Color_Black
Blackview A55 Pro 4GB+64GB 6.528 inches 13MP Camera Helio P22 Octa Core 4780mAh 4G Smartphone
Sale price £98.00 Regular price £150.00
Note:
A55 Pro
New Budget Excellence
Lead A Broader and Clearer Vision
Introduce the large 6.528" waterdrop display for an incredible and immersive visual journey. The 720*1600 high-definition resolution unveils lifelike details before your eyes.
  • 6.528-inch
    Screen Size
  • 720*1600
    HD+ Resolution
  • 89%
    Screen-to-body Ratio
  • 20:9
    Aspect Ratio
  • 400nit
    Brightness
The Power to Do More
Outlast your day with the large 4780mAh power-efficiency battery. Stay powered longer and no more with low battery anxiety on the go.
  • 6.5 hrs
    Game
  • 7.5 hrs
    Movie
  • 9.5 hrs
    Web
  • 18 hrs
    Call
  • 28 hrs
    Music
  • 480 hrs
Meet the Sophisticated, Simplistic Style
All details, from the water-rippling pattern, fingerprint-proof matte finish, and sleek
curves to the fresh colors, work in harmony and bring out the best design style.
As Light As It Can Be
Fitting the large screen and battery into an ultra-lightweight and compact body,
A55 Pro is comfortable to hold. Make every grasp a delight.
  • 9.2mm
    Slim
  • 196g
    Light
Your Dream Colors
Meet the new fabulous aesthetics in the new color series with the A55 Pro.
Opt for the most favored one that can speak out your style most.
  • Cobalt Blue
  • Turquoise Green
  • Obsidian Black
  • Cloud White
Powerful to the Core
The octa-core MediaTek Helio P22 capably multitasks efficiently and smoothly to power through most demands. CorePilot 4.0 technology matches the performance with the best power efficiency.
  • 4GB
    RAM
  • 64GB
    ROM
Memory Expansion from 4GB to 7GB
Include More without Cost
To further expand memory without extra cost, A55 Pro provides Memory Expansion Technology that can compress data and save them in RAM to enlarge memory capacity to 7GB. A55 Pro gives you an edge to open more apps simultaneously and switch between different apps with ultra-smoothness.
Store All What You Need
You can not only benefit from inserting two 4G SIM cards but also store everything you need, such as photos and movies, by expanding up to 1TB external storage via a TF card.
Everyday Shots Shine out
Discover the beauty in routine life through the dual lens of A55 Pro. Whenever something strikes you, click the shutter to record in a photo or video in a breeze.
Unlock in A Wink
Reach the rear-mounted fingerprint sensor area with your finger naturally to unlock the phone in no time. Also support face unlock.
Android 11
Doke OS 2.1
  • System Manager
    Support all-in-one controls such as trash cleaning and battery management.
  • Clone Phone
    Transfer the privacy data safely from the old to the new device.
  • Artistic Themes
    Two sets of themes are with enriching icons and invigorating wallpapers.
  • Cold Room
    Freeze apps to avoid their stealthy background running and save memory.
  • Screenshot/Long Screenshot
    For important messages, make a screenshot or long screenshot and edit it easily.
  • Dual-window Entertainment
    View different contents on the same screen to enable entertaining while working.
  • 4-in-1 Navigation System
    Supports GPS, GALILEO, GLONASS, and BEIDOU navigation for faster positioning.
  • 4G LTE Connectivity
    Deliver fast and stable mobile network experience for better work and play capabilities.
    Network Connectivity
    GSM spec: 850/900/1800/1900 (B2/B3/B5/B8)
    3G spec: WCDMA: B1/B8
    LTE spec: TDD: B40 FDD: B1/B3/B7/B8/B20
