Blackview GamiBook 6 16" AMD Ryzen™ CPU 16GB LPDDR5 RAM 512GB M.2 SSD Windows 11 Pro Gaming Laptop
Hurry up, only 2 items left in stock.
✔ 16" 1.65 kg Light & 17.4 mm Slim Premium Metal Body
✔16GB LPDDR5 Memory + Up to 64GB Expansion
✔512GB SSD + Up to 2TB TF Card Expansion
✔2-in-1 Fingerprint Power Button
✔Wi-Fi 6 & Wireless BT 5.2
✔Windows 11 Pro Pre-installed
Blackview GamiBook 6 combines powerful Ryzen 7 performance with a slim, premium metal body built for work, study, and everyday entertainment. Its 16-inch FHD IPS display, Radeon 680M graphics, 16GB LPDDR5 memory, and expandable SSD storage keep multitasking smooth and visuals sharp. With dual cooling, Wi-Fi 6, triple display support, and Windows 11 Pro, it’s ready wherever productivity takes you.
Easy to carry in a backpack.
Set up fast, pack away just as easily.
Light to bring, works anywhere.
Take it wherever you go at home.
More Stable When Typing
Premium Look & Finish
Less Stable on Desk
Low-End Plastic Appearance
Ryzen™ 7 7735HS
(GamiBook 6)
Zen 3+ (6nm), newer architecture for faster and more efficient performance
8C / 16T, stronger multitasking and heavy workload handling
Up to 4.75GHz, delivers faster responsiveness and smoother performance
35W high-performance design for sustained speed and stability
Zen 2 (7nm), older generation with lower efficiency
6C / 12T,
suitable for basic daily use
Up to ~4.0GHz,
limited peak performance
15W low-power design focused on efficiency
With hardware-accelerated decoding for AV1, HEVC, and VP9, 4K@60fps streaming stays fluid and highly efficient with minimal CPU usage.
(GamiBook 6)
Architecture
RDNA 2 (new gen)
12 CUs, ~50% more compute units
~2.3×–2.8× higher GPU performance, playable 1080p gaming in esports and light AAA titles
Higher efficiency, ~2× better performance per watt
More responsive, smoother multi-window experience under heavy load
Better 4K playback with improved codec support and smoother decoding
Vega 8
(Peers)
Vega (older gen)
8 CUs
Only suitable for light gaming at 720p–1080p low settings
Lower efficiency
Basic responsiveness
Limited 4K playback only
DOTA 2
CS:2
Minecraft
Genshin Impact
Fortnite
GTA V
on GamiBook 6
Microsoft Word
Microsoft Excel
Microsoft PowerPoint
Efficiency on GamiBook 6
Adobe Photoshop
Adobe Illustrator
Canva
GamiBook 6
Documents, spreadsheets, browser and meetings running without lag.
20+ tabs stay responsive.
Video playback, chat and downloads running at the same time without interruption.
Handles Photoshop and editing tools with stable performance.
(Idle)
(Full Load)
Reduced distraction during online meetings.
Helps maintain concentration over long hours.
More suitable for quiet environments.
Designed for less disturbance during late hours.
Designed for demanding tasks and gaming. Delivers stronger CPU and GPU performance for smoother and more stable operation.
For everyday use like browsing, work, and study. Keeps performance steady while managing power and heat.
Ideal for light tasks like web browsing and reading documents. Reduces power consumption to help battery last longer.
Watch videos with a wider, more cinematic perspective.
Work more efficiently with expanded vertical workspace.
Enjoy smooth casual gaming in your downtime.
Comfortable viewing for long reading and browsing sessions.
The 16:10 aspect ratio on GamiBook 6 creates a more expansive workspace, delivering 11% more vertical screen area than standard 16:9. The extended view enhances visual comfort in browsing, creative work, and more. More in view at once, less scrolling, smoother flow.
Zero Worry Powered by a 57Wh battery, it delivers up to 4.5 hours of office work on a single charge, enabling browsing, editing and gaming during daily use — without frequently hunting for outlets.
Convenience and Safety 65W fast charging boosts charging efficiency and reduces charging time, helping improve productivity with fewer interruptions during work, creation, or entertainment, with a full charge from 0 to 100% in around 3 hours.
Fully Immersed Dual BOX stereo speakers deliver a wider, more immersive soundstage through enhanced speaker separation and optimized acoustic tuning. Sound is fuller, richer, and more dynamic, with clearer vocals, better balance, and improved spatial presence that puts you at the center of every experience.
1080p
HD Front Camera
Dual DMIC Noise Reduction
Clear Video & Voice Calls
Always Clear The 2MP HD front camera delivers sharp 1080p video for crisp video calls, while the noise-reduction microphones reduce background noise to keep the voice clear. Ideal for online meetings, learning, and communication.
Unlock Instantly.
Stay Secure. Start your GamiBook 6 with a simple press, and unlock it quickly with your fingerprint. No password needed, ensuring secure and convenient access to your data.
Fingerprint
Sensor Diameter
Faster, More
Accurate Unlocking
Adjustable backlighting for clear visibility in low light, ensuring comfortable typing day or night.
1.3mm key travel for a responsive typing feel, while the numeric keypad improves efficiency for data entry.
Extra-large touch area (130 × 90 mm) with smooth multi-touch gestures for effortless scrolling, zooming, and navigation.
Earphone
Phone
Tablet
Power Bank
Mouse
USB-C Fan
HDMI 1.4 (Max 4096 × 2160)
USB Type-C (Full-featured) (Max 4K @60Hz)
Built-in 16-inch FHD IPS Display
Connected Experience
Fast, reliable connectivity for everyday use.
Quick pairing and stable wireless connections.
Delivers a clean interface that feels effortless from the start, with smooth multitasking that keeps your workflow going.
Built-in protection that keeps your data secure and protected at all times.
Remote Desktop and other useful tools available when needed for tasks.
Pre-installed Microsoft Office
Do Not Disturb Mode
Focus Sessions
Windows Security Center
Snap Layouts & Snap Groups
Virtual Desktops
Task View
Live Captions
Multitasking Begins With GamiBook 6’s Enhanced Virtual Desktops, you can unlock a smarter way to work and play by creating separate spaces for work, creativity, and entertainment — each with its own wallpaper. Instantly switch between them, like unlocking multiple laptops in one device.
Runs smoothly in hot and humid conditions without performance drops.
Retains stable performance and battery health after 1000+ charge cycles.
Withstands pressure and impact for reliable everyday durability.
Ensures consistent key feel and responsiveness after extensive typing.
Connection stays reliable after repeated plugging and unplugging.
Keeps fast, accurate response through repeated presses.
Remains smooth and sturdy after repeated opening and closing.
Provides stable click feedback with precise control.
Online Call Center
Warranty Service
Repair Centers
Blackview GamiBook 6 Specifications
BrandBlackview
ModelGamiBook 6
ColorGrey
Dimension356.3 × 245.2 × 17.4 mm
Weight1.65 kg
Display16-inch, 16:10, 1920 × 1200, 90% Screen-to-body Ratio, 60Hz
CPUAMD Ryzen™ 7 7735HS, 8 cores / 16 threads
GPUAMD Radeon™ 680M
Cache4MB L2 + 16MB L3
Burst FrequencyUp to 4.75GHz
RAM16GB LPDDR5, 5500MT/s
SSD512GB, M.2
TF Card ExpansionUp to 2TB Expandable Storage
SpeakerDual BOX Stereo Speakers
Camera2MP Front, 1920 × 1080
FingerprintSupported
Battery57Wh, 3-cell polymer
OSWindows 11 Pro
Wi-Fi & BTWi-Fi 6 (IEEE 802.11 a/b/g/n/ac/ax), BT 5.2
I/O1 × HDMI 1.4 Max 4K
2 × USB 3.2 Gen 1 Type-A (5Gbps)
1 × USB 2.0 Type-A
2 × Type-C (PD + DP + Data 5Gbps)
1 × TF Card Slot
1 × 3.5mm Audio Jack
| Brand | Blackview |
| Model | GamiBook 6 |
| Color | Grey |
| Dimension | 356.3 × 245.2 × 17.4 mm |
| Weight | 1.65 kg |
| Display | 16-inch, 16:10, 1920 × 1200, 90% Screen-to-body Ratio, 60Hz |
| CPU | AMD Ryzen™ 7 7735HS, 8 cores / 16 threads |
| GPU | AMD Radeon™ 680M |
| Cache | 4MB L2 + 16MB L3 |
| Burst Frequency | Up to 4.75GHz |
| RAM | 16GB LPDDR5, 5500MT/s |
| SSD | 512GB, M.2 |
| TF Card Expansion | Up to 2TB Expandable Storage |
| Speaker | Dual BOX Stereo Speakers |
| Camera | 2MP Front, 1920 × 1080 |
| Fingerprint | Supported |
| Battery | 57Wh, 3-cell polymer |
| OS | Windows 11 Pro |
| Wi-Fi & BT | Wi-Fi 6 (IEEE 802.11 a/b/g/n/ac/ax), BT 5.2 |
| I/O | 1 × HDMI 1.4 Max 4K 2 × USB 3.2 Gen 1 Type-A (5Gbps) 1 × USB 2.0 Type-A 2 × Type-C (PD + DP + Data 5Gbps) 1 × TF Card Slot 1 × 3.5mm Audio Jack |
