Blackview NEX60 Small PC Intel® Core™ 5 Processor 210H 16GB DDR4 512GB M.2 SSD WiFi 6 Windows 11 Pro Small Desktop PC
Sale price £523.00 Regular price £748.00
Mega Power, Packed Mini Work. Play. Create — All in One
6.37L Compact Size
20% Smaller
Intel® Core™ 5 Processor 210H 4.8GHz Max Turbo Frequency, 8 Cores 12 Threads,
12MB Intel® Smart Cache, 45W TDP
16GB Dual-Channel DDR4 &
Max 64GB Expansion
20% Smoother Multitasking
2.5" SSD Slot Support
Cinema-grade 4K UHD
Resolution
4X Clearer
15 Versatile Ports
6*USB-A 2.0
2*USB-A 3.0 (10Gbps)
1*Type-C
2*3.5mm Audio Jack
1*HDMI 2.0 (4K@60Hz)
1*VGA 1.4 (4K@60Hz)
1*RJ45 LAN(1000Mbps)
1*DC Jack
1*Power Button
97,029mm² Ultra-Large
Heat Dissipation Area
≤35℃ Daily Use Body
Temperature
Intel® UHD Graphics for
13th Gen Intel® Processors
512GB PCIe 4.0 M.2 SSD + Up to 4TB Total Expansion
100% Faster Transfer Speed
55 CFM Smart Temperature-Controlled Fan 3500 RPM High-Speed
≤30dB Daily Operation
Dual 4K Display Support 1*VGA 1.4 4K@60Hz
HDMI 2.0 4K@60Hz
Rocket-fast Wi-Fi 6 Up to 174% Faster Speed
Advanced
Wireless BT 5.2
Pre-installed Windows 11 Pro
Three Year Warranty
Built-in Power
Supply
Why Choose Blackview NEX60?
No.1 Uncompromising Flagship Performance
Blazing Speed, Stunning Visuals, Seamless Multitasking
No.2 Whisper-Quiet Cooling System
Keep Cool, Stay Fast — All Day Long
No.3 Seamless Connectivity & Instant Usability
Connect Everything, Work Anywhere—Right Out of the Box
Compact Size, Mighty Performance With its sleek and minimalist design, Blackview NEX60 seamlessly blends into any space. Don’t be fooled by its small size — it delivers impressive performance, making it the perfect combination of style and power.
20% Smaller
NEX60 Peers
6.37L 8L
No.1 Uncompromising Flagship Performance Blazing Speed, Stunning Visuals, Seamless Multitasking
Intel® Core™ 5 Processor 210H Unleash Power, Dominate Performance Equipped with the Intel Core 5 210H processor, NEX60 combines 8 cores, 12 threads, and a turbo frequency of up to 4.8GHz. Designed for smooth multitasking and immersive experiences, it’s perfect for everyday tasks, entertainment, and popular games.
8 Cores 12 Threads
45W TDP Higher Power, Smoother Performance
Intel 7 Advanced CPU Lithography
16GB Dual-Channel DDR4 & Max 64GB Expansion
Enhanced Speed, Seamless Multitasking NEX60 comes with 16GB dual-channel DDR4 memory, delivering faster data transfer and smoother multitasking for gaming, office work, and creative tasks like photo editing. With support for up to 64GB, it’s ready to handle complex projects and memory-intensive applications effortlessly.
Max 64GB Expansion 16GB SODIMM DDR4
Up to 3200 MT/s High-Speed Memory
20%
Faster App Launches & Smoother Multitasking
512GB PCIe 4.0 M.2 SSD + Up to 4TB Total Expansion Blazing Dual-Slot Speed &
Massive Capacity
100% Faster
PCIe 4.0 x4 SSD PCIe 3.0 x4 SSD
Up to 8GB/s Up to 4GB/s
*The comparison is based on theoretical data; actual experience may vary.
512GB M.2 Slots, Expandable up to 4TB
Massive Storage
Next-Gen PCIe 4.0 x4 Speed
Faster Boot-ups,
Smoother Multitasking,
Rapid File Access
2.5" SSD Slot Support Expand Freely, Store More Effortless storage expansion to keep your games, work files, and media organized. With support for drives up to 4TB, say goodbye to limitations and enjoy the freedom of extra space. *Optional feature, requires additional configuration.
Intel® UHD Graphics for 13th Gen Intel® Processors
Stunning Visuals,
Seamless Performance
From intense gaming to high-res video editing, enjoy ultra-smooth performance and breathtaking 4K visuals. Every frame, every detail—flawlessly delivered.
Cinema-grade 4K UHD Resolution
4X the Clarity, 4X the Impact Game, create, and stream in stunning 4K. With 4X the resolution of 1080P, every detail pops, making your visuals sharper,
brighter, and more immersive.
No.2 Whisper-Quiet Cooling System Keep Cool, Stay Fast — All Day Long
Class-leading Cooling System
Zero Heat, Zero Lag NEX 60 features a class-leading 97,029mm² pure aluminum extruded heatsink, a 55CFM high-output fan, and SGCC metal side panels. This powerful cooling system eliminates heat build-up and thermal throttling, delivering cool-to-the-touch, reliable performance for all-day work, streaming, and light gaming — no compromises.
≤35℃ Daily Use Body
Temperature
97,029mm² Ultra-Large Heat
Dissipation Area
Controlled Fan
55 CFM Powerful Airflow
3500 RPM High-Speed Precision Fan
No.3 Seamless Connectivity & Instant Usability Connect Everything, Work Anywhere—Right Out of the Box
All-Scenario Connectivity 15 Versatile Ports to Cover Every Use Case
1*Power Button
4*USB-A 2.0
1*3.5mm Audio Jack
1*Type-C
1*VGA 1.4 (4K@60Hz):
Cinematic 4K visuals
2*USB-A 2.0
1*RJ45 LAN (1000Mbps)
1*3.5mm Audio Jack
1*DC Jack
Screen
Keyboard
Mouse
Printer
Monitor
TV
Projector
Audio System
Headphones
4K Visuals,
Unmatched Clarity
Experience crisp 4K resolution via the HDMI port. Whether you’re multitasking, presenting, or streaming, NEX60 delivers stunning clarity to elevate your workflow and visual enjoyment.
Study and take notes simultaneously.
Deliver lessons while managing materials.
Game while chatting seamlessly.
Stream videos and browse freely.
Handle emails and analyze data efficiently.
Enjoy entertainment and multitask effortlessly.
Rocket-fast Wi-Fi 6
Blazing-Fast Connectivity,
Seamless Experience
Enjoy ultra-fast speeds, lower latency, and enhanced stability for streaming, gaming, and online meetings without interruptions.
Max Theoretical Speed
174% Faster
WiFi 6 9.6Gbps (~1200MB/s)
WiFi 5
3.5Gbps (~437MB/s)
Multi-Device Capacity
150% Higher Device Load Capacity
WiFi 6 20-30 stable devices
WiFi 5
8-12 stable devices
Avg Latency (Heavy Load)
60% Lower Latency
WiFi 6 20-40ms
WiFi 5
80-120ms
Advanced Wireless BT 5.2
Effortless Pairing,
Stable Connections
Connect multiple wireless devices seamlessly with faster pairing, extended range, and ultra-low power consumption.
Ready to Use,
With Windows 11 Pro pre-installed, NEX60 saves you time and effort. No need for additional setup — just unbox, power on, and start working or enjoying your favorite content immediately.
Blackview NEX60 Specifications
Model
Color
Dimension
Weight
CPU
Cache
Max Turbo Frequency
GPU
Display Support
RAM
SSD
OS
Wi-Fi
Wireless BT
LAN
I/O
NEX60
298x225x95mm, 6.37L
2641g
Intel® Core™ 5 Processor 210H, 8 Cores, 12 Threads; 45W TDP
12MB
4.8GHz
Dual; 4K (4096 x 2304 @ 60Hz)
16GB DDR4, Up to 3200 MT/s
Dual Channel, Up to 64GB Expansion
512GB M.2 2280/2242 (NVMe PCIe4.0×4 / SATA 3.0), Up to 4TB Expansion;
Up to 4TB 2.5" SSD (Optional)
Windows 11 Pro
Wi-Fi 6
5.2
Support 10/100/1000Mbps
6*USB-A 2.0
1*Type-C
2*3.5mm Audio Jack
1*HDMI 2.0 (Max 4096*2160@60Hz)
1*VGA 1.4 (Max 4096*2304@60Hz) / VGA
1*DC Jack (220V)
1*Power Button
