Blackview DCM6 14-inch Dual Monitor Portable Laptop Screen Extender with Speaker
Hurry up, only 8 items left in stock.
✔Dual 14" IPS 1080P FHD, Triple Your Laptop Screen
✔TÜV SÜD Low Blue Light Certified
✔Integrated Box Speaker
✔3x USB-C Ports, Fits 13.3”to 17.3" Laptops
DCM6 Screens deliver an ultra-light dual-display experience designed for portable productivity. Featuring two 14-inch 1080p IPS eye-comfort screens with 300 nits brightness, it enables seamless multitasking anywhere. At just 4.5mm thin and 1kg, it stays highly portable. Universal USB-C plug-and-play ensures wide compatibility across OS platforms. With TÜV SÜD low blue light, integrated speaker, 100W reverse charging, and aluminum alloy durability, DCM6 redefines mobile triple-screen workflow efficiency and creators use.
| Model | DCM6 |
| Color | Grey |
| Material | Aluminum Alloy + PC + ABS |
| Display | 14" IPS, 1080p FHD, 60Hz Refresh Rate, 300 nits Brightness, 157.35 PPI |
| Ports | 2 × USB - C (Full - Featured, USB3.1, DP Alt Mod, PD3.0 20V/5A MAX) 1 × USB - C (PD 3.0, 20V/5A Max) |
| Speaker | Single BOX Speaker |
| Compatibility | Resolution: 640 x 480 - 1920 x 1080 Color: RGB Refresh Rate: 60Hz OS: Mac / Windows / Android / Linux / Chrome |
| Dimension | 345 x 207 x 20.5 mm |
| Weight | 1 kg |
