Blackview GamiBook 16 16" 300Hz 2.5K Display Intel® Core™ CPU NVIDIA® GeForce GPU 16GB DDR5 RAM 1TB M.2 PCIe Gen4 SSD Windows 11 Pro Gaming Laptop
In stock
✔ 16" 2.5K 16:10 300Hz TÜV SÜD Low Blue Light Display w/ Premium Metal Design Body
✔NVIDIA® RTX™ 5060 GPU & Intel® Core™ i7-13650HX CPU
✔16GB DDR5 RAM + 1TB PCIe Gen4 SSD
✔Wi-Fi 6 & Wireless BT 5.2
✔Windows 11 Pro Pre-installed
Beyond Fast. Beyond 300Hz.
Designed for Competitive Gaming and Demanding Creativity
Faster Workflows. NVIDIA® RTX™ 5060 · Intel® Core™ i7-13650HX · 16GB DDR5 Memory · 1TB PCIe Gen4 SSD
Battle-ready NVIDIA® RTX™ 5060
Crank Up the Power. Elevate Your Gameplay. Great performance starts with powerful graphics. Built for gaming, creation, and multitasking, GamiBook 16 is powered by the new-generation NVIDIA® GeForce™ RTX™ 5060 Laptop GPU, based on the latest Blackwell architecture. As a next-gen gaming GPU, it outperforms traditional gaming laptops by keeping frame rates high and latency low, no matter how demanding the workload. With up to 115W Max TGP via Dynamic Boost, plus AI-powered technologies like DLSS 4 and advanced ray tracing, you get smooth gameplay, fast rendering, and immersive visuals – all without compromise.
Building on this foundation, DLSS 4 takes AI-driven rendering further with RTX AI acceleration, delivering enhanced performance and efficiency in supported titles. DLSS 4 is supported in over 800 games and applications, including more than 250 DLSS 4 titles.
* All data above were tested under ideal laboratory conditions.
Cinematic Visuals with Ray Tracing
Powered by next-generation Tensor Cores and enhanced media engines, GamiBook 16 brings stronger AI performance, improved video decode and encode efficiency, and more responsive handling of creative tasks.
Over 20%↑ faster than RTX™ 4060
Boosting up to 155W when needed, GamiBook 16 dynamically unleashes extra performance for smoother gameplay, faster rendering, and more seamless multitasking.
Performance Cores Threads
Modern games and large creative projects demand fast, larger storage, which is why
GamiBook 16 comes equipped with a high-speed 1TB PCIe Gen4 SSD. It delivers faster boot times, quicker
game loading, and rapid access to large files for a smoother everyday experience. It features two M.2
PCIe Gen4 x4 slots, supporting up to 4TB total storage expansion, giving you more room for growing game
libraries, creative assets, and media collections.
Laptop GPU 8GB GDDR7, Up to 115W Max TGP, 20%↑ Faster than RTX™ 4060
Gaming Processor 4.9GHz, 14 Cores & 20 Threads, 15%↑ Better Gaming Performance
Up to 64GB Expansion 4800 MT/s, 50%↑ Faster Memory Speed
Up to 4TB Expansion
of Up to 170W 115W GPU + 55W CPU
Expansion 5x Productivity
Reduction Sharp Video, Clear Communication
Battery
Keyboard 12 Dynamic Lighting Effects
Blue Light Certified 100W Fast Charging
Test Cycles 12-month Warranty Service
With a total cooling area of 97,156 mm², which is 4.86× larger than the previous generation, it greatly improves thermal efficiency during gaming, multitasking, and high-load sessions, keeping GamiBook 16 cool, responsive, and powerful.
Step into expansive visuals on GamiBook 16, featuring a wide-view 16” 2.5K
anti-glare IPS display with narrow bezels that provides a spacious viewing area for immersive gaming and
productivity. Its 16:10 aspect ratio delivers approximately 11% more vertical space than 16:9 displays,
while 500 nits of brightness provides excellent visibility even in bright indoor and daylight
environments. With vivid colors and crisp visuals, every detail pops with clarity, elevating both gaming
and productivity performance.
Comfort Professionally certified by TÜV SÜD, GamiBook 16 reduces blue light exposure to minimize eye strain, providing a comfortable viewing experience for prolonged sessions, whether for gaming, editing, or everyday tasks.
With Two-way AI Noise Cancellation, background noise is reduced on both sides, ensuring clear communication between you and your team.
With 500 nits brightness, 100% sRGB color gamut, and factory color calibration powered by X-Rite, achieving a ΔE less than 1, the display delivers pro-grade visual performance for gaming and content creation. The productivity-friendly 16:10 aspect ratio further enhances vertical workspace and overall viewing efficiency.
With a 2.5kg chassis and 26.9mm profile, it’s designed for performance without excess bulk, making it easier to carry than most gaming laptops.
(10Gbps, DisplayPort 1.4, Power Delivery) ×2 HDMI 2.1 (4K display output) ×1 Mini DisplayPort 2.1a
(high-resolution display output) ×1 2.5GbE RJ45 LAN Port ×1 3.5mm Audio Combo Jack ×1 DC-in Power Input ×1 Kensington Security Lock Slot ×1
Type-C (DP 1.4) ×2 Max 4K @60Hz
16:10 Display 2560 × 1600
Performance Every millisecond is crucial in competitive play. With 2.5G Ethernet for lag-free wired dominance and Wi-Fi 6 for uninterrupted wireless speed — whether you're raiding online or streaming 4K, your connection won't hold you back.
competitive gameplay. Fast wireless connectivity for
everyday use.
Yours to command. Performance stays exactly where you set it. GamiBook 16’s Control Center gives you direct command over four performance modes, GPU switching, per-key RGB lighting— all within a streamlined interface. Shape your performance, visuals, and experience exactly the way you want.
Four Modes
Efficiency. Or Both. Break free from graphics constraints. Switch between dGPU for raw performance, iGPU for maximum battery life, or Hybrid mode that intelligently balances both, putting the right GPU to every task.
Own Your Game.
Gameplay Per-key Backlight with
Workflows Pre-installed with Windows 11 Pro, GamiBook 16 is designed for professional use from the start. Step into improved productivity and security with enhanced multitasking, productivity tools, and security features for streamlined daily work.
Ready When You Need It. Quickly access Microsoft Copilot to help with everyday tasks like drafting content, brainstorming ideas, and improving productivity. Just press the Copilot key and get started faster.
Built for Everyday Use GamiBook 16 has undergone strict reliability and stress testing to ensure reliable performance under daily workloads. Built with a sturdy and solid structure, it is designed for long-term durability in everyday use.
Operating Test Runs smoothly in hot and humid conditions without performance drops.
Resistance Test Withstands pressure and impact for reliable everyday durability.
Durability Test Connection stays reliable after repeated plugging and unplugging.
85% Screen-to-body Ratio
USB Type-C (Full-function, DP 1.4, PD, 10Gbps) ×2
HDMI 2.1 ×1
Mini DisplayPort 2.1a ×1
RJ45 2.5GbE Ethernet Port ×1
3.5mm Combo Audio Jack ×1
Related Product:
#Cheap laptop for student, #budget Windows 11 laptop, #best basic laptop for students
