Blackview N1000 2.4-Inch Keyboard Detachable Battery Flashlight KaiOS 4G Mini Ruggedized Cellphone
Out of stock
✔2.4 Inch Display & 165g Ultra-light
✔Large Keyboards w/ Big Fonts
✔Built-in Bright Flashlight
✔3300mAh Detachable Battery
✔MIL-STD 810H & IP69 Rating
Note:
Rugged. Reliable. Ready.
Display
240*320
Resolution
Keyboards Easy to Operate
Card Expandable
MediaTek
MT6739 4*A53 Cores,
Up to 1.28 GHz
Camera 2MP
Battery
2* SIMs / 1* SIM + 1* TF Card
Dust-Resistance
Practical & Functional for Everyday Use
MIL-STD 810H & IP69 Level Rugged Resilience
Stay Updated with the Smart KaiOS
SIMPLE TO OPERATE
Industrial Style. Keypad
MIL-SPEC
810H
None the Errors. Intuitive Big Buttons
and Clear Menu
Ample Space. Ample Fun. Quad-core MediaTek MT6739
Expandable
Storage
All the Way Right. Bright Torch
Thickened corners for enhanced shock-resistance
Tightly-fit cap for enhanced water- and dust-resistance
Screws for enhanced shock- and drop-proofness
Any Situation MIL-STD 810H Certified
Always Keep Update. Always Keep in Touch.
Connectivity Support WiFi, 4G, GPS
Rest of the World Essential Apps
ModelBlackview N1000
ColorBlack
Dimension133.1*59.6*19.1mm
Weight165g
OSKaiOS
Main Display2.4-inch Display, 240*320 Resolution
CPUMediaTek MT6739,Quad-core, Up to 1.28 GHz
RAM & ROM1GB RAM & 4GB ROM, LPDDR3 & EMMC
TF Card ExpansionUp to 32GB
Battery3300mAh(detachable)
Rear Camera2 MP
Speaker1PCS; Smart-PA
Rugged RatingMIL-STD-810H &IP69
NavigationGPS
Card SlotThree; 2* SIMs / 1* SIM + 1* TF Card
Earphone type3.5mm jack
ChargingType-C/Desk charging Dock
WiFi802.11 a/b/g/n
Wireless BTV4.2
NetworkWiFi 4 (802.11 a/b/g/n)
Connectivity2G Band: B2/B3/B5/B8
3G Band: B1/B8
4G Band: FDD: B1/B3/B7/B8/B20/B19
TDD:B40
Display
240*320
Resolution
Card Expandable
MediaTek
MT6739 4*A53 Cores,
Up to 1.28 GHz
Dust-Resistance
MIL-SPEC
810H
Camera 2MP
and Clear Menu
Always Keep Update.
ColorBlack
Weight165g
OSKaiOS
Rear Camera2 MP
NavigationGPS
Card SlotThree; 2* SIMs + 1* TF Card
WiFi802.11 a/b/g/n
Wireless BTV4.2
3G Band: B1/B8
TDD:B40
Simple to Operate
Expandable
Storage
