Blackview AirBuds 5 Pro IPX7 Waterproof True Wireless Stereo Earbuds
Out of stock
✔Hybrid Active Noise Cancellation
✔Triple Microphones Call Noise Reduction
✔Super Punchy Bass
✔IR Proximity Sensor
✔IPX7 Waterproof
AirBuds 5 Pro
Hear the magic without interruptions
Hybrid Active Noise Cancellation 丨 Triple Microphones 丨 Punchy Bass
IR Proximity Sensor
Smart wear detection
5-minute charge
3-hour audio enjoyment
Hybrid ANC &
audio quality compensation
Single ear use
Support wireless
charging
Five sizes of soft tips
5.0
IPX7
waterproof
Five Sizes of Soft Tips
Find the Best Fit for the Best Sound
The size of earbud tips matters when it comes to noise cancellation. AirBuds 5 Pro come with five sizes of soft tips for a custom fit. The result is an exceptional seal for noise cancellation.
12.60mm
Medium
14.20mm
Maximum -
13.40mm
Large -
11.80mm
Small -
11.00mm
Minimum
A Wonderful World without Noise
AirBuds 5 Pro are equipped with the dual-core digital noise reduction chip and the enhanced hybrid active noise cancellation (ANC) technology, which combines feedforward and feedback ANC. With a noise reduction depth of 35 dB, AirBuds 5 Pro eliminate ambient noise and create the most attractive musical landscapes for your mind to wander around in.
Noise Frequency
30Hz-2kHz
Noise Reduction depth
-35 dB
35 dB In-Depth Noise Reduction, Redefine Music Clarity For In-Ear Peace
A Good Partner for Commuters
Metro, bus, street, etc. Free from noise with hybrid active noise cancellation.
Enjoy Quiet Travel Time
Thanks to hybrid active noise cancellation, AirBuds 5 Pro give you a quiet world.
Quiet Sleep-Easy Solution
Listen pure soothing sound with hybrid active noise cancellation. Sleep better and wake up refreshed.
Calls like Face-to-Face Conversations
Triple Microphone Noise Reduction
Thanks to the triple microphone noise reduction technology and air ducts designed specifically for preventing noises of wind, AirBuds 5 Pro capture your voice clearly even in a crowded environment. The result is that calls sound like face-to-face conversations.
Noise
0 dB
Voice
100%
Audio Quality Compensation Just like in a Live Concert
In order to avoid loss of audio quality from noise reduction techniques, AirBuds 5 Pro are equipped with the audio quality compensation algorithm, allowing every note to be restored to its original brilliance.
Graphene-Based Speaker Super Punchy Bass and Fine Details, Always in Opera
The 7mm dynamic coil driver comes with the sensitive graphene-PU composite diaphragm, which is ultra-thin, but strong and flexible enough, helping in delivering punchy bass and fine details. The result is an ultimate listening experience.
composite diaphragm
dynamic coil driver
IR Proximity Sensor
Smart Play and Pause, Never Miss a Beat
Thanks to the IR proximity sensor and the gravity sensor, AirBuds 5 Pro deliver an unparalleled magical listening experience. They automatically stop when you take them out of your ears, seamlessly resume when you put them back.1
removing the earphones
when wearing
Single Ear Use
Each Earbud Has Its Own Brilliance
Connect each earbud to separate devices, and enjoy two different worlds simultaneously.2
5-minute Charge
3-hour Audio Enjoyment
AirBuds 5 Pro have remarkable endurance, delivering 24 hours of battery life together with the charging case, and offering nearly 3 hours of audio enjoyment from only a 5-minute charging for the charging case.
24hrs
of listening time with multiple additional charges in the case.3
4hrs
of listening time on one charge for the earphones.4
3hrs
of listening time from only 5 minutes of charging for the charging case.5
Indicator light description
| * Open the charging case when earphones are in it, put earphones in or take them out to activate the LED battery indicator. | |
| LED | Battery level of earphones |
| stays red on for 2s | 0-15% |
| stays orange for 2s | 15%-90% |
| Stays green for 2s | 90%-100% |
| *Open the charging case when no earphones are in it to activate the LED battery indicator. | |
| LED | Battery level of the charging case |
| stays red for 7s | 0-20% |
| stays orange for 7s | 20%-80% |
| stays green for 7s | 80%-100% |
| Time & LED | Purpose |
long press the button for 3s,
the light flashes white |
pair your smartphone with AirBuds 5 Pro |
long press the button for 10s,
delete previous pairing memory |
* When both earphones are in the charging case, the LED battery indicator indicates the one with lower battery level.
How to Pair Your Smartphone with AirBuds 5 Pro?
Step 1
Turn on switch on Your Smartphone.
Step 2
Long press the button for 3s until the light flashes white.
Step 3
Search for AirBuds 5 Pro on Your Smartphone.
Step 4
Click "AirBuds 5 Pro" and then pair your smartphone with AirBuds 5 Pro.
Support Wireless Charging
More Solutions, More Freedom
AirBuds 5 Pro's charging case comes with a USB Type-C port and you can also charge it simply by putting it on a charging mat. It takes 2 hours to be fully charged with a 1.5W wireless charger.
Ergonomic Design & Scratch-Proof Coating
Always Keep Fit & Every Detail Perfect
Innovative structural design exists purely to serve your all-day comfort. AirBuds 5 Pro have undergone hundreds of rounds of optimization and upgrading to achieve a superb structural design. Additionally, the special coating protects your earphones and charging case from scratches while maintaining a stylish appearance.
Smart Tap Control
It Couldn't Be Easier
Play music, skip songs, pick up/end calls, and turn on/off ANC simply by tapping on AirBuds 5 Pro.
Tap right twice
Play music
Tap right twice
Next song
Tap right twice
Answer / end a call
Tap right three times
active voice assistant
Tap left twice
ANC switch
5.0
Transmission Faster and More stable
Enjoy fast and stable audio transmission powered by 5.0 technology. Thanks to its stable connection and a transmission distance up to 10 meters, you can keep playing music smoothly.
IPX7 Waterproof
No Fear of Rain or Sweat Challenges
AirBuds 5 Pro are professionally designed for IPX7 water resistance. Whether you are in the gym or have an outdoor activity, they are always reliable enough.
| Model | AirBuds 5 Pro |
| Product color | White |
| Driver | 7mm dynamic driver |
| Driver sensitivity | 100dB @1KHz |
| Frequency response range | 20Hz ~ 20kHz |
| Microphone sensitivity | -38 dBV/Pa |
| Wireless range | 10 m |
| Battery type | Rechargeable lithium-ion battery |
| Battery capacity | 25 mAh (headphones) / 480 mAh (charging case) |
| Music play time (50% volume) | ANC on: 3.5h (single charge) / 20h (with charging case) ANC off: 4h (single charge) / 24h (with charging case) |
| Wired charging time | 1.2h(headphones)/1h(charging case) |
| Wireless charging time | 2h (with charging case) |
| Charging port | USB Type-C |
| water resistance (headphones) | IPX7 |
| Weight (Entire device) | 53g |
