Blackview 18W Charging Dock For Active 7 Rugged Tablet PC
Available in stock (13)
Engineered specifically for the Blackview Active 7, this 18W charging dock delivers rapid power replenishment with intelligent thermal management. The dock's robust design complements your rugged tablet's durability, featuring secure positioning and reliable contact points that withstand frequent use. With 18W output, you'll achieve faster charging cycles compared to standard adapters, minimizing downtime between work sessions. The compact footprint makes it ideal for fieldwork setups, offices, or mobile operations where space is limited. Compatible exclusively with Active 7 models, this dock ensures optimal charging performance while protecting your device's battery longevity through regulated power delivery.
