Blackview AirBuds 9 Smart LED Power Display PNC Noise Reduction Sleep Mode In-ear TWS Earbuds
Hurry up, only 7 items left in stock.
✔2.83g Weightless Comfort In-ear Design
✔Tailored Sleep Mode
✔Latest Bluetooth 5.4
✔400mAh Mega Battery
Blackview AirBuds 9 is made for users who want lightweight, comfortable earbuds for everyday personal listening. With each earbud weighing just 2.83g, it offers an easy, low-pressure fit for bedtime listening, relaxing at home, casual commuting, and daily entertainment. PNC noise reduction helps create a more focused listening experience for music, podcasts, and videos, while BT 5.4 delivers a smoother wireless connection for phones and tablets. The 400mAh charging case supports convenient daily use, and the smart LED power display makes it easy to check battery levels before heading out. For users who value light wear, simple controls, clear battery visibility, and comfortable everyday sound, AirBuds 9 is a practical entry-level choice.
| Model & Design | |
| Model | AirBuds 9 |
| Color | Phantom Black, Beige White |
| Weight | 2.83g (per earbud), 30.36g (charging case) |
| Audio & Performance | |
| Driver Unit | 6mm Dynamic Driver |
| Frequency Response | 20Hz ~ 20KHz |
| Audio Codec | SBC, AAC |
| Connectivity & Battery | |
| BT Version | 5.4 |
| Connection Range | >10m |
| Battery Capacity | 30mAh (earbud), 400mAh (charging case) |
| Charging Time | 1.5hrs (earbud), 1.75hrs (charging case) |
| Charging Port | Type-C |
