Blackview BL9000 6.78-Inch 120Hz Display 12+512GB Dimensity 8020 8800mAh Dual-screen 5G Rugged Phone
Available in stock (17)
✔5G 6nm Octa-core MediaTek Dimensity 8020 CPU
✔Power-efficient Secondary Display
✔Dual Harman Kardon Smart-PA Speakers
✔12GB LPDDR4X RAM+512GB UFS 3.1 ROM
✔50MP OIS Anti-shake Rear & 50MP Selfie Cameras
✔Corning® Gorilla® Glass 7 (Victus®)
Blackview BL9000 is a premium rugged phone focused on dual-screen convenience, fast performance, and strong everyday usability. Its most distinctive feature is the Secondary Display, which adds quick access to time, notifications, music control, compass, call handling, and selfies with the rear camera. It also supports 5G, a 120Hz high-refresh display, and NFC, making it stronger for both daily use and mobile productivity. The 8800mAh battery supports long endurance, while 120W Fast Charge greatly reduces charging downtime. With dual Harman Kardon speakers and rugged protection, BL9000 is positioned as a high-end rugged model that balances practicality, performance, and standout dual-screen design.
| Design | |
| Product | BL9000 |
| OS | DokeOS4.0 Based on Android 13 |
| Color | Black, Gold |
| Weight | 413g |
| Dimensions | 179.5*82.6*17mm |
| Screen | |
| Main Display | |
| LCD panel | BOE |
| IC | ILI7807S |
| Panel Type | IPS |
| Display Resolution | FHD+ |
| Screen Size | 6.78 Inch |
| Screen Resolution | 1080*2460 20:9 |
| Screen to Body Ratio (%) | 81% |
| PPI/DPI | PPI: 396 |
| Refresh frequency | 120HZ |
| Glass | Corning® Gorilla® Glass 7(Victus®) |
| Round Secondary Display | |
| Screen Size | 1.32 Inch |
| Screen Resolution | 360*360 |
| Connectivity | |
| WIFI | 802.11a/b/g/n/ac/ax |
| Bluetooth | V5.1 |
| 2G | B2/B3/B5/B8 |
| 3G | WCDMA: B1/B2/B4/B5/B8 CDMA: BC0/BC1/BC10 |
| Hardware | |
| CPU | MediaTek Dimensity 8020 (6nm), Octa-core, Up to 2.6GHz |
| CPU Clock | ARM Cortex-A78 cores @ 2.6GHz*4, ARM Cortex-A55 cores @ 2.0GHz*4 |
| GPU | ARM G77 MC9 836MHz |
| RAM | 12GB |
| RAM Type | LPDDR4X |
| ROM | 512GB |
| ROM Type | UFS3.1 |
| TF Card Slot | NO |
| USB | TYPE-C (USB 3.0) |
| Camera | |
| Front Camera | 50MP |
| Front Camera Sensor | SK Hynix 5022Q |
| Front Camera Aperture | f2.45 |
| Rear Camera | 50MP main camera 13MP 120° Ultra-wide & up to 2cm Ultra-macro Camera |
| Rear Camera Sensor | Samsung® ISOCELL GN5 + Hi-1336 |
| Rear Camera Aperture | f1.88/f2.2 |
| Rear Flash | Yes |
| Video | 4K Video Recording with Beauty Mode |
| Power | |
| Battery Capacity | 8800mAh, 120W Super-fast Charge |
| Max Charging Current | 6A |
| Multi-media | |
| Video | 3pg\mp4\avi\3gp\3g2\3gpp... |
| Audio | mpeg\3gpp\raw\wma\alac... |
| Image | jpeg\png\gif... |
| Features | |
| Navigation | GPS+GLONASS+Beidou+Galileo |
| Motor | Flat motor |
| Sensors | G/P/L-sensor |
| Gyroscope | YES |
| Magnetic | YES |
| Air pressure sensor | YES |
| Hall | NO |
| Compass | YES |
| Fingerprint | YES |
| RGB | YES |
| NFC | YES |
| Hotkont | NO |
| Coulomb Counter | YES |
| Wireless Charging | NO |
| FM | YES |
| OTG | YES |
| Accessories | |
| User Manual | x1 |
| USB Cable | x1 |
