Blackview AirBuds 13 IPX7 Waterproof Smart Noise Reduction Bluetooth 5.4 Clip-on OWS Earbuds
Available in stock (18)
✔ENC+DNS Smart Noise Reduction
✔ IPX7 Waterproof Rating
✔5.28g Ultra-lightweight & Clip-on Design
✔400mAh Battery & Smart LED Power Display
✔Android & iOS & HarmonyOS Compatible
Blackview AirBuds 13 is made for everyday listening, clear calls, and active routines. Lightweight and easy to carry, it fits commuting, workouts, gaming, movies, and office video calls with ease. With ENC and DNS noise reduction, AirBuds 13 helps keep calls clearer in busy environments. IPX7 water resistance adds confidence for workouts, sweat, and rainy days, while fast charging gives you quick power when you’re in a rush. A comfortable lightweight design reduces pressure during longer wear, and the LED power display makes battery status easy to check. For users who want practical earbuds with clear calls, water protection, and daily convenience, AirBuds 13 is a smart, flexible choice.
| Model & Design | |
| Model | AirBuds 13 |
| Color | Lava Black, Stellar White |
| Weight | 5.28g (per earbud), 36.01g (charging case) |
| Audio & Performance | |
| Driver Unit | 13mm Dynamic Driver |
| Frequency Response | 20Hz ~ 20KHz |
| Audio Codec | SBC, AAC |
| Water Resistance | IPX7 |
| Connectivity & Battery | |
| BT Version | 5.4 |
| Connection Range | >10m |
| Battery Capacity | 35mAh (earbud), 400mAh (charging case) |
| Charging Time | 1.5hrs (earbud), 2hrs (charging case) |
| Charging Port | Type-C |
