Blackview AirBuds 30 IPX7 Waterproof Bluetooth 5.4 In-ear TWS Earbuds
• 10mm dynamic driver for rich audio
• Advanced Bluetooth 5.4 for stable link
• 30-hour total battery for all-day use
• Lightweight 3.79g design for comfort
• IPX7 water-resistant for workouts
• Fast USB-C charging for convenience
Blackview AirBuds 30 is made for users who want affordable earbuds that go beyond everyday listening. From office calls and business trips to workouts, movies, travel, and remote conversations, it fits smoothly into busy daily routines. Its standout feature is AI real-time translation with support for 134 languages, making it especially useful for global meetings, overseas travel, language learning, and conversations across borders. At the same time, IPX7 waterproofing, up to 30 hours of total playback, and a lightweight design keep it practical for commuting, exercise, and casual listening. For users who want simple daily earbuds with a clear advantage in portable communication, AirBuds 30 offers strong value with a smart global-ready edge.
AirBuds 30
Communication without Barriers
to Break Down Language Barriers
Translate Right in Your Ear
Conquer Global Meetings, Language No Longer a Barrier
Travel the World, Language Won’t Hold You Back
Smooth Everyday Conversations with International Friends
Remote Communication, Just Like Being There
Your Personal Language Learning Companion
Delve into Immersive Movies When Watching at Home
35mAh
Respond in a Scroll
Single Tap
Double Tap
Triple Tap
Previous Track
Next Track
( 2 seconds)
a Voice Assistant Press and Hold, Assistant Awake
50Mbps
Faster Data Transfer Speed -
0.06s
Lower Communication Latency -
Stronger
Anti-interference Capabilities -
Faster
Connection Speed -
Lower
Power Consumption -
More Stable
Even in Crowded Areas with Heavy BT Usage
More Stable
During a Business Trip
with Clients in the Office
Silicone Ear Tips Solid Fit and Comfort for All
35mAh
Respond in a Scroll
Single Tap
Double Tap
Triple Tap
( 2 seconds)
Assistant Awake By simply pressing and holding the right earbud for 2 seconds, you can instantly summon your favorite voice assistant like Siri, Google Assistant, or Alexa. An effortless way to stay connected and productive while on the go.
50Mbps
0.06s
Stronger
Faster
Connection Speed -
Lower
Power Consumption -
More Stable
Faster,Stronger,
More Stable
| Model & Design | |
| Model | AirBuds 30 |
| Color | Ceramic White, Carbon Black |
| Weight | 3.79g (per earbud), 35.01g (charging case) |
| Audio & Performance | |
| Driver Unit | 10mm Dynamic Driver |
| Frequency Response | 20Hz ~ 20KHz |
| Audio Codec | SBC, AAC |
| Water Resistance | IPX7 |
| Connectivity & Battery | |
| Bluetooth Version | 5.4 |
| Connection Range | >10m |
| Battery Life | 6hrs (single), 30hrs (with case) |
| Charging Time | 1.5hrs (earbuds), 2hrs (case) |
| Charging Port | USB-C |
