Blackview BV9300 6.7-Inch 12+256GB 120Hz Display MediaTek Helio G99 6nm CPU 15080mAh 4G Outdoor Smartphone
Out of stock
✔Additional Tool: 100LM Flashlight or 40M Laser Rangefinder
✔15080mAh Enormous Battery, Up to 76-day Standby
✔120Hz Dynamic Refresh Rate Display
✔12GB RAM+256GB ROM
✔MIL-STD-810H & IP68 & IP69K
BV9300
One-Of-A-Kind Precise Measurement/ Superbright Rugged Lifestyle
Charge for 3 Hours, Last for 76 Days
15080mAh
33W Fast Charge
100LM Flashlight
32MP Front Camera
Mediatek Helio G99
Up to 2.2GHz
As speedy as 5G Chipset
50MP Rear Camera
True-Chroma Photo Master
120°Ultra-wide
ArcSoft® 3.0 Algorithms
12GB RAM + 9GB Expansion = Up to 21GB RAM
App start-up 25% faster
256GB ROM + Up to 1TB Expandable Storage
2MP Rear Depth Camera
Smart-PA BOX Speaker
Multifunctional NFC
120Hz
2.3K Display
MIL-STD-810H & Leading IP68 & IP69K Waterproofness
Glove Mode
DokeOS 3.1 Based on Android 12
Fingerprint Sensor & Power Button 2-in-1 Key
Lanyard Hook
Fluency Upgrades -
Camera Upgrades -
Battery Upgrades -
Ruggedness Upgrades -
OS Upgrades
Thinner & Lighter Incell Display
Multi-touch 10-point
120Hz
2.3K Display
GORILLA®
GLASS 5
240Hz
81%
FHD+ IPS
21:9
391 PPI
500 nits
25% faster
Mediatek Helio G99
2* Cortex-A76 (2.2GHz) +
6* Cortex-A55 (2.0GHz)
55%
more fluency
LPDDR4X + UFS2.1
AnTuTu 353283 As fast as 5G chipset
Arm Mali- G57 CM2
Atomized Memory
17%
Low Memory Killer
15%
Integrated Cooling System
Cooling Graphite & Copper Foil 7,392mm2 Cooling Silicon 144mm2
2112mm²Cooling copper pipes
144mm²Cooling silicon
5280mm²Cooling graphite
43.8°C
Intelligent and dynamic management of CPU, GPU and memory according to active measurements of power, thermal and gameplay factors.
Networking Engine 2.0Call & Data Concurrency allows users to defer calls while in-game without the data connection dropping.
50MP Rear Camera
32MP Front Camera
Impressive Low Light Photography
120°Ultra-wide
Face Fill Light
Up to 1 cm Ultra-Macro
Underwater Mode
Improved HDR
360° Panorama Mode
Beauty Mode
Portrait Mode
Upgraded Super Night Backed by ArcSoft® 3.0
2K Video
ISOCELL PlusEnhanced pixel performance
TetrapixelRemosaic algorithm
3D HDRMore vivid images and videos even in mixed and challenging lighting environments
25%
Industry-leading 1/2.8-inch sensor with 25% improved light sensitivity
8MP Rear Camera120°Ultra-wide & Up to 1 cm Ultra-Macro -
50MP Rear Camera -
Tetrapixel TechnologyCapture details even in the dark
Inter-scene HDRPerfectly balanced shadows and highlights
Double Super PD for Auto FocusCapture fast-moving subjects with ease
8MP Rear Camera (120° Ultra-wide & Up to 1 cm Ultra-Macro)
Improved HDR
Portrait Mode
Beauty Mode
360° Panorama Mode
Super Night
HDR
Beauty
Portrait
Panorama
Super Night
Solid-State Battery Dual Electric Cores Safer & More Stable
15,080mAh Enormous Battery
1,824hrs of Standby
33W Fast Charge
5W OTG Reverse Charging Support
Survive extreme cold and heat at down to
-30°C and up to 58°C
Intelligent Charging Protection & Customized Charging Mode
Longer Battery Lifespan
Game15.5 hrs
Video23.5 hrs
Web25.5 hrs
Calling84 hrs
Music54 hrs
Standby1,824 hrs
Intelligent Charging ProtectionBV9300 allows you to turn on the Intelligent Charging Protection that helps stop the smartphone from charging if its battery level exceeds 80% during night charging. This protects you against all the possible overcharging-caused risks, ensuring your safety during deep sleep at night.
Customized Charging ModeCustomized Charging Mode automatically stops the smartphone from charging when its battery level reaches the desired level you set.
Portable power station
Digital camera
Navigation compass
Wireless speaker
40M Laser Rangefinder/ 100 Lumen Flashlight
≈170K+ Photos
≈2.8K+ Short Videos
≈446K+ Songs
≈2.8K+ Short Videos
Up-to-40M
Laser Rangefinder
100 Lumen
Flashlight
Useful Toolkit
Underwater Camera
Gloves Mode
CORNING® GORILLA® GLASS 5
GPS+Beidou+Glonass+Galileo
Length Measurement1.Decide the two points between which you want to measure the length. (Note: There should be an obstacle of light color on one end to reflect the laser beam.)
2.Launch Laser Rangefinder App.
3.Choose between “Measure from the bottom or top of the phone”.
4.Put the bottom or the top of the phone on one point.
5.Turn on Laser
6.Click “Start Measurement”.
7.Read the length measurement result.
8.You may copy the result to your clipboard.
Area Measurement1.Turn on Laser
2.Click “Start Measurement” to measure the length.Click “Start Measurement” again to measure the width.
3.Read the area result of the object.
Volume Measurement1.Follow the same steps above to measure the length, width and height of the object.
2.Read the volume result of the object.
Thickened rubber corners for incredible shock resistance.
Tightly-fit cap for charging port to resist water from infiltration.
Aluminium alloy side frame fixed with screws for reduced risks of falling apart.
Double-shot molding TPU & glass fibre for great protection against drops.
Undergone tests that include but are not limited to:
Rain
Sand and Dust
Vibration
Shock
Acceleration
High Temperature
Low Temperature
Humidity
Altitude
Immersion
Cold Room
Live Wallpaper
Customize Lock-screen Shortcut
New Focus Mode App
New Health App
Sports Metrics Monitoring
Health Metrics Recording
Customize Your Folders
Data Migration Assistant
old device
new device
Customized Mode
Game Mode
No-play ModeNo-play mode blocks your access to the apps you choose and prohibits you from receiving any notifications from them during no-play time.
Meditation ModeAdd the apps you want to use to the whitelist during meditation, so you can have full access to them while apps not included in the list will be completely blocked and locked down.
Work & Sport & Read ModeCustomize the duration when you only want to focus on work, sports or reading and add related apps to the whitelist so you can only use those apps during this period of time.
Customized ModeYou are free to create your own focus modes according to your specific concentration needs.
Sports Metrics MonitoringIn the Health app, you are allowed to record your exercise metrics including steps, calories, duration or distance of running, walking and cycling. -
Health Metrics RecordingKeeping a record of your body health statistics has never been easier. The Health app helps you record your sleep duration, water intake, body weight, blood glucose and blood pressure efficiently, so you can be well informed of your physical condition and body changes everyday.
Do Not Disturb Mode (DND)
Magnifier
Compass
Flashlight
Calculator
Alarm
Customized Shortcut Button
Multifunctional NFC
Lanyard Hook
Start Soundrecording Open Flashlight Screenshots Open Underwater Camera Open PTT Open SOS Open Game Mode
Multifunctional NFCEasier and faster. Support Google pay, public transport ticket purchase, and file sharing with other devices.
Fingerprint Sensor & Power Button 2-in-1 KeyReach the side button with your finger naturally and quickly start up and unlock the phone seamlessly.
ModelBlackview BV9300
(40M Laser Rangefinder/100 Lumen Flashlight) -
ColorBlack, Green, Orange
Dimension184.6*85.6*22.8mm
Weight520g
OSDokeOS 3.1 Based on Android 12
Display6.7-inch, 120Hz Dynamic Refresh Rate, 1080*2388 Resolution, CORNING® GORILLA® GLASS 5
CPUMediatek Helio G99 (6nm), Octa-core, Up to 2.2GHz
RAM & ROM12GB RAM & 256GB ROM, LPDDR4X+UFS2.1
RAM ExpansionUp to 9GB
Expandable StorageUp to 1TB TF
Battery15080mAh, 33W Fast Charge
Front Camera32MP ( Samsung® ISOCELL GD2)
Rear Camera50MP (Samsung® ISOCELL JN1) 8MP (120° Ultra-wide & Up to 1 cm Ultra-Macro) 2MP Depth
SpeakerSmart-PA BOX Speaker, 1PCS
Rugged RatingIP68 & IP69K & MIL-STD-810H
NavigationGPS+Beidou+Glonass+Galileo
Card SlotDual Hybrid SIM Slots
Glove ModeSupport
NFCSupport
Dual 4G VolTESupport
WiFi2.4/5G (802.11a/b/g/n/ac)
Network Connectivity2G Band: GSM: 850/900/1800/1900 (B2/B3/B5/B8) 3G Band: WCDMA: B1/B2/B4/B5/B8 CDMA: BC0/BC1/BC10 4G Band: LTE_FDD: B1/2/3/4/5/7/8/12/13/17/18/19/ 20/25/26/28A/28B/30/66 LTE-TDD:B34/38/39/40/41
