Blackview AirBuds 16 IPX4 Waterproof In-ear TWS Earbuds
Hurry up, only 9 items left in stock.
✔IPX4 Water Resistance
✔2.8g Ultra-light & Ergonomic Fit Design
✔470mAh Charging Case + 35mAh Earbuds (Each)
✔Wireless Bluetooth 6.0
The Blackview AirBuds 16 are made for everyday listening, commuting, workouts, and hands-free calls. With a 13mm dynamic driver and Wireless BT 6.0, they deliver an easy, reliable sound experience without extra setup. Up to 30 hours total playback with a 470mAh case helps you move through the day, while IPX4 splash resistance adds confidence during sweat, light rain, or outdoor use. Comfort-focused design, simple charging, and broad device compatibility make them a practical pick for music, podcasts, video calls, and casual travel.
| Design | |
| Product | Blackview AirBuds 16 |
| Color | Black |
| Battery & Charging | |
| Charging Case Dimensions | 65.97 × 37.79 × 26.38 mm |
| Charging Case Weight | 30.97g ± 1g |
| Earbud Battery | 35mAh per earbud |
| Charging Case Battery | 470mAh |
| Charging Port | Type-C |
| Audio | |
| Driver | 13mm |
| Frequency Response | 100Hz–10KHz |
| Audio Codec | AAC / SBC |
| Durability | |
| Water Resistance Rating | IPX4 |
| Connectivity | |
| Connection Range | Up to 10m |
| Extra Features | |
| Earbud Dimensions | 21.25 × 16.8 × 18.26 mm |
| Earbud Weight | 2.8g ± 0.2g each |
| Wireless Version | Wireless BT 6.0 |
