Blackview BV9500 Plus 10000mAh 4G Rugged Phone - Blackview Store
Blackview BV9500 Plus 4G Ruggedized Phone - Official Refurbished
£250.00 £125.00
✔10000mAh IP68 Waterproof
✔Helio P70 Octa Core
✔4GB + 64GB
Capacity: 4GB+64GB
4GB+64GB
4GB+64GB - Refurbished
Color: Black
Yellow
Description
BV9500 Plus
Rugged Smartphone
IP68| IP69K| MIL-STD-810G
Helio P70
AI Processor
4GB RAM
64GB ROM
1.8M
Drop proof
5.7’’ FHD+
IPS Display
10000mAh
BAK ® Battery
Sony® 16MP
Dual Rear Camera
Android 9.0
IP68 Water
&Dust Proof
Bigger than Bigger,
BAK® 10000mAh Battery
Inside the tough exterior of BV9500 Plus lies massive energy — a 10000mAh battery custom-crafted to pack maximum performance into ruggedized body. With so much power at your disposal, you can do more online, stream longer videos, and talk as much as you want without worry of getting through the day and days after. Full range of low-power design from hardware to software for BV9500 Plus, resulting in following data tested from full power to exhausted.
A Tough Tool, A True Survivor
BV9500 Plus is IP68/IP69K certified rating waterproof and dustproof, which means it offers the highest level of protection against dust, handle not just a brief dunk in water but also complete submersion under 1.8 meters up to 2 hours, further more, it can resist 1450 psi high-pressure and 80ºC high-temperature steam scouring. So you can feel free to go to the sea, to the river, to the mountain, to the desert, to the gobi, to the forest, to the valley, to the island. They're no match for this intercom rugged smartphone. Because it is built for the extreme, just like you.
IP69 CERTIFIED
WATERPROOF
1.5M Drop Proof
Octa-Core Helio P70 Processor,
Impressively Powerful yet Power-Efficient
The advance octa-core processors operate up to 2.1GHz keeps a sustained high-performance and reliably consistent user-experience. The upgraded Mali-G72 MP3 GPU running up to a speedy 900MHz guarantees smooth gaming. The latest TSMC 12nm FinFET production process, powering premium experiences that are also light on battery use. The perfect balance between performance and consumption, that’s the ultimate goal we always pursue.
4*2.1GHz Context A73 + 4*2.0GHz Context A53 | 3*Mali-G72 900MHz | TSMC 12nm FinFET
See a Clearer World
BV9500 Plus features an advanced dual-camera system designed to take your mobile photography to the next level. Its 16MP main camera is equipped with the big F2.0 aperture lens to capture clearer photos. Combined with the depth of field sub camera, BV9500 Plus can produce beautiful photo with creamy bokeh effect.
16MP Dual Rear Camera
IMX298 CMOS
F2.0 aperture
6P Lens
Multifunction NFC
The BV9500 Plus comes with full-featured NFC, supports card reading, card writing, card emulation, and P2P mode. After successfully binding the bus card and bank card, the mobile phone is your one card solution, take the bus, take the subway, brush POS machine, pay with your BV9500 Plus.
Open Wonder Android 9
Smarter, faster, more powerful and sweeter than ever. The world's favorite cookie helps BV9500 Plus achieve the most floating experience you ever seen.
Green
Yellow
Specification
Design
Product BV9500 Plus
OS Android 9
Color Grey, Silver
Weight 365g
Dimensions 165*81.8*18.7 mm
Screen
Panel type IPS
Display Resolution FHD IPS
Screen size 5.7 inch
Screen resolution 1080*2160
PPI/DPI 425
Screen to Body Ratio (%) 18:9 78%
Viewing Angle (H/V) Full angle
Connectivity
WIFI 802.11 a/b/g/n/ac
Bluetooth BT4.2
2G B2(1900), B3(1800), B5(850), B8(900)
3G WCDMA: B1(2100), B2(1900), B4(1700), B5(850), B8(900);
TDSCDMA: B34(2010---2025), B39(1880---1920);
C2K: BC0(800), BC1(1900)
4G FDD: B1(2100), B2(1900), B3(1800), B4(1700), B5(850), B7(2600), B8(900), B12, B13, B17(700), B18(850), B19(850), B20(800), B25(1900), B26(850), B28a(700), B28b(700)
TDD: B34(2100), B38(2600), B39(1900), B40(2300), B41(2500)
Hardware
CPU MT6771T
CPU Clock 2.1GHz
GPU ARM Mali G72 MP3 900MHz
RAM 4GB
RAM Type LPDDR4
ROM 64GB
ROM Type EMMC5.1
TF Card Slot Support
Max TF Card Capacity 128GB
USB 24pin TYPE-C
Camera
Front Camera 13.0MP
Front Camera Sensor S5K3L8
Front Camera Aperture f2.0
Front Flash NO
Rear Camera 16.0MP + 0.3MP
Rear Camera Sensor IMX298 + SP0A09
Rear Camera Aperture f2.0 / f2.8
Rear Flash YES
Power
Battery Capacity 10000 mAh
Max Charging Current 9V 2A
Multi-media
Video mp4\3gp\mov\mkv…
Audio flac\ape\ac…
Image jpeg\png\gif\bmp
Features
Navigation GPS+GLONASS
Sensors YES
Gesture YES
Gyroscope YES
Magnetic YES
Air pressure sensor YES
Hall NO
Compass YES
Fingerprint YES
RGB YES
NFC YES
Hotkont NO
Coulomb Counter YES
Wireless Charging YES
Sim-Card Type 2 Nano-SIM
FM YES
OTG YES
Earphones Jack Type 3.5mm
SAR Head: 0.165 W/kg;
Body: 0.640 W/kg;
Accessories
Gift Box x1
User Manual x1
Protective Film Separately x1
Power Adaptor x1
USB Cable x1
Earphones x1
