Blackview DCM8 Pro 15.3-inch Dual Monitor Portable Laptop Screen Extender with 2 USB-C Port
Hurry up, only 7 items left in stock.
✔Dual 15.3" IPS 1920*1200 16:10, Triple Your Laptop Screen
✔TÜV SÜD Low Blue Light Certified
✔Integrated Box Speaker
✔2x USB-C Ports, Fits 14”to 17.3" Laptops
Blackview DCM8 Pro Portable Screens give your laptop a cleaner, wider, and more professional triple-screen workspace. With dual FHD IPS displays, 100% sRGB color, 4320Hz PWM zero-risk dimming, TÜV-certified eye comfort, and one-cable USB-C plug-and-play, it keeps work, creation, gaming, and travel effortlessly organized—thin, light, and ready anywhere.
| Model | DCM8 Pro |
| Color | Grey |
| Material | Aluminum Alloy + PC + ABS |
| Display | 15.3" IPS, 1920×1200 Resolution, 60Hz Refresh Rate, 300 nits Brightness, 100% sRGB |
| Ports | (Full-Featured, USB3.1) 1 × USB-C (PD 3.0, 20V/5A Max) |
| Features | Only One Cable Powers Two Screens |
| Speaker | Single BOX Speaker |
| Compatibility | Resolution: 640 × 480 – 1920 × 1200 Color: RGB Refresh Rate: 60Hz OS: Mac / Windows / Android / Linux / Chrome |
| Dimension | 364.4 × 237.43 × 21mm |
| Weight | 1.2kg |
