Blackview AirBuds 15 IPX5 Waterproof LED Display Bluetooth 6.0 Clip-on OWS Earbuds
Sale price £38.00 Regular price £53.00
AirBuds 15
Light to Wear. Deeper to Feel
Connect Faster. Last Longer.
Style Your Way.
AirBuds 15
AirBuds 15
Customize Your Look
Accessorize Freely
AirBuds 15
5.6g Feather-Light
AirBuds 15
Flexible AirFit
Open-Ring Design
AirBuds 15
Φ13mm Titanium-
Coated Driver
AirBuds 15
Dual Microphones
with ENC
Noise
Reduction
AirBuds 15
Type-C Fast Charging
10-min charge = 1-hr talk
AirBuds 15
Next-Gen Wireless
BT 6.0
2× Faster↑
Transmission Speed,
1.5×↑ Longer
Transmission Range
AirBuds 15
Built-in
Hall switch
Pop It Open.
Power On
AirBuds 15
LED Display
AirBuds 15
400 mAh Charging Case &
50 mAh Earbuds (each)
Up to 35 hours of
total playback
AirBuds 15
Tailored for Android, iOS,
and HarmonyOS
AirBuds 15
IPX5-Level Water
Resistance
Clip On. Tune In. Zone Out
Customize Your Look — Accessorize Freely
Feel the Fit. Hear with Freedom. AirBuds 15 fuses clip-on comfort with sound privacy, delivering lossless clarity and a secure, waterproof fit that’s uniquely yours.
AirBuds 15
Zero Pressure, All Comfort.
Flexible AirFit Open-Ring Design
Crafted with soft TPE memory wire and ultra-light materials, the AirFit open-ring design of AirBuds 15 adapts comfortably to every ear shape and relieves pressure evenly. Move freely, wear effortlessly—comfort that lasts all day.
AirBuds 15
5.6g
Feather-Light
AirBuds 15
Let the Music Take You In
Φ13mm Titanium-Coated Driver
Feel the Depth. Hear the Detail. With its 13mm titanium-coated driver, AirBuds 15 delivers deeper bass, brighter highs, and studio-level clarity in every beat.
AirBuds 15
Hear Clearly. Speak Freely
Dual Microphones with ENC Noise Reduction
With dual microphones and ENC noise reduction, AirBuds 15 picks up your voice clearly and cuts through background sound—so every call stays crystal clear, wherever you are.
AirBuds 15
No Drops. No Delays.Just Flow
Next-Gen Wireless BT 6.0
With next-gen wireless BT 6.0, AirBuds 15 connects instantly and stays steady no matter the move. Feel the speed, the stability, and the pure freedom of lossless sound in every moment.
2× Faster↑
Transmission Speed
30% Lower↓
Power Consumption
1.5×↑ Longer
Transmission Range
15-Meter
Wireless Range
AirBuds 15
Pop It Open. Power On
Built-in Hall switch
Pop it open and you’re instantly connected. Thanks to its built-in Hall switch, AirBuds 15 turns on and pairs automatically, then powers down when closed—smart, fast, and always ready.
AirBuds 15
Always Ready. Always With You
400 mAh Charging Case & 50 mAh Earbuds (each)
Powered by a 400mAh charging case and 50mAh earbuds(each), AirBuds 15 delivers up to 10 hours of playtime on a single charge and 35 hours in total. With energy-efficient tuning and over 6 months of standby, it’s always ready when you are.
AirBuds 15
Built for the Longer Run
AirBuds 15
AirBuds 15
500 Full Charge Cycles
AirBuds 15
Others
300 Full Charge Cycles
Up to 1.6× Longer Battery Lifespan
Fuel Up Fast.
Stay Unstoppable
In a rush? A 10-minute charge keeps the conversation going for 1 hour—AirBuds 15, always ready when you are.
10-min Charge = 1-hr Talk
AirBuds 15
Stay One Step Ahead
of Every Charge
LED Display
Stay informed at a glance—the LED display on the AirBuds 15 displays real-time battery levels for both the earbuds and the charging case.
AirBuds 15
Rain or Sweat. Still On Beat
IPX5-Level Water Resistance
With IPX5-level water resistance, AirBuds 15 stands up to sweat, splashes, and light rain—so your music never stops, wherever life takes you.
AirBuds 15
Connected in a Second. Seamless All Day
Tailored for Android, iOS, and HarmonyOS
Seamless connectivity wherever you go — Blackview AirBuds 15 pairs instantly with Android, iOS, and HarmonyOS devices, letting you switch between phone, tablet, and laptop with ease.
AirBuds 15
AirBuds 15 —
Sound Your Every Moment.
From workouts to work calls, AirBuds 15 empowers your every moment with comfort, clarity, and endurance—because every moment deserves its soundtrack.
AirBuds 15
AirBuds 15
Shadow Black
AirBuds 15
Frost White
Model AirBuds 15
Dimensions Earbuds: 21.28 x 28.25 x 22mm
Charging case: 53.2 x 71.6 x 31mm
Weight 5.6g±0.2 (per earbud), 39g±0.2 (charging case)
Color Shadow Black, Frost White
Driver Unit Φ13.0mm
Frequency Response Range 50Hz~8KHz
Wireless BT Version V6.0
Audio Code AAC/SBC
Battery Capacity 50mAh (Per Earbud), 400mAh (Charging Case)
Charging Time(0%~100%) <1.5 hrs (Earbuds) / <2 hrs (Charging Case)
Charging Port Type-C
Connection Range >15m
Water Resistance Rating IPX5
