Blackview AirBuds 13 IPX7 Waterproof Smart Noise Reduction Bluetooth 5.4 Clip-on OWS Earbuds
Hurry up, only 4 items left in stock.
✔ENC+DNS Smart Noise Reduction
✔ IPX7 Waterproof Rating
✔5.28g Ultra-lightweight & Clip-on Design
✔400mAh Battery & Smart LED Power Display
✔Android & iOS & HarmonyOS Compatible
Blackview AirBuds 13 is made for everyday listening, clear calls, and active routines. Lightweight and easy to carry, it fits commuting, workouts, gaming, movies, and office video calls with ease. With ENC and DNS noise reduction, AirBuds 13 helps keep calls clearer in busy environments. IPX7 water resistance adds confidence for workouts, sweat, and rainy days, while fast charging gives you quick power when you’re in a rush. A comfortable lightweight design reduces pressure during longer wear, and the LED power display makes battery status easy to check. For users who want practical earbuds with clear calls, water protection, and daily convenience, AirBuds 13 is a smart, flexible choice.
13mm Mega Dynamic Driver |
Latest BT 5.4 | 400mAh Mega
Battery | IPX7 Waterproof
Lead the Trend
Listening Pleasure
Clearer and Richer Sound Quality Through Bone Vibration
Less Detailed Sound Quality
vs
& Dual Noise Reduction
Well-balanced and Zealous Sound Anytime, Anywhere
Enjoy Clear and Polished Music During Your Commute
Conduct Clear Video Calls with Clients in the Office
Listen to a Podcast While Doing Yoga
Cancellation AirBuds 13 Predecessor
Durable Battery Life
1-hour Music Play Flash Charge, Instant
Play A quick 10-minute charge delivers up to 1 hour of uninterrupted music playback. Say goodbye to battery anxiety, and keep your music online and let your inspiration flow, right now!
Case Power on, Worry-free Use
Display Visible Power, Smarter
Charge Combining aesthetic appeal with practicality, the smart LED display shows the remaining charge at a glance. Always know exactly when to recharge and enjoy uninterrupted listening.
Charging Case
L/R Earbuds
Intensely in the Gym Sweat It out, Music on
Water Sports Accidental Splashes, Easy to Handle
for Instant Joy
User Guide
Assistant Tap and Talk, Voice
at Your Command
Connection One Pair, Auto-
connect Forever
First-time Paring Guide
Compatibility Across Devices
in Every Way Offer faster data transmission, lower power consumption, and reduced latency for an instant and stable connection with immediate response for music and calls, even in crowded places where many BT devices are in use.
Heavy BT Usage
HarmonyOS Connect Universally, Listen Seamlessly
Blackview AirBuds 13 Specifications
ModelAirBuds 13
Weight5.28g (per earbud), 36.01g (charging case)
ColorLava Black, Stellar White
Driver Unit13mm Dynamic Driver
Frequency Response Range20Hz~20KHz
BT Version5.4
Audio CodecSBC, AAC
Battery Capacity35mAh (earbud), 400mAh (charging case)
Charging Time1.5hrs (earbud), 2hrs (charging case)
Charging PortType-C
Connection Range>10m
Water Resistance RatingIPX7
Lead the Trend
Listening Pleasure
vs
Anytime, Anywhere
Delve into Immersive Movies When Watching at Home
Engage in Gaming with Lively and Surrounding Sound
L/R Earbuds
Charging Case
for Instant Joy
at Your Command
connect Forever After initial pairing, AirBuds 13 offers seamless, instant connection. Open the charging case, wear the earbuds, and immerse yourself in beautiful notes.
Heavy BT Usage
HarmonyOS Connect Universally, Listen Seamlessly Offer seamless performance across Android, iOS, and HarmonyOS and allow you to switch effortlessly between your smartphone, tablet, and laptop without missing a beat.
ModelAirBuds 13
BT Version5.4
Audio CodecSBC, AAC
Charging PortType-C
| Model & Design | |
| Model | AirBuds 13 |
| Color | Lava Black, Stellar White |
| Weight | 5.28g (per earbud), 36.01g (charging case) |
| Audio & Performance | |
| Driver Unit | 13mm Dynamic Driver |
| Frequency Response | 20Hz ~ 20KHz |
| Audio Codec | SBC, AAC |
| Water Resistance | IPX7 |
| Connectivity & Battery | |
| BT Version | 5.4 |
| Connection Range | >10m |
| Battery Capacity | 35mAh (earbud), 400mAh (charging case) |
| Charging Time | 1.5hrs (earbud), 2hrs (charging case) |
| Charging Port | Type-C |
