Blackview BL8800 Pro 6.58" 8+128GB 8380mAh 33W Fast Charge Thermal Imaging 5G Rugged Phone
Out of stock
✔MediaTek Dimensity 700 5G
✔FLIR® Lepton® 2.5 Thermal Imaging Camera
✔IP68&IP69K MIL-STD-810H
✔Glove Mode
✔8380mAh Battery w/ 33w Fast Charge
The Blackview BL8800 Pro is built for inspections, field work, and outdoor troubleshooting, helping you see what ordinary cameras can’t. Its thermal imaging capability makes it easier to detect heat loss, overheating equipment, and hidden targets in low visibility. With 5G connectivity, rugged durability, and a long-lasting battery, BL8800 Pro keeps you connected, prepared, and productive through demanding days outside.
| Design | |
| Product | BL8800 Pro |
| OS | Doke-OS 3.0 ( Based on Android 11) |
| Color | Black, Orange, Green |
| Weight | 367g |
| Dimensions | 176.2*83.5*17.7mm |
| Screen | |
| LCD panel | JDI |
| IC | FT8720-AA |
| Panel Type | IPS |
| Display Resolution | FHD+ |
| Screen Size | 6.58 Inch |
| Screen Resolution | 1080*2408 18:8 |
| Screen to Body Ratio (%) | 85% |
| PPI/DPI | PPI: 400, DPI: 480 |
| Glass | CSG |
| Connectivity | |
| WIFI | 802.11a/b/g/n/ac |
| Bluetooth | V5.1 |
| 2G | 2/3/5/8 |
| Hardware | |
| CPU | Dimensity 700(MT6833) Octa Core |
| CPU Clock | 2*2.2GHz Cortex-A76 6*2.0GHz Cortex-A55 |
| GPU | ARM Mali Natt MC2 |
| RAM | 8GB |
| RAM Type | LPDDR4X |
| ROM | 128GB |
| ROM Type | UFS2.1 |
| TF Card Slot | NO |
| Max TF Card Capacity | NO |
| USB | 24pin TYPE-C |
| Camera | |
| Front Camera | 16MP |
| Front Camera Sensor | S5K3P9-SP |
| Front Camera Aperture | f2.0 |
| Rear Camera | 50MP main camera 5MP thermal assisted camera 2 x 2MP depth camera FLIR® Lepton® 2.5 thermal imaging camera |
| Rear Camera Sensor | S5KJN1SQ03-FGX9+GC5035+GC032A |
| Rear Camera Aperture | f1.8+f2.2 |
| Rear Flash | Dual LED flash |
| Video | 2K video recording |
| Power | |
| Battery Capacity | 8380mAh |
| Max Charging Current | 9v 3A |
| Multi-media | |
| Video | mp4\3Gp\3gpp\avi\x-flv... |
| Audio | ogg\aac\imy\amr\x-flac\mp3... |
| Image | jpeg\png\gif\bmp |
| Features | |
| Navigation | GPS+GLONASS+Beidou+Galileo |
| Motor | Flat motor 0830 |
| Sensors | YES |
| Gyroscope | YES |
| Magnetic | YES |
| Air pressure sensor | YES |
| Hall | NO |
| Compass | YES |
| Fingerprint | YES |
| RGB | YES |
| NFC | YES |
| Hotkont | NO |
| Coulomb Counter | YES |
| Wireless Charging | NO |
| FM | YES |
| OTG | YES |
| Accessories | |
| User Manual | x1 |
| Protective Film Separately | x1 |
| USB Cable | x1 |
