Blackview AirBuds 20 IPX7 Waterproof Bluetooth 5.4 Half-in-ear TWS Earbuds
Available in stock (15)
• 13mm dynamic driver for powerful sound
• Advanced BT 5.4 for seamless connection
• Ultra-lightweight build at only 6.3g
• IPX7 water-resistant for active use
• 6.5-hour playback on a single charge
• Quick USB Type-C charging for convenience
Blackview AirBuds 20 is made for users who want lightweight earbuds that can keep up with active everyday life. Comfortable, easy to control, and resistant to rain and sweat, it’s a practical fit for walking, workouts, commuting, and all-day listening. With DNS noise reduction, AirBuds 20 helps improve call and audio clarity in busier environments. IPX7 water resistance adds extra confidence for sports, sweat, light rain, and daily outdoor movement. Up to 6.5 hours of listening on a single charge and 29 hours total battery life make it easy to stay powered through the day. Quick-charge support helps when you need a fast boost before heading out, while the lightweight design reduces pressure during longer wear. For users who value comfort, water resistance, dependable battery life, and simple daily convenience, AirBuds 20 is a smart, affordable choice.
| Model & Design | |
| Model | AirBuds 20 |
| Color | Carbon Black, Ceramic White, Lilac Purple |
| Weight | 28g (case), 6.3g (earbuds) |
| Audio & Performance | |
| Driver | 13mm Dynamic Driver |
| Frequency Response | 20Hz ~ 20KHz |
| Audio Codec | SBC, AAC |
| Water Resistance | IPX7 (earbuds) |
| Connectivity & Battery | |
| Bluetooth Version | BT 5.4 |
| Battery Capacity | 400mAh (case) |
| Music Play Time | 6.5 hours (50% volume) |
| Charging Time | Earbuds: 1h 10m, Case: 1h 45m |
| Charging Port | USB Type-C |
