Blackview AirBuds 20 IPX7 Waterproof Bluetooth 5.4 Half-in-ear TWS Earbuds
Available in stock (23)
• 13mm dynamic driver for powerful sound
• Advanced BT 5.4 for seamless connection
• Ultra-lightweight build at only 6.3g
• IPX7 water-resistant for active use
• 6.5-hour playback on a single charge
• Quick USB Type-C charging for convenience
Blackview AirBuds 20 is made for users who want lightweight earbuds that can keep up with active everyday life. Comfortable, easy to control, and resistant to rain and sweat, it’s a practical fit for walking, workouts, commuting, and all-day listening. With DNS noise reduction, AirBuds 20 helps improve call and audio clarity in busier environments. IPX7 water resistance adds extra confidence for sports, sweat, light rain, and daily outdoor movement. Up to 6.5 hours of listening on a single charge and 29 hours total battery life make it easy to stay powered through the day. Quick-charge support helps when you need a fast boost before heading out, while the lightweight design reduces pressure during longer wear. For users who value comfort, water resistance, dependable battery life, and simple daily convenience, AirBuds 20 is a smart, affordable choice.
AirBuds 20
Light as Air, Perfect for
Every Moment
13mm Dynamic Driver
400mAh Large
Battery
DNS Noise Reduction
Ergonomic &
Secure Fit
Half-in-ear
Design
IPX7
Waterproof
Single Earbud
Weighing
Only 3.1g
Smart Touch Control
Clear Sound &
HQ Bass
The Latest BT 5.4
AirBuds 20
Carbon Black
AirBuds 20
Ceramic White
AirBuds 20
Lilac Purple
Comfortable Half-In-Ear Design,
Safe and Pressure-Free
AirBuds 20 features a lightweight half-in-ear structure that eliminates ear pressure and discomfort. This design allows you to hear external sounds clearly, ensuring safety whether you're walking in busy streets or working out.
Metal Dust Cover for Reliable Protection and Easy Cleaning
AirBuds 20 features a metal dust cover that effectively prevents debris from entering the earbuds, makes surface cleaning easy, and resists sweat corrosion, ensuring long-lasting reliability and performance.
Casual Fashion Design
Durable, Lightweight, Eco-Friendly
Crafted with high-quality ABS material, AirBuds 20 is durable and impact-resistant, yet lightweight and comfortable for extended wear. The eco-friendly, recyclable material ensures you enjoy superior sound quality while contributing to a healthier planet.
400mAh Large Battery
Large Capacity Battery, Long-lasting Performance
AirBuds 20 features a 400mAh battery, providing up to 6.5 hours of music playback on a single full charge. With the charging case, you get a total of 29 hours of endurance, offering 3.5 additional charges for earbuds.
Charge for just 10 minutes, enjoy 60 minutes of music—instant power, endless enjoyment!
*The actual battery life varies depending on music type, volume, connected devices, etc
13mm Self-Developed Dynamic Driver
Crystal-Clear sound with Deep, Elastic Bass and Crisp Treble
The special 3-layer composite diaphragm ensures deep, elastic bass while maintaining clear and natural vocals and crisp, bright treble. Even at high power levels, enjoy distortion-free sound for a truly immersive listening experience.
Sound Clarity, Anywhere You Go
Featuring our self-developed, patented MIC isolation structure, AirBuds 20 delivers exceptional noise reduction with a DNS communication algorithm. This advanced design effectively cancels out ambient noise by up to -20 dB, ensuring crystal-clear sound for calls and music, even in noisy environments.
The Latest Bluetooth 5.4
Faster Connections, Enhanced Stability
Airbuds 20,equipped with the latest BT 5.4, offers faster connections,enhanced stability, lower latency, and improved security for an unparalleled audio experience.
IPX7 Protection, Rain or Shine
AirBuds 20 with lPX7 protection resist rain,sweat,and splashes.Perfect for sports, outdoor activities, and everyday use,ensuring reliable performance without the fear of water damage.
Pair Once, Connect Always
Effortless Auto-Connection
Simply open the charging case and the AirBuds 20 will automatically power on. After the initial pairing with your phone, they’ll seamlessly reconnect every time. No need to pair again—just pop them in and go!
Effortless Touch Control
Airbuds 20 responds to your light taps, giving you precise control with every touch.
Perfect for Android, iOS, and HarmonyOS
Entertainment Anywhere, Any Device
AirBuds 20 seamlessly supports Android, iOS, and HarmonyOS devices. Enjoy a variety of entertainment experiences whether you're using a tablet, computer, or smartphone.
| Model | AirBuds 20 |
| Weight | 28g(charging case)/6.3g (earbuds) |
| Color | Carbon Black/Ceramic White/Lilac Purple |
| Driver | 13mm dynamic driver |
| Frequency Response Range | 20Hz~20KHz |
| Bluetooth Version | BT 5.4 |
| Audio Codec | SBC, AAC |
| Battery Capacity | 400mAh |
| Music Play Time (single full charge) | 6.5 hours(50% volume) |
| Charging Time | 1h10mins (earbuds)/1h45mins(charging case) |
| Charging Port | USB Type-C |
| Water Resistance | IPX7 (earbuds) |
| Model & Design | |
| Color | Carbon Black, Ceramic White, Lilac Purple |
| Weight | 28g (case), 6.3g (earbuds) |
| Audio & Performance | |
| Driver | 13mm Dynamic Driver |
| Frequency Response | 20Hz ~ 20KHz |
| Connectivity & Battery | |
| Battery Capacity | 400mAh (case) |
| Music Play Time | 6.5 hours (50% volume) |
| Charging Time | Earbuds: 1h 10m, Case: 1h 45m |
