Blackview MEGA 2 12-inch Unisoc T615 Octa-core 8GB/12GB+256GB 9000mAh Netflix HD Support Android Tablet PC
Hurry up, only 1 item left in stock.
✔12-inch FHD+ 2K Display
✔Netflix 1080P HD Support
✔9000mAh & 33W Fast Charge
✔Latest Android 15
The Blackview MEGA 2 is designed for users who want more screen space for learning, reading, streaming, and everyday productivity without stepping into the rugged lineup. Its expansive 12-inch 2K display gives you extra room for split-screen viewing, online classes, and entertainment, while the 9000mAh battery and 33W fast charging help keep up with daily use at home or on the go. With 4G connectivity and Android 15, MEGA 2 delivers a smooth, practical tablet experience for work, study, and downtime.
| Blackview MEGA 2 Specifications | |
| Model | Blackview MEGA 2 |
| Color | Celestial Grey; Ice Blue; Moss Green |
| Dimension | 281.7*177.2*8.0mm |
| Weight | 615g |
| Display | 12-inch, IPS, 1200*2000 Resolution, 84.9% Screen-to-body Ratio |
| CPU | Unisoc T615; octa-core |
| RAM & ROM | 8GB+256GB/Up to 16GB RAM Expansion 12GB+256GB/Up to 24GB RAM Expansion LPDDR4X+UFS2.2 |
| Max TF Card Capacity | Up to 2TB Expandable |
| OS | Android 15 |
| Card Slot | Dual; 1*SIM +1 TF/2*SIM |
| Cameras | 8MP Front+16MP Rear |
| Battery | 9000mAh Battery; 18W Fast Charging |
| Speaker | Dual-BOX speakers |
| Navigation | GPS+Glonass+Beidou+Galileo |
| Connectivity | Wi-Fi: 2.4/5GHz(802.11 a/b/g/n/ac ) 2G Band: B2/B3/B5/B8 3G Band: B1/B8 4G Band: FDD: B1/B3/B7/B8/B20/B19/B28A/B28B TDD: B40/B41 |
