Blackview FORT 2 Ultra-slim 6.56-inch MediaTek Helio G81 Octa-core 5000mAh 16MP+13MP AI Camera NFC 4G Rugged Phone
Out of stock
✔6.56-inch 245.3g & 10.7mm Slim Rugged Phone
✔Octa-core MediaTek Helio G81 Processor
✔5000mAh & 18W Fast Charging
✔IP68 & IP69K & MIL-STD-810H Certified
The Blackview FORT 2 is a slim rugged 4G phone made for users who need outdoor reliability without carrying a heavy brick. Its 6.56-inch 90Hz HD+ display, MediaTek Helio G81 processor, 5000mAh battery, and 18W fast charging keep daily tasks smooth and practical. With IP68 & IP69K protection, MIL-STD-810H durability, glove mode, underwater camera, NFC, dual 4G support, and a 16MP rear camera, it is a lightweight field-ready phone for work, travel, and everyday adventure.
| Model | FORT 2 |
| Color | Obsidian Black, Lightning White |
| Dimension | 174.6*83*10.7mm |
| Weight | 245.3 g |
| OS | DokeOS 5.0 Based on Android 15 |
| Display | 6.56-inch HD+ IPS, 720*1612 Resolution 90Hz Refresh Rate, 89.7% Screen-to-body Ratio, 180Hz Touch Sampling Rate |
| CPU | Octa-core MediaTek Helio G81 Processor |
| RAM & ROM | Up to 24 GB RAM +128GB/256GB ROM |
| TF Expansion | Up to 2TB Expansion |
| Battery | 5000mAh; 18W Fast Charging |
| Front Camera | 13MP |
| Rear Camera | 16MP |
| Speaker | Smart-K Speaker |
| Navigation | GPS+Glonass+Beidou+Galileo , Support L1 |
| Card Slot | Dual; 2*SIM/1*SIM +1*TF Card |
| NFC | Support |
| Dual 4G VoLTE | Support |
| Wi-Fi &BT | IEEE802.11 ac/a/b/g/n (2.4/5.0GHz); BT 5.0 |
| Network Connectivity | 2G Band: B2/B3/B5/B8, CDMA: BC0/BC1/BC10 3G Band: B1/B8 4G Band: FDD: B1/B3/B7/B8/B19/B20/B28AB, TDD: B40/B41 |
How much does the Blackview FORT 2 weigh?
The Blackview FORT 2 weighs 245.3 grams and is 10.7 millimeters thick, making it both practical and not overly bulky—perfect for both work and everyday use. Its slim profile fits easily into a jacket pocket, work bag, or fanny pack. Whether you’re commuting, traveling between job sites, or enjoying outdoor activities, it’s highly portable.
It also features a rugged and durable design that balances everyday portability, so you can carry it with you all day long and handle calls, messages, and navigation needs at any time.
What mobile networks does the Blackview FORT 2 support?
The Blackview FORT 2 is a rugged 4G smartphone that supports 4G LTE, 3G, and 2G networks. You can use it on compatible mobile networks to make calls, send messages, browse the web, view maps, and make video calls.
It also supports dual 4G SIM cards, allowing you to use both your work and personal numbers on the same phone. Before purchasing, please check the supported network bands listed in the FORT 2 product specifications and verify compatibility with your carrier. Available services depend on your mobile plan and local network coverage.
Does the Blackview FORT 2 have 24GB of physical RAM?
No, the Blackview FORT 2 comes with 8GB of physical RAM and supports up to 16GB of virtual RAM expansion, for a total of 24GB of memory. This 16GB portion is allocated from the phone's internal storage.
Virtual RAM expansion enhances multitasking capabilities by allowing more applications to remain active in the background—a useful feature for daily use, outdoor tasks, and switching between multiple apps. However, the performance of virtual RAM is not identical to that of physical RAM.
Can I use the Blackview FORT 2’s touchscreen while wearing gloves?
Yes. The Blackview FORT 2 features “Glove Mode 2.0,” which allows the touchscreen to respond normally even when you’re wearing gloves. This is especially useful when it’s inconvenient to remove your gloves—such as when performing maintenance outdoors, in cold weather, or when checking directions, answering calls, or opening work apps.
Response may vary depending on the material, thickness, and fit of your gloves, so we recommend testing this feature with the gloves you normally wear. Larger buttons and simple taps are generally easier to use. If the touchscreen does not respond, or if you need to perform precise actions, it may be better to switch to thinner gloves or remove one glove.
Can I use the Blackview FORT 2 in the rain?
Yes. The Blackview FORT 2 features IP68 and IP69K water resistance ratings, making it capable of withstanding sudden outdoor rain. Even when the weather changes, you can still use it to check your route, answer calls, or record work details. Before exposing the phone to water, please ensure that all protective covers are securely closed and that the phone’s casing and seals are undamaged.
After use, we recommend wiping the phone with a soft, dry cloth and ensuring the charging port is completely dry before connecting the data cable. If water droplets affect touchscreen responsiveness, wipe the screen dry before using it. Water resistance may diminish due to wear and tear, impact, or repairs, so if the screen is cracked or the body is damaged, inspect the device before exposing it to moisture again.
What can I do with the Blackview FORT 2’s shortcut button?
The shortcut keys on the Blackview FORT 2 allow you to quickly access selected features or apps, such as turning on the flashlight or taking a screenshot. Instead of having to unlock your phone and search for the app every time, you can simply assign frequently used actions to these keys. You can also set up shortcut keys for functions you frequently use while working or during outdoor activities.
You’ll need to select the desired option from the list in your phone’s settings, then test the button while the screen is both on and locked. However, some actions may require you to unlock your phone first.
Who is the Blackview FORT 2 rugged phone best suited for?
The Blackview FORT 2 is ideal for farm workers, maintenance technicians, delivery drivers, warehouse staff, and others. It’s also well-suited for commuters and casual outdoor enthusiasts, as it’s not only rainproof, dustproof, and shock-resistant, but also very lightweight, slim, and durable.
In addition to its slim design, the Glove Mode and shortcut keys make it easy to perform frequently used tasks such as checking directions, opening work apps, and using the flashlight. As a result, the FORT 2 is well-suited for everyday communication and offers exceptional durability.
What does the Blackview FORT 2’s 90Hz refresh rate mean for everyday use?
The Blackview FORT 2’s display can refresh the screen up to 90 times per second. Compared to a 60Hz display, this makes scrolling through messages, browsing the web, and navigating menus much smoother when supported by the software.
The refresh rate does not determine image clarity; that depends on factors such as screen resolution and the content itself. It also does not mean that every game will run at 90 frames per second. Gaming performance is determined by factors such as the processor, graphics settings, and the game’s own frame rate limit, while video playback depends on the frame rate of the video itself.
Can I expand the Blackview FORT 2’s storage with a microSD card?
Yes. The Blackview FORT 2 supports microSD cards up to 2TB, providing additional space to store photos, videos, music, and work documents. This extra storage is especially convenient if you frequently collect files while outdoors or like to keep multimedia files on your phone.
The microSD card shares the same slot as the second SIM card, so you’ll need to choose between using two SIM cards or one SIM card plus a memory card. Be sure to purchase from a reputable supplier and select a memory card suitable for storing your files. Some apps recommend saving data to internal storage, and you should also back up important files to another location in case the memory card is lost or damaged.
Does the Blackview FORT 2 support NFC payments?
Yes. The Blackview FORT 2 supports NFC payments and allows for contactless payments through compatible payment services. This requires a supported bank card, a payment app available in your country or region, and a phone that meets the service’s security requirements. The presence of NFC hardware alone does not guarantee that every bank or payment app will work properly.
To get started, enable the NFC feature, add your bank card to the payment app, complete the verification process, and select that app as your default contactless payment service. If necessary, you can also set up a screen lock. When checking out, unlock your phone and hold it near the contactless payment symbol on the terminal. If the payment fails, first check the app’s settings and whether your bank card is eligible before determining if the issue lies with the phone itself.
What can I use the Blackview FORT 2’s built-in toolbox for?
The Blackview FORT 2’s toolbox includes practical tools such as a flashlight, compass, and sound level meter. These tools can help with everyday tasks, such as finding dropped items in dimly lit areas, determining your direction outdoors, or checking the noise level around you.
For more accurate readings, it is recommended to use each tool under appropriate conditions. When using the compass, stay away from magnets and large metal objects; when measuring noise levels, do not cover the microphone. These tools are designed for quick reference but are not intended to replace calibrated equipment for professional measurements or safety assessments.
Can I take underwater photos with the Blackview FORT 2?
Yes. The Blackview FORT 2 is equipped with an underwater photography feature and can be submerged at a depth of 1.5 meters for up to 30 minutes. This is a general guideline for the phone’s water resistance; however, you should not exceed the tested depth or use the phone underwater for extended periods.
Before attempting underwater photography, make sure the phone is undamaged, all protective covers are securely closed, and you are familiar with the camera’s operation. Please note that the protection rating does not apply to diving, seawater, pool chemicals, or pressurized flowing water environments. Additionally, after the phone comes into contact with water, be sure to dry it off and ensure the charging port is dry before charging.
How can the Blackview FORT 2 help me keep work notes organized?
The Notebook 3.0 app on the Blackview FORT 2 supports search, sorting, and reminder features, and allows you to export notes as Word or TXT files. You can use it to centrally manage work details, inspection records, shopping lists, or follow-up tasks, making it easier to find the information you need.
Create a note for each work task, including the client’s name, location, and date in the title. Record completed work and any points to note, then set a reminder for your next service visit. When you need to share details, simply export the note and send it.
How can I transfer data from my old phone to the Blackview FORT 2?
Be sure to back up your old phone before you begin. During the initial setup of the Blackview FORT 2, follow the on-screen prompts to copy apps and data or restore from a Google backup. When using the wired or wireless transfer options provided on the screen, make sure both phones are charged and allow enough time to transfer large photo and video libraries.
Before resetting or giving away your old phone, verify that your contacts, photos, documents, and other important information have been successfully transferred. Banking apps, authentication accounts, and some chat histories require separate transfer or login procedures. If you’re migrating from an iPhone, follow the corresponding iPhone data transfer guide and turn off iMessage when transferring your phone number to an Android device.
Should I choose the 128GB or 256GB version of the Blackview FORT 2?
If you mainly use your phone for messaging, navigation, everyday apps, and occasional photography—don’t play games, have a limited budget, and regularly back up and delete old files—the 128GB version is the best choice. On the other hand, if you need to store a lot of videos, games, downloaded maps, or work documents, we recommend the 256GB version.
Additionally, if your current storage is nearing 128GB, we recommend choosing the 256GB version to leave more space for future downloads and updates. You can also add a microSD card, but this will occupy the second SIM card slot. Therefore, if you need to use two SIM cards simultaneously, opting for larger internal storage may be particularly useful.
What do the Blackview FORT 2’s 16MP and 13MP camera specifications refer to?
The 16-megapixel camera refers to the Blackview FORT 2’s rear camera, while the 13-megapixel camera refers to the front camera. The rear camera can be used for everyday scenes, work documentation, and photographing documents, while the front camera is used for selfies and video calls.
To achieve clearer photos, clean the lens before use and take photos in a well-lit area. When photographing documents, hold the phone parallel to the page to avoid casting shadows on the document, and make sure the text is clearly legible before taking the photo.
