Blackview AuraBass 2 IPX7 Waterproof & Drop-Resistant Mini Outdoor Portable Bluetooth Stereo Speaker
✔Massive 52mm Speaker Driver
✔ IPX7 Waterproof & Rugged 1.2m Drop-Resistant
✔Powerful 1800mAh Battery
✔Built-in Mic with Smart Noise Reduction
✔RGB Beat-Synced Lights
The Blackview AuraBass 2 is a compact outdoor Bluetooth speaker built to bring bigger sound anywhere you go. Its massive 52mm driver, 10W RMS output, and 77dB signal-to-noise ratio deliver deep bass, clear treble, and less distortion for music, podcasts, calls, and outdoor fun. Bluetooth 5.3 keeps pairing fast and stable, while TWS support lets you connect two speakers for wider stereo sound. With a 1800mAh battery, IPX7 waterproof protection, 1.2m drop resistance, RGB beat-synced lights, USB-C charging, and a built-in mic, it is ready for travel, parties, and everyday listening.
AuraBass 2 Your Ultimate Audio Upgrade
No.1Unmatched Supreme Audio Experience — Feel Every Beat Like Never Before
No.2Ultra-Compact, Marathon Battery Life — Take Powerful Sound Anywhere You Go
No.3Tough Beyond Limits — Waterproof and Drop-Resistant for Fearless Outdoor Use
No.4Optimal Smart Convenience — Easier Intuitive Control at Your Fingertips
-to-Noise Ratio No Buzz. Just Beats
AuraBass 2 minimizes distortion and keeps your audio crisp, making it perfect for quiet rooms, podcasts, or detail-rich music. Hear only what matters.
Theater-Like Stereo Setup —— Surround Yourself with Cinematic Sound
Immersive Gaming Audio —— Hear Every Shot, Own Every Fight
15% Longer Battery Life
2 x Stable Connection
10m+ Wireless Range
Party Anywhere
Rhythm Under the Stars
Me Time
Size: 84 x 84 x 92.7mm Easy-Carry
Weight: 253g
One-hand carry, music anywhere
Clip on your pack, go hands-free
Mounted on your bike rack,
music rolls with you
performance may vary based on real-world usage conditions.
Drop-Resistant Firm and Fine, Drops Decline Fragile speakers can’t keep up with real life. This durable shell shrugs off bumps, drops, and daily wear, keeping your music safe and sounding great—whether you’re at home, on the road, or outdoors.
- Power
- Vol -
- Vol +
- Play/Pause
- Vol- and Vol+
- Short Press
- Switch EQ Mode
- Decrease Volume
- Increase Volume
- Play/Pause Answer a Phone/Hangup
- RGB on/off
- Long Press
- Power on/off
- Previous Song
- Next Song
- Refuse Calls TWS Connection Reset BT Pairing
- Prompt Volume Switch
- Double Click
- Connect/Disconnect BT
- Redial the Last Call
Blackview AuraBass 2 Specifications
- Model
- Color
- Dimensions
- Weight
- Battery Capacity
- Bluetooth Version
- Playback Mode
- True Wireless Stereo (TWS)
- Waterproof Rating
- Output Power
- Speaker Configuration
- Signal-to-Noise Ratio
- Microphone
- AuraBass 2
- Black
- 84 x 84 x 92.7mm
- 253g
- 1800mAh
- V5.3
- BT
- Yes
- IPX7
- 10W RMS,15W Peak Output
- 4Ω10W
- 77dB
- Yes
| Design | |
| Product | Blackview AuraBass 2 |
| Product Type | Mini Outdoor Portable Bluetooth Stereo Speaker |
| Color | Black |
| Dimensions | 84 × 84 × 92.7 mm |
| Weight | 253 g |
| Audio | |
| Driver | 52mm speaker driver |
| Output Power | 10W RMS, 15W peak output |
| Speaker Configuration | 4Ω 10W |
| Signal-to-Noise Ratio | 77dB |
| EQ | Dual-mode EQ, indoor / outdoor |
| Audio Tuning | Smart DSP + EQ tuning |
| Stereo Pairing | TWS pairing support |
| Battery & Charging | |
| Battery | 1800mAh |
| Charging Port | USB-C |
| Auto Shut Off | 10 minutes with no connection, 30 minutes when connected but not playing |
| Connectivity | |
| Bluetooth | BT 5.3 |
| Playback Mode | BT |
| Wireless Range | 10m+ |
| Auto Reconnection | Supported |
| Wide Compatibility | Phone, tablet, laptop, and PC |
| Durability | |
| Water Resistance Rating | IPX7 |
| Drop Resistance | 1.2m drop-resistant |
| Shell Protection | Waterproof and drop-resistant outdoor shell |
| Lighting | |
| RGB Light | RGB beat-synced lights |
| Microphone & Controls | |
| Microphone | Built-in mic with smart noise reduction |
| Button Control | Power, volume, play / pause, call control, EQ mode switch, RGB on / off, TWS connection, BT pairing reset |
| Extra Features | |
| Use Case | Outdoor listening, parties, hiking, strolling, climbing, cycling, poolside use, bathroom tunes, and everyday music playback |
| Other Features | Portable lanyard design, RGB beat lighting, hands-free calls, TWS pairing, smart auto shut off, USB-C charging, and Bluetooth auto reconnection |
