSCAL Pad 15, aiming to improve the security of Linux systems and minimize the number of resources accessible to service processes in the system.
effectively protect programs from rooting and attacks
performance,
not easily compromised
by vulnerabilities
control structure
with enhanced level of security
protection
Mitigates disasters caused by malicious attacks or malware
Provides a high level of security for information with high confidentiality and integrity requirements
With a 4-in-1 navigation system, pack with Pad 15 with ease to reach your destination.
Pad 15 supports dual 4G LTE, enabling 4G connectivity on two SIM cards, allowing you to switch between two 4G networks at will.
*The protective case is not included.
ModelOSCAL Pad 15
ColorSeafoam Green/Stellar Grey
Dimension246.5*156.3*7.6mm
Weight449g
Display10.36-inch, 1200*2000, FHD+ IPS
82% Screen-to-Body Ratio -
CPUOcta-core Unisoc T606
RAM & ROM8GB +256GB; LPDDR4X+UFS2.1
RAM ExpansionUp to 8GB
Max TF Card CapacityUp to 512GB
OSDokeOS_P 3.0 Based on Android 13
Front Camera16MP SK Hynix® Hi-1634Q
Rear Camera13MP
Battery Capacity8280mAh; 33W Fast Charge
Speaker1224 2PCS BOX Speakers
Wi-Fi802.11a/b/g/n/ac (2.4GHz/5GHz)
NavigationGPS+Glonass+Beidou+Galileo
SIM SlotDual; 2*SIM/ 1 SIM+ 1 TF card
ConnectivityGSM spec: 850/900/1800/1900
3G spec: WCCMA1/8
LTE spec: FDD:B1/3/7/8/20; TDD:B40
Oscal Pad 15 utilizes DokeOS_P 3.0 system based on Android 13 upgraded to provide more smooth, personalized and convenient user experience, achieving seamless interface switching and efficient memory allocation.
PAD 15
Just 1 Hour
20% Faster Start-up
Enhanced Linux
/Composing
Lens
Adhering to the DNA of the OSCAL Pad series with a minimalist and sleek design, Pad 15 is crafted with an exquisite back finish for a truly tactile comfort and classic look. With flat edges and round corners, Pad 15 sits comfortably in your palms.
whether streaming movies, playing games, or reading papers and novels.
10.3''Screen Size -
IncellTP Type -
225PPI -
5:3Aspect Ratio -
1200*2000Resolution
20% Faster Start-up
Fun and Efficiency
/Composing
Just 1 Hour
276,644
Oscal Pad 15
Class notes
Incredible Wonders
front camera.
Preferences Versatile
Desktop Refined Animation
Windows The Upgraded
Notebook DAC&MAC
Protection Cold Room
Assistant System Manager Security-
Enhanced Linux
Bella Flor
Aurora
Preferences Assign different language settings to individual apps on Pad 15, allowing
Permission While DAC(Discretionary Access Control) allows a lot of freedom for users and has several considerable limitations, Pad 15 sets up a second layer for next-level security with MAC (Mandatory Access Control), and its high level of privacy has been demonstrated by its application to the NSA.
performance,
by vulnerabilities
control structure
protection
malware
ModelOSCAL Pad 15
Weight449g
Rear Camera13MP
3G spec: WCCMA1/8
