Blackview AirBuds 15 IPX5 Waterproof LED Display Bluetooth 6.0 Clip-on OWS Earbuds
Available in stock (13)
✔IPX5-Level Water Resistance
✔5.6g Ultra-lightweight & Clip-on Design
✔400mAh Charging Case & 50mAh Earbuds (each)
✔Next-Gen Bluetooth 6.0, Android & iOS & HarmonyOS Compatible
The Blackview AirBuds 15 are made for everyday listening, commuting, workouts, and hands-free calls. With a 13mm titanium-coated driver and Wireless BT 6.0, they deliver an easy, reliable sound experience without extra setup. up to 35 hours total playback with a 400mAh case helps you move through the day, while IPX5 water resistance adds confidence during sweat, light rain, or outdoor use. Comfort-focused design, simple charging, and broad device compatibility make them a practical pick for music, podcasts, video calls, and casual travel.
| Design | |
| Product | Blackview AirBuds 15 |
| Color | Shadow Black, Frost White |
| Battery & Charging | |
| Charging Case Dimensions | 53.2 × 71.6 × 31 mm |
| Charging Case Weight | 39g ± 0.2g |
| Earbud Battery | 50mAh per earbud |
| Charging Case Battery | 400mAh |
| Charging Time | <1.5 hrs earbuds / <2 hrs case |
| Charging Port | Type-C |
| Audio | |
| Driver | 13mm titanium-coated |
| Frequency Response | 50Hz–8KHz |
| Audio Codec | AAC / SBC |
| Durability | |
| Water Resistance Rating | IPX5 |
| Connectivity | |
| Connection Range | >15m |
| Extra Features | |
| Earbud Dimensions | 21.28 × 28.25 × 22 mm |
| Earbud Weight | 5.6g ± 0.2g each |
| Wireless Version | Wireless BT 6.0 |
