AirBuds 1
True Wireless Stereo Headsets
  • Instant setup
    Master-slave switch
  • 5.0
    Operation range 10m
  • Up to 20hrs battery life
    390mAh charging case
  • Tap to operate
    Multifunction control
  • Voice assistant
    Smart control
  • 8mm dynamic coil unit
    DSP noise cancellation
Master-slave switch,
either can be master
Both the left and the right earbud can connect to device independently. Pick up to use. No more signal dropouts. After the first pairing, they can connect automatically to the device next time.
5.0 for faster,
more stable connection
The latest Bluetooth 5.0 chip enables AirBuds 1 to connect automatically in seconds. Twice faster data transfer than the previous generation, low-latency for gaming, better power-saving ability.
Operation range
10m | 360°
Natural, full and rich
sound you can feel
AirBuds 1 earbuds feature a large speaker with a 8mm dynamic coil unit, coupled with DSP noise cancellation technology, offering crystal-clear sound quality.
large speaker dynamic coil unit
A fully charged case provides good protection and storage, and offers up to 20hrs battery life, which can charge the earbuds more than twice. Each charge guarantees 6 hours of listening time.
* 390mAh charging case included
* The actual battery life varies depending on the music type, volume, etct
Your right-hand smart
assistant who listens back
Your voice assistant wakes up to your voice, letting you control your phone without lifting a finger. Adjust the volume or manage your calls while on the move. You talk, your voice assistant listens.
  • Apple
    Siri
  • Google
    Assistant
  • Amazon
    Alexa
Tap to operate,
and control with ease
Operations such as to play/pause music, answer/end a call can be performed by simply tapping the earbuds. Easy control without operating the device.
  • Volume+ / Volume-
    Long tap right/left earbud
  • Play / pause music
    Tap either earbud once
  • Answer / end a call
    Tap either earbud twice
  • Next song / previous song
    Tap right/left earbud twice
  • Reject a call
    Tap either earbud for 2 seconds
  • Activate voice assistant
    Triple-tap either earbud
  • Volume+ / Volume-
  • Reject a call
Comfortable in-ear design for a secure fit
The in-ear design fits the ear canal snugly. Easy to wear and never falls out. Enjoy smooth and uninterrupted sound whether you're running, playing sports or traveling.
  • Lightweight
    & mini
  • Secure
    fit
  • Comfortable
    wearing
