Blackview AirBuds 300 IPX5 Waterproof Smart Digital Power Display ENC Noise Cancellation Microphone Bluetooth 6.0 Open-ear OWS Earbuds
Available in stock (12)
✔Open-Ear Design with Ergonomic Ear Hook
✔ IPX5 Waterproof Rating
✔500mAh Battery & Smart LED Power Display
✔Next-Gen Bluetooth 6.0, Android & iOS & HarmonyOS Compatible
Blackview AirBuds 300 is built for everyday movement, clear calls, and all-day listening. Whether you’re commuting, working out, taking remote meetings, or moving through busy city streets, it keeps you connected with practical audio performance. Dual ENC microphones help make calls clearer in traffic, public spaces, and quick work conversations. With up to 28 hours of total battery life and a 10-minute quick charge for up to 2 hours of call time, AirBuds 300 is ready when your day gets busy. The digital power display makes battery levels easy to check, while IPX5 water resistance adds confidence for sweat, light rain, and active use. For users who want reliable earbuds with strong call performance, long battery life, and everyday convenience, AirBuds 300 is a smart, affordable choice.
| Design | |
| Model | AirBuds 300 |
| Color | Obsidian Black, Moonstone Beige |
| Weight |
Earbuds: 19g Charging Case: 58.5g |
| Audio | |
| Driver Unit | 18.2 × 11.2 mm |
| Frequency Response Range | 20Hz ~ 20KHz |
| Audio Decoding | AAC / SBC |
| Connectivity | |
| BT Version | BT 6.0 |
| Connection Range | >15m |
| Charging Port | Type-C |
| Battery | |
| Battery Capacity |
Earbuds: 65mAh Charging Case: 500mAh |
| Charging Time |
Earbuds: 1.5H Charging Case: 2H |
| Protection | |
| Water Resistance Rating | IPX5 |
