Blackview AirBuds 15 IPX5 Waterproof LED Display Bluetooth 6.0 Clip-on OWS Earbuds
Hurry up, only 10 items left in stock.
✔IPX5-Level Water Resistance
✔5.6g Ultra-lightweight & Clip-on Design
✔400mAh Charging Case & 50mAh Earbuds (each)
✔Next-Gen Bluetooth 6.0, Android & iOS & HarmonyOS Compatible
The Blackview AirBuds 15 are made for everyday listening, commuting, workouts, and hands-free calls. With a 13mm titanium-coated driver and Wireless BT 6.0, they deliver an easy, reliable sound experience without extra setup. up to 35 hours total playback with a 400mAh case helps you move through the day, while IPX5 water resistance adds confidence during sweat, light rain, or outdoor use. Comfort-focused design, simple charging, and broad device compatibility make them a practical pick for music, podcasts, video calls, and casual travel.
Light to Wear. Deeper to Feel
Connect Faster. Last Longer.
Style Your Way.
Customize Your Look
Accessorize Freely
5.6g Feather-Light
Flexible AirFit
Open-Ring Design
Φ13mm Titanium-
Coated Driver
Dual Microphones
with ENC
Noise
Reduction
Type-C Fast Charging
10-min charge = 1-hr talk
Next-Gen Wireless
BT 6.0
2× Faster↑
Transmission Speed,
1.5×↑ Longer
Transmission Range
Built-in
Hall switch
Pop It Open.
Power On
LED Display
400 mAh Charging Case &
50 mAh Earbuds (each)
Up to 35 hours of
total playback
Tailored for Android, iOS,
and HarmonyOS
IPX5-Level Water
Resistance
Clip On. Tune In. Zone Out
Customize Your Look — Accessorize Freely
Feel the Fit. Hear with Freedom. AirBuds 15 fuses clip-on comfort with sound privacy, delivering lossless clarity and a secure, waterproof fit that’s uniquely yours.
Zero Pressure, All Comfort.
Flexible AirFit Open-Ring Design
Crafted with soft TPE memory wire and ultra-light materials, the AirFit open-ring design of AirBuds 15 adapts comfortably to every ear shape and relieves pressure evenly. Move freely, wear effortlessly—comfort that lasts all day.
5.6g
Feather-Light
Let the Music Take You In
Φ13mm Titanium-Coated Driver
Feel the Depth. Hear the Detail. With its 13mm titanium-coated driver, AirBuds 15 delivers deeper bass, brighter highs, and studio-level clarity in every beat.
Hear Clearly. Speak Freely
Dual Microphones with ENC Noise Reduction
With dual microphones and ENC noise reduction, AirBuds 15 picks up your voice clearly and cuts through background sound—so every call stays crystal clear, wherever you are.
No Drops. No Delays.Just Flow
Next-Gen Wireless BT 6.0
With next-gen wireless BT 6.0, AirBuds 15 connects instantly and stays steady no matter the move. Feel the speed, the stability, and the pure freedom of lossless sound in every moment.
2× Faster↑
Transmission Speed
30% Lower↓
Power Consumption
1.5×↑ Longer
Transmission Range
15-Meter
Wireless Range
Pop It Open. Power On
Built-in Hall switch
Pop it open and you’re instantly connected. Thanks to its built-in Hall switch, AirBuds 15 turns on and pairs automatically, then powers down when closed—smart, fast, and always ready.
Always Ready. Always With You
400 mAh Charging Case & 50 mAh Earbuds (each)
Powered by a 400mAh charging case and 50mAh earbuds(each), AirBuds 15 delivers up to 10 hours of playtime on a single charge and 35 hours in total. With energy-efficient tuning and over 6 months of standby, it’s always ready when you are.
Built for the Longer Run
AirBuds 15
500 Full Charge Cycles
Others
300 Full Charge Cycles
Up to 1.6× Longer Battery Lifespan
Fuel Up Fast.
Stay Unstoppable
In a rush? A 10-minute charge keeps the conversation going for 1 hour—AirBuds 15, always ready when you are.
10-min Charge = 1-hr Talk
Stay One Step Ahead
of Every Charge
LED Display
Stay informed at a glance—the LED display on the AirBuds 15 displays real-time battery levels for both the earbuds and the charging case.
Rain or Sweat. Still On Beat
With IPX5-level water resistance, AirBuds 15 stands up to sweat, splashes, and light rain—so your music never stops, wherever life takes you.
Connected in a Second. Seamless All Day
Tailored for Android, iOS, and HarmonyOS
Seamless connectivity wherever you go — Blackview AirBuds 15 pairs instantly with Android, iOS, and HarmonyOS devices, letting you switch between phone, tablet, and laptop with ease.
AirBuds 15 —
Sound Your Every Moment.
From workouts to work calls, AirBuds 15 empowers your every moment with comfort, clarity, and endurance—because every moment deserves its soundtrack.
Shadow Black
Frost White
| Model | AirBuds 15 |
| Dimensions | Earbuds: 21.28 x 28.25 x 22mm Charging case: 53.2 x 71.6 x 31mm |
| Weight | 5.6g±0.2 (per earbud), 39g±0.2 (charging case) |
| Color | Shadow Black, Frost White |
| Driver Unit | Φ13.0mm |
| Frequency Response Range | 50Hz~8KHz |
| Wireless BT Version | V6.0 |
| Audio Code | AAC/SBC |
| Battery Capacity | 50mAh (Per Earbud), 400mAh (Charging Case) |
| Charging Time(0%~100%) | <1.5 hrs (Earbuds) / <2 hrs (Charging Case) |
| Charging Port | Type-C |
| Connection Range | >15m |
| Water Resistance Rating | IPX5 |
| Design | |
| Product | Blackview AirBuds 15 |
| Battery & Charging | |
| Charging Case Dimensions | 53.2 × 71.6 × 31 mm |
| Charging Case Weight | 39g ± 0.2g |
| Earbud Battery | 50mAh per earbud |
| Charging Case Battery | 400mAh |
| Charging Time | <1.5 hrs earbuds / <2 hrs case |
| Audio | |
| Driver | 13mm titanium-coated |
| Frequency Response | 50Hz–8KHz |
| Audio Codec | AAC / SBC |
| Durability | |
| Connectivity | |
| Extra Features | |
| Earbud Dimensions | 21.28 × 28.25 × 22 mm |
| Earbud Weight | 5.6g ± 0.2g each |
| Wireless Version | Wireless BT 6.0 |
