Oscal HiBuds 6 IPX7 Waterproof Bluetooth 5.4 In-ear TWS Earbuds
Out of stock
OSCAL HiBuds 6
Born to Sound Beautiful,
Harmony in Your Ears
Refined Sleekness,
Timeless Style
Featuring a sleek and compact charging case with a built-in display that clearly shows the battery levels, HiBuds 6 excel not only for luxurious matte finish and a smooth, comfortable touch, but their superior audio quality along every note, every sound.
Pearl White
Obsidian Black
Unmatched Sound
Quality for Perfect
Listening
13mm Dynamic Driver
Deliver rich bass and crisp mids for a rich and immersive audio experience anytime, anywhere whether you’re listening to classical symphonies, rock anthems, or the latest pop hits.
Big Dynamic Driver (13mm or Larger)
Deeper and More Powerful Bass
Warm and Full-bodied Mids
Slightly Less Detailed Trebles
Small Dynamic Driver (6 or 8mm)
Less Bass-heavy
Lack the Fullness Provided by Larger Ones
Clearer and More Precise Trebles
Well-balanced and Zealous Sound Anytime, Anywhere
Listen to a Podcast While in the subway
Enjoy Clear and Polished Music During Your Commute
Conduct Clear Video Calls with Clients in the Office
Delve into Immersive Movies When Watching at Home
All-day Snug Fit, Endless Listening Pleasure
Ergonomically Comfy
In-ear Design
Ergonomic Comfort, Perfect Fit
Ergonomically designed after tens of thousands of simulations, HiBuds 6 provide a secure and comfortable fit for working out, commuting, or relaxing at home.
Three-sized Silicone Ear Tips
Every Ear, Perfect Fit
Each pair comes with small, medium, and large silicone ear tips, ensuring a perfect fit for all ear shapes and sizes. No more slipping or discomfort.
Lightweight for Your Ears
Lighter Build, Less Burden
Weighing just 4.15g each, HiBuds 6 are lightweight, minimizing ear fatigue and staying securely in place during physical activities.
4.15g
Per Earbud
35.5g
Charging Case
Slipped into the Pocket
Easily Thrown into the Briefcase
Tossed into the Mini Handbag
Uninterrupted Fun
with 400mAh
Durable Battery Life
400mAh Mega Battery Capacity
Larger Battery, Endless Fun
HiBuds 6 deliver up to 8 hours of playtime on a single charge, with the charging case extending total battery life to 30 hours. Enjoy music anytime, anywhere.
5hrs
Calling
8hrs
Music
30hrs
Standby (Connected to the Phone)
>150 hrs
Standby (with the charging case)
10-minute Charge,
0.8-hour Play
Uninterrupted Joy, Always
A quick 10-minute charge gives you 0.8 hours of playtime. Perfect for when you’re on the go, HiBuds 6 keep you connected and entertained with minimal charging time.
Powerful Charging Case
Up to 2.8 Times Recharge Capability
HiBuds 6 feature a fast-charging case that reaches full capacity in just 2.2 hours and can recharge the earbuds up to 2.8 times. Stay connected to your music and calls without frequent recharging.
40mAh
Earbuds
1.6hrs
40mAh
Charging Case
2.2hrs
IPX7 Waterproof Rating
Sweat or Rain? Constant Joy
With an IPX7 water-resistance rating, HiBuds 6 handle rain and sweat, ensuring you enjoy your music regardless of the weather or your workout.
Jogging in the Rain
Common Gym Workouts
Outdoor Hiking
Cycling in Moist Weather
Easy Control at
Your Fingertips for
Instant Joy
Click, Press, Control
Effortlessly adjust volume, answer calls, switch tracks, and more by single-tapping, double-tapping, triple-tapping, or long-pressing on the touch-sensitive area. No need to take out your phone—everything is at your fingertips.
Easy to Activate a
Voice Assistant
Press and Hold, Assistant Awake
Press and hold the right earbud for 2 seconds in standby or music mode to instantly summon your voice assistant. Stay connected and productive on the go.
Automatic Connection
Pair Once, Connect Forever
Once initially paired, HiBuds 6 will connect to your device automatically. The instant you open the charging case and put them on, you can immerse yourself in beautiful notes.
First-time Paring Guide
Time-consuming Method 1
Step 1:
Open the charging case.
Step 2:
Search for“HiBuds 6” from your device.
Step 3:
Click to connect.
Seamless Audio with
Wide Compatibility&
Reliable Connection
Compatibility with Android, iOS, HarmonyOS
Connect Universally, Listen Seamlessly
HiBuds 6 offer seamless performance across Android, iOS, and HarmonyOS. Switch effortlessly between your smartphone, tablet, and laptop without missing a beat.
Supported Operating System Android, iOS, and HarmonyOS
Supported Smart Devices Phones, Tablets, and Notebooks
Dual Device Connection
Two Devices, One Touch Switch
HiBuds 6 can connect to two phones simultaneously for seamless switching without interruption. From handling work on one device and personal calls on another to using different devices for music and calls, you can just stay connected and productive.
Latest BT 5.4
Faster, Stronger,
More Stable
With BT 5.4, HiBuds 6 ensure a stronger connection, reduced audio latency, and improved battery efficiency, delivering a flawless audio experience for music and calls.
BT 5.4
Lower Consumption When in Use ↓
Connections with Less Interference ↓
Greater Connection Security ↑
Better Quality Always ↑
BT 5.2
Relatively Higher Power Consumption ↑
More Audio Latency ↑
Reduced Signal Interference Resistance ↓
| Model | HiBuds 6 |
| Weight | 4.15g (per earbud), 35.5g (charging case) |
| Color | Pearl White, Obsidian Black |
| Driver Unit | 13mm Dynamic Driver |
| Frequency Response Range | 20Hz~20KHz |
| BT Version | 5.4 |
| Audio Codec | SBC, AAC |
| Battery Capacity | 40mAh (earbud),400mAh(charging case) |
| Charging Time | 1.6hrs (earbud), 2.2hrs (charging case) |
| Charging Port | Type-C |
| Connection Range | >10m |
| Water Resistance Rating | IPX7 |
