Blackview FitBuds H1 Hybrid Active Noise Cancelling Bluetooth 5.4 Hi-Res Audio Over Ear Headphone
Hurry up, only 10 items left in stock.
✔High-quality 3D Stereo Audio w/ Hi-Res Audio Certified
✔Hybrid Active Noise Cancelling With Mic
✔500mAh Mega Battery, Up to 65 hours of Non-stop Audio
✔Wireless Bluetooth 5.4 & USB-C Charging Port
Blackview FitBuds H1 is made for users who need comfortable, focused listening during work, study, travel, and long indoor sessions. With hybrid ANC, it helps reduce surrounding noise in shared offices, coffee shops, public transport, and home environments. Up to 65 hours of audio battery life makes FitBuds H1 easy to rely on through busy days, business trips, and extended listening without frequent charging. BT 5.4 and USB-C charging keep the experience simple and modern, while the noise-cancelling mic helps make work calls and online meetings clearer. For users who want fewer distractions, longer comfort, and dependable all-day audio, FitBuds H1 is a practical headphone choice for everyday focus.
| Model & Design | |
| Model | FitBuds H1 |
| Color | Nimbus Black, Nebula White |
| Dimensions | 185.9 * 182.8 * 82.6mm |
| Weight | 248g |
| Audio & Performance | |
| Driver Unit | Φ40mm Large Driver |
| Frequency Response | 20Hz ~ 20KHz |
| Audio Codec | SBC / AAC / LHDC |
| Connectivity & Battery | |
| BT Version | 5.4 |
| Connection Range | Indoor: >15m, Outdoor: >10m |
| Battery Capacity | 500mAh |
| Charging Time | 2 Hrs (0%~100%) |
| Charging Port | Type-C |
