Blackview AceBook 8 Pro 16 Inches AMD Ryzen™ 7 3700U Windows 11 Pro 16GB DDR4 512GB SSD Laptop
Regular price £598.00
Sale price Regular price
Work Smarter, Create Greater
16-inch Eye-Friendly
FHD Display
17.4 mm Slim &
1.65 kg Lightweight
Pre-installed
Windows 11 Pro
Your Upgrade to Faster,
Bigger, and Smarter Experiences
Key
Upgrade
Bigger, more immersive screen
Slimmer than ever before for portability
Faster CPU and improved GPU for gaming, multitasking, and productivity
More room for files and projects
Reduces eye strain for long usage
Enhanced security and productivity tools for professional use
AceBook 8 Pro
Display
16-inch FHD (16:10),
90% screen-to-body
Thickness
17.4 mm
Processor
AMD Ryzen™ 7 3700U
(4 cores/8 threads, up to 4.0GHz),
Integrated Radeon™ Vega 10 Graphics
Storage
512 GB SSD+ TF Card Expansion (Up to 2TB)
Eye Comfort
OS & Security
Windows 11 Pro
AceBook 8
Display
15.6-inch FHD (16:9), 84% screen-to-body
Thickness
19.9 mm
Processor
Intel® N150, 4 cores/4 threads, up to 3.6 GHz
Storage
512 GB SSD+ TF Card Expansion (Up to 1TB)
Eye Comfort
Standard display
OS & Security
Windows 11 Home
NO.1 Immersive View, Slimmer Than Ever, Effortless Multitasking
16-inch FHD Display, 17.4 mm Slim & 1.65 kg Light, TÜV SÜD Low Blue Light Certification, 0–180° Lay-Flat Design
16-inch Eye-Friendly FHD Display
Sharper Details, Bigger View Enjoy a spacious 16-inch FHD display with a 90% screen-to-body ratio. The ultra-slim bezel design creates an immersive viewing experience, making daily tasks and entertainment more enjoyable while keeping the device sleek and streamlined.
16:10 Aspect Ratio
1920 × 1200 Resolution
90% Screen-to-body Ratio
2.5 mm Ultra-narrow Bezel
178° Wide Viewing Angle
Movies Feel More Cinematic
Read and Learn Comfortably
Relax with Gaming
Work More Efficiently
Work and Explore with Ease
AceBook 8 Pro is designed for everyday portability. Measuring just 17.4 mm in thickness, it slips easily into backpacks or briefcases, making it convenient for working and exploring. At 1.65 kg, it’s light enough for easy one-handed carrying, while remaining durable and reliable.
11% Slimmer than Before
The New AceBook 8 Pro
17.4 mm
AceBook 8 Pro
19.9 mm
AceBook 8
Grey
Refined Grey and
Durable Design
Built from a hybrid of metal and plastic with a sandblasted finish, AceBook 8 Pro combines strength with a sleek, modern look.
Comfortable Viewing, Day or Night TÜV SÜD Low Blue Light Certification
Certified by TÜV SÜD for low blue light emissions, the display helps reduce eye strain during long hours of browsing or watching videos, so you can enjoy clear visuals with greater comfort.
0–180° Lay-Flat Design Share Freely, View Comfortably With a fully rotatable hinge, adjust your screen effortlessly to any angle between 0° and 180°. Perfect for study or entertainment, making sharing easier than ever.
AceBook 8 Pro
0°–180°
Peers
Limited to 135°
NO.2 Multitask Seamlessly, Store Effortlessly AMD Ryzen™ 7 3700U, Radeon™ Vega 10 Graphics, 16GB DDR4 Memory, 512GB SSD + TF Card Expansion (Up to 2TB)
AMD Ryzen™ 7 3700U + Radeon™ Vega 10 Graphics Powerful Enough for Work & Play Driven by AMD Ryzen™ 7 3700U processor with boost speeds up to 4.0GHz, AceBook 8 Pro delivers smooth and responsive performance for everyday tasks. Featuring integrated with Radeon™ Vega 10 Graphics, it handles work, entertainment, and light gaming with ease.
12nm Process
4 Cores
8 Threads
4.0GHz Turbo Frequency
6MB (L2+L3) Cache
Smoother, Faster, More Responsive CPU Performance: +30% (PassMark multi-thread benchmark)
AceBook 8 Pro
7,020
+30%
AceBook 8
5,387
16GB DDR4 Memory Smooth Multitasking, No Slowdowns With 16GB of DDR4 RAM, AceBook 8 Pro handles multiple tasks effortlessly — work on projects, stream videos, and join video calls, all running smoothly without slowdowns.
512GB SSD + TF Card Expansion (Up to 2TB) Space to Keep Your Ideas Flowing Unlock ample storage for all your media files, projects, and more without worrying about running out of space. With a 512GB SSD and TF card support expandable up to 2TB, you have plenty of room to grow your work and creativity.
512GB SSD
2TB TF Card Expansion
NO.3 All-Day Performance, Stay Cool and Calm
Reliable 38 Wh Battery Capacity, PD 3.0 Fast Charging, 16,000 mm² Total Cooling Area, Whisper-Quiet Design
Work. Play. Learn. All Day.
*Tested by Blackview Lab. Actual results may vary depending on usage and environmental conditions.
AceBook 8 Pro’s 38 Wh battery keeps you powered through daily tasks, from handling work to streaming videos. Compact and reliable, it’s the ideal companion for business trips or working on the go.
5 hrs Music
4.5 hrs HD video
5 hrs Office use
3.5 hrs Game
Charge in Minutes, Stay Powered Longer
PD 3.0 Fast Charging AceBook 8 Pro supports PD 3.0 fast charging, compatible with laptops, tablets, and smartphones, keeping your device ready for meetings or streaming throughout the day.
16,000 mm² Total Cooling Area Efficient Cooling, Quiet Performance Powered by an advanced thermal system, AceBook 8 Pro combines a dense-blade fan with durable copper heat pipes across a 16,000 mm² total cooling fin area. This design ensures smooth airflow, keeping the laptop cool and whisper-quiet even during prolonged use.
High-Density Centrifugal Fan
For efficient airflow and quiet operation
16,000 mm² Large Cooling Surface
For rapid heat dissipation
Thick Copper Heat Pipes
Ensure fast and even heat transfer
Whisper-Quiet Design Work Quietly. Stay Productive
Designed for focus and comfort, AceBook 8 Pro keeps cooling efficient while maintaining a quiet environment. Fan noise stays around 43 dB under full load, ensuring you can work or relax without distraction.
NO.4 Type Comfortably, Hear Effortlessly, Speak Clearly Independent Numeric Keypad, Dual BOX Stereo Speakers, 2MP HD Front Camera, Noise-Reduction MIC
Independent Numeric Keypad Seamless Typing, Comfortable Feel
Featuring an independent numeric keypad for quick number entry, AceBook 8 Pro allows one-handed input for spreadsheets, data tasks and more. With 1 mm key travel, typing feels comfortable and responsive, ideal for smooth workflows.
Fast, One-Handed Number Entry
1 mm Key Travel
Comfortable and Responsive Typing
1 mm
Clearer, Louder, Richer Equipped with dual BOX stereo speakers, AceBook 8 Pro delivers clear, rich stereo sound with volumes up to 97 dB. From online meetings to media playback, enjoy fuller and more immersive audio.
2MP HD Front Camera & Noise-Reduction MIC
See Clearly, Speak Naturally The 2MP HD front camera on the AceBook 8 Pro captures clear 1080P video, while the noise-reduction microphones ensure your voice comes through clearly, ideal for video calls, online meetings and more.
NO.5 Connect More, View More, Work Smarter 8 Versatile Ports, Triple Display Support, Wi-Fi 5 + Wireless BT 4.2
8 Versatile Ports
Plenty of Ports. Easy Connections Designed to handle work and entertainment, AceBook 8 Pro features a versatile set of ports including USB, HDMI and more that make it easy to connect displays, storage, and essential accessories. Enjoy seamless connectivity and get more done without extra adapters.
TF Card Slot 3.5mm Audio Jack USB 3.2 Gen 1 Type-A: Up to 5 Gbps
HDMI 1.4: Max 4K@30Hz Full-featured USB Type-C (Type-C1) : Up to 5 Gbps
USB Type-C (Type-C2): PD + Data 2.0 USB 3.2 Gen 1 Type-A: Up to 5 Gbps
Full-featured Type-C
One Port, Multiple Uses Charge your devices, transfer data, and connect to an external display at up to 4K@60Hz, all through a full-featured USB-C port. Power your phone or tablet, connect peripherals, and enhance your workflow effortlessly. Charge and Connect Multiple Devices
Earphone
Phone
Tablet
Power Bank
Mouse
USB-C Fan
Triple Display Support Triple Your View, Multitask Efficiently
HDMI 1.4
(Max 4096 x 2160 @30Hz)
USB Type-C (Full-featured)
(Max 4K @60Hz)
Built-in 16-inch
Immersive Display
With HDMI, Type-C, and the built-in display all connected at once, you can see all your content clearly and multitask across three screens with ease, boosting your productivity.
Wi-Fi 5 + Wireless BT 4.2 Always Stay Connected
Fast & Reliable Wi-Fi 5
For smooth browsing, streaming, and downloads.
Stable Wireless BT 4.2
For making pairing devices quick and hassle-free.
Pre-installed Windows 11 Pro Easy Setup with Powerful
Performance
Discover a secure, powerful, and business-ready experience with Windows 11 Pro pre-installed, keeping you productive and your data safe from the moment you start, all on the AceBook 8 Pro.
Pre-installed
Microsoft Office
Do Not Disturb
Mode
Focus Sessions
Windows Security
Center
Snap Layouts &
Snap Groups
Virtual Desktops
Task View
Live Captions
10,000+ Rigorous Tests, Reliable Performance AceBook 8 Pro undergoes rigorous quality inspections, including drop, touchpad click, and hinge tests, to ensure long-lasting durability. Reliable and sturdy, it performs smoothly whether you’re streaming or multitasking on the go.
High Temperature
and High Humidity
Operating Test
Packaging
Vibration Test
Packaging
Drop Test
Hinge
Durability Test
Touchpad
Click Test
Blackview AceBook 8 Pro Specifications
  • Brand
    Blackview
  • Model
    AceBook 8 Pro
  • Color
    Grey
  • Dimension
    356.3 x 245.2 x 17.4 mm
  • Weight
    1.65 kg
  • Display
    16-inch, 16:10, 1920 x 1200, 90% Screen-to-body Ratio,60Hz
  • CPU
    AMD Ryzen™ 7 3700U, 4 cores/8 threads
  • GPU
  • Cache
    2MB L2 + 4MB L3
  • Burst Frequency
    4.0GHz
  • RAM
    16GB DDR4, 2400MT/s
  • SSD
    512GB, M.2 2280
  • TF Card Expansion
    Up to 2TB Expandable Storage
  • Speaker
  • Camera
    2MP Front, 1920 x 1080
  • Fingerprint
    Supported
  • Battery
    Sup38Wh with PD 3.0 Fast Chargingported
  • OS
    Windows 11 Pro
  • Memory
    RAM 1GB,ROM 8GB
  • Wi-Fi & BT
    Wi-Fi 5 (IEEE 802.11 a/b/g/n/ac), BT 4.2
  • I/O
    1 x HDMI 1.4 (4K@30Hz)
    3 x USB 3.2 Gen 1 Type-A
    1 x Type-C1 (PD + DP + Data 3.0 5Gbps)
    1 x Type-C2 (PD + Data 2.0)
    1 x TF Card Slot
