Blackview AceBook 5 15.6-Inch Intel® CPU DDR4 RAM M.2 SSD Windows 11 Pro Laptop
Out of stock
✔ 15.6-inch FHD Display, 19.3 mm Slim & 1.6 kg Light
✔Intel® Pentium® Silver N6000 CPU, Intel® Graphics GPU
✔2666MHz DDR4 RAM + M.2 2280 SSD
✔Windows 11 Pro Pre-installed
Your payment information is processed securely. We do not store credit card details nor have access to your credit card information.
16GB RAM + 512GB SSD + Up to 2TB TF Card Expansion
Certification, Immersive and Comfortable Viewing
Dual Microphones For Video Calls, Online Classes, and More.
Area of 15,481 mm²
Battery Up to 100hrs of Standby
Fast Charging
Keypad Fast Number Input for Reports, Budgets, and Data Tasks.
Windows 11 Pro More Secure, More Manageable,
More Professional
Proven Reliability
Visuals
Easier to carry around ↑
Better for commuting and travel↑
Less weight in your backpack↑
*Based on PassMark multi-thread benchmark results. Actual performance may vary
depending on usage conditions.
512GB SSD
Blades Quiet and Efficient Cooling Design
4500 RPM For Faster Heat Dissipation
Large Size For Stronger Airflow & Lower Noise
Pipes For Fast and Even Heat Transfer
Touchpad 121 × 80 mm² touching area
Humidity Test Maintains reliability in hot or humid climates.
Everyday Productivity With a spacious 15.6-inch display designed for comfortable viewing and practical everyday features, Blackview AceBook 5 delivers an efficient experience for work, study, and entertainment. From clear video calls to faster data entry with its full-size keyboard and numeric keypad, it helps you stay productive throughout the day. Slim and lightweight, it’s ready to go wherever your day takes you.
Model
Color
Dimension
Weight
Display
CPU
GPU
Cache
Burst Frequency
RAM
SSD
TF Card Expansion
Camera
Speaker
Battery
Wi-Fi & BT
I/O
OS
AceBook 5
Grey
360.6 × 236 × 19.3 mm
Approx. 1.6 kg
15.6-inch FHD IPS Display, 1920 × 1080 Resolution
Intel® Pentium® Silver N6000, 4 Cores / 4 Threads, 10 nm Process
Intel® Graphics, u p to 850MHz Dynamic Frequency, 4096 × 2160 @ 60Hz
6 MB Intel® Smart Cache
Up to 3.3GHz
DDR4, 2666MHz, 16GB
512GB, M.2 2280 SSD
Up to 2TB
2MP Front Camera
Dual BOX Stereo Speakers
38Wh, 45W Fast Charging
Wi-Fi 5 (IEEE 802.11 a/b/g/n/ac), BT 5.0
2 × USB 3.2 Gen 1
1 × USB 3.2 Gen 2
1 × TF Card Slot
1 × HDMI 1.4 (4K @ 30 Hz)
1 × USB-C (PD + DP + Data 3.0 5 Gbps)
1 × 3.5 mm Audio Jack
Windows 11 Pro
