Blackview BV5200 ArcSoft AI Algorithm Powered Camera 4+32GB Tough 4G Smartphone
Out of stock
Note:
X
BV5200
ArcSoft-powered, Redefine Rugged Phone Cameras
5MP + 13MP
ArcSoft® Panorama Mode
ArcSoft® Beauty Mode
ArcSoft® HDR Mode
ArcSoft® Portrait Mode
Face Fill Light
Night Mode
Underwater Mode
Reverse
Charging Support
GPS + Beidou + Glonass + Galileo
Doke OS 3.0
(Android 12)
IP68 & IP69K &
MIL-STD-810H
6.1-inch
HD+ Display
MediaTek Helio A22
4GB RAM + up to
3GB Expansion
32GB ROM + up to
1TB TF Expansion
5180 mAh
Battery
Cameras Made More Powerful
13MP Rear + 5MP Front Cameras
Backed by Advanced Algorithm
to Shoot Better
Blackview adopts the advanced camera algorithms from ArcSoft, a leading algorithm and software solution provider, for the BV5200 to help users get the most out of its photography and shoot more like a pro.
5MP front camera
13MP main camera
Flash
360° Panorama Capture
Powered by the ArcSoft panorama stitching technology that supports dynamic shooting direction detection, exclusive access to ArcSoft real-time stitching, and more, BV5200’s Panorama Mode achieves the best possible stitching results.
Improved HDR
BV5200’s cameras adopt the ArcSoft HDR technology to more accurately determine brightness levels within various shooting environments and ensure bright and dim areas receive optimal exposure, resulting in the imaging with clearer details, distinct light levels, and stunning color.
Flawless Beauty, Perfect You
The Beauty Mode adopts the ArcSoft Beauty technology that supports fast face detection, facial attribute analysis, and smart facial beautification to present yourself as best as you can.
Be the Attractive Focus
The Portrait Mode supported with the ArcSoft Portrait technology can precisely segment the foreground and background and intelligently blur the background to highlight the captured subject.
Other Camera Highlights
Face Fill Light
Taking a selfie outdoors at night is a complete no-brainer with the Face Fill Light which lets you never compromise on light conditions and take pictures of yourself and friends, day or night.
0.1s Ultra-fast PDAF
BV5200 adopts the 13MP Sony® IMX258 that supports the PDAF technology as the rear camera. It takes only 0.1 seconds to autofocus sharply to shoot birds darting across the sky, cars speeding down a track, the perfect jump shot, or any other wonderful moments.
Night Mode
Take brighter and stunning images with low noise even in poor-lit environments.
Underwater Mode
With the Underwater mode available, make awesome snaps for the splendid scenes or other wonderful life moments anywhere.
Ruggedness that You can
Always Rely on
MIL-SPEC Upgrading from
810G to 810H
Blackview shifts the military-grade rating for rugged phones from MIL-STD-810G to the latest revision, MIL-STD-810H, which concentrates on more rigorous testing requirements in demanding environments of various kinds for guaranteed durability and endurance.
Rain
Sand and Dust
Vibration
Shock
High Temperature
Low Temperature
Humidity
Acceleration
Altitude
Immersion
Drop proof up to 1.5m meters
Leading IP68 & IP69K Rated
Waterproofness
BV5200 is specially designed to perform to high standards in wet environments and survive more than just a splash of water. Have peace of mind when use it in the rain or fall it into water.
Waterproof up to 1.5m deep for 30mins
Tough Doesn’t Mean Bulky
Blackview BV5200 is engineered with a superior level of rugged durability to survive the drops and bumps of the day-to-day. But having the highest reliability no longer means that the BV5200 needs to be as bulky and heavy as a brick. Instead, it's as light and thin as it's tough.
13.65mm Thinner & 268g Lighter
Performance to be Mighty
MediaTek Helio A22
The Power and Speed for Most Demands
Powered by the quad-core MediaTek Helio A22 processor, BV5200 gives a strong boost for work and entertainment performance.
4GB RAM + up to 3GB Expansion
Make Everything Quicker and Smoother
The RAM expansion function extending the 4GB RAM to up to 7GB enables BV5200 to smoothly and effortlessly run more apps simultaneously in the background and switch across them for various tasks.
32GB ROM + up to 1TB TF Expansion
More Room, More Possibilities
BV5200 features dual card slots to insert either two SIM cards or one SIM card and one TF card expandable to 1TB. Paired with 32GB of ROM, you can save all your favorite photos and music right on your phone and access them anytime.
5180mAh Battery
Stay in Power Longer
Enliven your days with long-lasting power. Under the hood, BV5200 equips a large 5180mAh battery that intelligently saves power for when you need it most to power through your needs.
Game
8.5 hrs
Video
9 hrs
Web
14.5 hrs
Calling
18 hrs
Music
25 hrs
709.7 hrs
* The data is tested by Blackview Laboratory based on continuous use. Battery life depends on the actual usage situation.
5W Reverse Charging
Serve as A Power Bank, Buy One Get Two
When your backup smartphone or TWS earphones run low on battery on the go and find nowhere to charge, BV5200 is capable of lending some juices as a temporary power bank.
Reverse Charging Compatible Devices
TWS Earphones
Mobile Phones
Smart Watches
Mini Speaker
USB Fan
Others
6.1-inch HD+ Display
Large and Clear to View
Discover more beauties with a broader vision on the large 6.1" waterdrop display. 720*1560 HD+ resolution makes details vivid with rich colors and brilliant contrast.
83%
screen-to-body ratio
283
PPI
720*1560
HD+ resolution
450
nits of brightness
Screen that
Works with Gloves
No more need to unglove for any phone operation on freezingly cold winter days, in outdoor sports, or during work. Keeping your hands wrapped won’t mess up the screen recognition.
Note: When Glove Mode is enabled, the screen responds more sensitively to touches with glove on. Turn Glove Mode off when ungloving to avoid accidental screen activation.
Doke OS 3.0 Based on Android 12
Hit A New Height in Every Aspect
Harnessing the power from the Android 12, an OS more personal, safe, and effortless than ever before, and the Doke OS 3.0 featuring a bunch of useful tweaks and add-ups, BV5200 achieves a breaking-through UI performance for higher efficiency and smoother interaction.
Even the little things
are a big deal
Customized Shortcut Button
Easily programme the custom key to 7 different functions or other favorite apps and access them quickly.
Shortcut Button
Start
Soundrecording -
Open
Flashlight -
Screenshots
Open
Underwater
Camera -
Open PTT
Open SOS
Open
Game Mode
GPS & Beidou & Glonass & Galileo
Whether you’re driving, hiking, or just traveling across the country, BV5200’s high-precision quad navigation system offers a better route to your destination.
Face Unlock
Enable the face recognition function to unlock the smartphone quickly at a glance.
Dual 4G LTE
Support 4G LTE in both slots - offering high data transmission, more reliable coverage, low power consumption, and consistent HD call quality.
Useful Toolkit
A bunch of professional apps helps you get the job done.
Compass
SoundMeter
Pic Hanging
Gradienter
HeightMeasure
Magnifier
Warning
Plumb Bob
protractor
Barometer
Flashlight
StepCount
Green
Blackview BV5200
Model
BV5200
Colors
Black/Orange/Green
Dimension
161.6*77.86*13.65mm
Weight
268g
Display
6.1-inch 720*1560 HD+ IPS
83% Screen-to-body Ratio -
CPU
MediaTek Helio A22
RAM & ROM
4GB + 32GB
RAM Expansion
Up to 3GB Expandable
Card Slot
Three Slots : 2*SIMs +1* TF Card
Max TF Card Capacity
1TB
Cameras
5MP Front + 13MP Sony® IMX258 Rear
Battery
5180mAh; 10W Charge
Connectivity
Wi-Fi: 802.11a/b/g/n/ac
2G Bands: B2/B3/B5/B8
3G Bands: W1/W8
4G Bands: FDD:B1/B3/B7/B8/B20 TDD:B40 -
Navigation
GPS/Beidou/Glonass/Galileo
OS
Glove Mode
Support
Three card slots
Customizable button
Type-C charging port
5MP
Volume +/-
13MP
Flash
Power button
