AirBuds K1
Joy in Every Beat
Safe in Every Sound
AirBuds K1
AirBuds K1
AirBuds K1
Safety First, Designed for Young Ears
AirBuds K1 is thoughtfully designed for how children learn and listen every day. From online classes to quiet moments at home, it delivers comfort, stability, and safe daily listening giving parents confidence and helping kids stay focused.
Turn the Mood. Hear the Joy
Rotatable Mood-Switch Design Designed to bring a playful twist to everyday listening, AirBuds K1 features three expressive moods and a rotatable space capsule case that switches looks with a simple turn. Interactive yet distraction-free, it’s made to enjoy every day.
AirBuds K1
Happy
Trary
Playfully
Unimpressed
AirBuds K1
Clip Light. Stay Tight.
Soft & Secure Ear-Clip Fit At only 3.5g per earbud, AirBuds K1 stays light all day—at home, on the go, or during play. The soft silicone clip gently rests on the ear, offering a secure fit without squeezing or discomfort.
AirBuds K1
Clear Voices.
Lively Music.
All Balanced.
Carefully Tuned 12mm Driver Featuring a carefully tuned 12mm driver AirBuds K1 delivers rich, balanced sound that brings music and voices to life. Smooth and easy on young ears, it’s perfect for music, videos, and everyday moments.
AirBuds K1
Speak Clearly.
Be Heard Instantly
Clear Voice Calls With a built-in microphone, AirBuds K1 ensures clear voice pickup for everyday conversations. Whether chatting with friends or calling family kids can speak clearly and be heard without removing the earbuds.
AirBuds K1
Fast to Connect.
Stable All Day.
Wireless BT 6.0
With Wireless BT 6.0, AirBuds K1 delivers a fast and stable connection up to 10 meters. It is compatible with smartphones, tablets, and other wireless-enabled devices, pairing quickly and keeping music, videos, and calls smooth and uninterrupted.
Connect Across All Your Devices
AirBuds K1
Smartphones
AirBuds K1
Tablets
AirBuds K1
Laptops
AirBuds K1
Wireless-Enabled Devices
Tap. Hold. Control with Ease
Intuitive Smart Touch Controls
Take control with a simple touch. AirBuds K1 features intuitive touch controls designed for young users. Tap or press and hold to play or pause music, skip tracks, manage calls, or activate the voice assistant with ease.
AirBuds K1
AirBuds K1
Play / Pause
Double tap Left or Right Touch Area
AirBuds K1
Next Track
Triple tap Right Touch Area
AirBuds K1
Previous Track
Triple tap Left Touch Area
AirBuds K1
Answer Call
Touch Area
AirBuds K1
End Call
AirBuds K1
Reject Call
Press and hold Left or Right
Touch Area for 2 seconds
AirBuds K1
Activate Voice Assistan
Press & Hold (L/R) for 2s, then release
AirBuds K1
Listen. Talk. Keep Going
300mAh Charging Case + 30mAh Earbuds (Each) Designed to last throughout the day, AirBuds K1 delivers dependable battery life for music, calls, and everything in between.
Up to 5 Hours
on a Single Charge
Up to 22 Hours
Total Playback with Charging Case
AirBuds K1
Drop In. Power Up. Go.
Fast & Convenient Charging
The charging case enables quick and convenient recharging—simple enough for kids to manage independently. Earbuds recharge automatically when placed in the case, and the charging case fully recharges in approximately 1.5 hours via Type-C.
AirBuds K1
Drop In to Recharge
AirBuds K1
~1.5h to Full Power
AirBuds K1
Type-C for Easy Charging
*Battery life tested at 70% volume. Actual results may vary depending on usage conditions.
AirBuds K1
Carry it. Clip it. Keep it Close
A built-in lanyard makes the charging case easy to clip onto backpacks, bags, or everyday gear. Secure and convenient, it helps keep earbuds close and reduces the chance of misplacement throughout the day.
AirBuds K1
Keep Moving.
Stay Protected
Splash-ready with IPX4 protection, AirBuds K1 stands up to sweat and everyday splashes with ease.
Ready for
Every Adventure
Lightweight yet tough, AirBuds K1 is built to handle everyday movement and small drops, making it reliable for playtime, travel, and daily use.
AirBuds K1
AirBuds K1
Blackview AirBuds K1 Specifications
Model AirBuds K1
Color Cheeky Blue, Blushy Pink
Dimensions Earbuds(Each): 25.45*14.9*25 mm
Charging Case: 54.1*52*45.2 mm
Weight Earbud(Each): 3.5g
Charging Case: 43g
Dynamic Driver 12mm
Frequency Response Range 20 Hz – 20 kHz
Audio Code SBC, AAC
Battery Capacity Earbuds: 30mAh (per earbud)
Charging Case: 300mAh
Charging Port Type-C
Wireless BT Version Wireless BT 6.0
Connection Range Up to 10 m (open space)
Water Resistance Rating IPX4 (sweat & splash resistant)
