Blackview BV5900 4G Rugged Smartphone - Blackview Store
Blackview BV5900 5.7" 3+32GB MT6761 Water-resistant Dustproof 4G Ruggedized Phone - Official Refurbished
£143.00 £68.00
✔5.7 inch 720*1520 4G Smartphone
✔MT6761 2.0GHz 3GB+32GB
✔Rear:13.0MP + 0.3MP+ Front:5.0MP
Capacity: 3GB+32GB - Official Refurbished
Color: Green
Green
Description
Note:
BV5900
Cost-effective ruggedized phone
with futuristic space capsule look
Tougher than ever Reliable ruggedized phone
Blackview BV5900 adopts industry-leading rugged rubber, which is usually seen on top off-road vehicle tires. It includes multiple rigid layers & silicone liner for exceptional shock absorption.
IP68 &IP69K waterproof
Water-resistant, Dustproof, Shockproof
Water or dust never stops your steps. With IP68&IP69K certified rugged BV5900, you have no worries when playing or working under water or any humid environments.
5580mAh Battery, Longer Standby Time
Equipped with 5580mAh large-capacity battery, it ensures you worry-free game playing for long time. Blackview BV5900 smartphone kills your low battery anxiety.
600H
Video
18H
Gaming
12H
Music
45H
Calling
23H
Formidable Processor for Best Experience
MT6761 Quad-core super processor costs less power consumption, guarantees higher performance. With 3GB high speed RAM, the BV5900 runs every task freely and the 32GB ROM is enough for daily used apps. It supports expandable storage up to 32GB.
AndroidTM 9 Sweet Pie Tailored to You
AndroidTM 9 Pie brings Artificial Intelligence to learn your preferences, making the BV5900 smarter and faster. Your experience gets better and better over time.
Life Can be Easier with Wireless NFC
BV5900’s NFC function supports Google Pay. You can make the payment via wireless NFC function. No more bank cards needed. The new, intelligent life!
Prepaid Buss Pass
Electronic Access
Credit Card Payment
High Speed Data
Transmission
Green
Specification
Design
Product BV5900
OS Android 9
Color Black, Green, Orange
Weight 268g
Dimensions 159*80*15 mm
Screen
Panel type IPS
Display Resolution HD+
Screen Size 5.7 inch
Screen Resolution 720*1520
Screen to Body Ratio(%) 86%
Viewing angle (H/V) Full angle
PPI/DPI 294
Connectivity
WIFI 802.11 a/b/g/n (5G)
Bluetooth BT4.2
Europe Version:
2G B2(1900), B3(1800), B5(850), B8(900)
3G B1(2100), B8(900)
4G FDD: B1(2100), B3(1800), B7(2600), B8(900), B20(800);
TDD: B40(2300);
Hardware
CPU MT6761
CPU Clock 2.0GHz
GPU IMG GE8300@420/660MHZ
RAM 3GB
RAM Type LPDDR3
ROM 32GB
ROM Type EMMC
TF Card Slot Support
Max TF Card Capacity 32GB
USB TYPE-C(24PIN)
Camera
Front Camera 5.0MP
Front Camera Sensor GC5025
Front Camera Aperture f2.2
Front Flash NO
Rear Camera 13.0MP + 0.3MP
Rear Camera Sensor IMX214 + GC0310
Rear Camera Aperture f2.2 + f2.8
Rear Flash YES
Power
Battery Capacity 5580 mAh
Max Charging Current 5V 2A
Multi-media
Video mp4\3Gp\mov\mkv…
Audio flac\ape\ac…
Image jpeg\png\gif\bmp
Features
Navigation GPS + GLONASS + Beidou + Galileo
Sensors YES
Gesture NO
Gyroscope YES
Magnetic YES
Hall NO
Compass YES
Fingerprint YES
RGB YES
NFC YES
Hotkont NO
Coulomb Counter NO
Wireless Charging NO
Sim-Card Type 2 Nano-SIM
FM YES
OTG YES
Earphones Jack Type 3.5mm
SAR Head: 0.166 W/kg;
Body: 0.866 W/kg;
Accessories
Gift Box x1
User Manual x1
Protective Film Separately x1
Power Adaptor x1
USB Cable x1
Earphones x1
