Blackview AceBook 8 Pro 16 Inches AMD Ryzen™ 7 3700U Windows 11 Pro 16GB DDR4 512GB SSD Laptop
Hurry up, only 6 items left in stock.
✔ 16" 17.4 mm Slim & 1.65 kg Lightweight
✔AMD Ryzen™ 7 3700U 4.0GHz Processor
✔16GB DDR4 RAM + 512GB SSD
✔Windows 11 Pro OS
Blackview AceBook 8 Pro upgrades everyday productivity with a larger 16-inch FHD display, slim 17.4 mm body, and lightweight 1.65 kg design. Powered by AMD Ryzen 7 3700U, Radeon Vega 10 graphics, 16GB DDR4 memory, and 512GB SSD storage, it handles work, study, entertainment, and light gaming smoothly. With TÜV low blue light, triple display support, and Windows 11 Pro, it’s built for smarter daily use.
| Brand | Blackview |
| Model | AceBook 8 Pro |
| Color | Grey |
| Dimension | 356.3 x 245.2 x 17.4 mm |
| Weight | 1.65 kg |
| Display | 16-inch, 16:10, 1920 x 1200, 90% Screen-to-body Ratio,60Hz |
| CPU | AMD Ryzen™ 7 3700U, 4 cores/8 threads |
| GPU | Radeon™ Vega 10 Graphics |
| Cache | 2MB L2 + 4MB L3 |
| Burst Frequency | 4.0GHz |
| RAM | 16GB DDR4, 2400MT/s |
| SSD | 512GB, M.2 2280 |
| TF Card Expansion | Up to 2TB Expandable Storage |
| Speaker | Dual BOX Stereo Speakers |
| Camera | 2MP Front, 1920 x 1080 |
| Fingerprint | Supported |
| Battery | Sup38Wh with PD 3.0 Fast Chargingported |
| OS | Windows 11 Pro |
| Memory | RAM 1GB, ROM 8GB |
| Wi-Fi & BT | Wi-Fi 5 (IEEE 802.11 a/b/g/n/ac), BT 4.2 |
| I/O | 1 x HDMI 1.4 (4K@30Hz) 3 x USB 3.2 Gen 1 Type-A 1 x Type-C1 (PD + DP + Data 3.0 5Gbps) 1 x Type-C2 (PD + Data 2.0) 1 x TF Card Slot |
