Blackview BV9600 Pro 4G Rugged Smartphone - Blackview Official Store
Blackview BV9600 Pro AMOLED Screen 4G Ruggedized Smartphone - Official Refurbished
Sale price £165.00 Regular price £329.00
The world's top indestructible rugged mobile of 2019
Helio P70
AI Processor
Side Place
Fingerprint
Samsung® 16MP + 8MP
Dual Rear Camera
6GB RAM
128GB ROM
Eye-Protection
Display
5580mAh
BAK® Battery
US military certified
  • IP68
  • IP69k
  • MIL-STD-810G
  • More certification ...
Helio P70 is upgraded from Helio P60
Helio P70 provides class-leading performance and impressive power efficiency so you can be immersed in the movie and game. Multitasking becomes much faster and easier.
Lower Consumption 30%
More Efficient Cooling 20%
Game Laggy Optimization 90%
*NeuroPilot Intelligence | Context A73 | TSMC 12nm FinFET | 70% Increase.
AMOLED A Wider View,
A World of Excitement
On the BV9600 Pro, Blackview’s iconic FullView™ Display enjoys an amazing 19:9 aspect ratio, with ultra-narrow bezels, brand new Amoled display. The screen provides a wider view and much better visual effects for games and videos.
6.21 Inch | AMOLED | 1080*2248 | 10 Points Touch
16MP Dual Rear Camera,
AI Bokeh Create Masterpieces
The BV9600 Pro uses two rear cameras – a 16MP main camera and a secondary 8MP camera* – and is supported by an AI Bokeh algorithm. This algorithm has been optimized based on machine learning of large amounts of data, so it can achieve amazing bokeh shots that rival DSLR camera results, transforming every photo into an artistic masterpiece.
Samsung® 16MP
Main Camera
8MP Depth of
Field Camera
UnderWater Capture Mode
For more professional photograph underwater, BV9600 Pro features a UnderWater Capture Mode. You can enable it from the notification bar quick access tile. Once your into the UnderWater Capture Mode, the touch screen would stops working, use the volume up key to start or stop capture photo or video, use the volume down key to switch between photo and video. Use the power button to exit UnderWater Capture Mode.
Android 9 , Powered by Al
Android 9 harnesses the power of artificial intelligence to give you more from your phone. Now your phone is learning your preferences as you go. Your experience gets better and better over time, and it keeps things running smoother, longer.
Grey
Silver
