Blackview ROCK 1 6.56-inch 90Hz Main & 2.01" Secondary Display MediaTek Helio G81 Octa-core 15000mAh 20MP Night Vision Camera 4G Rugged Phone
Available in stock (15)
✔6.56-inch Main & 2.01" Multi-functional Secondary Display
✔Octa-core MediaTek Helio G81 Processor
✔15000mAh & 33W Fast Charging
✔20MP Sony® Night Vision Camera
✔IP68 & IP69K & MIL-STD-810H Certified
The Blackview ROCK 1 is built for users who need dependable mobile performance in demanding environments. It combines a 6.56-inch 90Hz main display and 2.01-inch secondary display with MediaTek Helio G81 performance and a 15000mAh battery with 33W fast charging for work, travel, navigation, and outdoor use. Key field-ready features include a 20MP Sony night vision camera, dual-screen utility for quick status checks, and IP68 & IP69K & MIL-STD-810H protection. Designed for job sites, remote trips, and everyday toughness, it gives users the confidence to stay connected, capture details, and keep going when regular phones are not enough.
Innovative Dual Displays
Meets Massive Power
Your Trusted Outdoor Choice to Explore Beyond
Rugged Design Meets Thoughtful Aesthetics
ROCK 1 features a durable rugged structure, highlighting its hardcore technological strength. The back cover integrates a unique matte design that interacts with light to create dynamic visual effects, adding a subtle touch of sophistication to its rugged appearance.
Effortlessly attach a strap, hang anywhere, and keep it safe.
No.1
MIL-STD-810H & IP69K & IP68 Certified, Built
to Conquer Extremes
No.2
Innovative Dual-Screen, Redefining
Smart Vision
No.1
Built to Conquer Extremes
Built Tough. Ready for Anything.
ROCK 1 offers military-grade durability to withstand drops, water, and dust. From construction sites to extreme outdoor adventures, it's your trusted companion for every challenge.
Proven through these extreme tests
Rain
Sand and Dust
Vibration
Shock
Humidity
Altitude
Acceleration
High Temperature
Low Temperature
Immersion
Reinforced Shockproof Corners
Ultra-Tough Back Cover
Aviation-Grade Aluminum
Alloy Frame
Scratch-Resistant
Shatterproof Panda Glass
Engineered for Extremes.
ROCK 1 meets both IP68 and IP69K standards — fully protected against dust, deep water immersion, and powerful high-pressure jets. Engineered for extreme environments, it performs reliably where others can't.
*Waterproof up to 1.5m depth for 30 minutes.
Seamless Edge Sealing Around Screen
Corrosion-Resistant Aluminum Buttons with Premium Silicone Waterproof Rings
TPU Plug for USB Port, Complete Seal
Speaker Cleaning, Auto Dust &
Water Removal
Underwater Camera
No.2
Innovative Dual-Screen, Redefining Smart Vision
6.56" HD+ IPS Display
See More, Enjoy More
ROCK 1's 6.56" HD+ IPS display combines stunning clarity with wide viewing angles, delivering an immersive visual experience for gaming, streaming, and more.
720*1612
Resolution
178°
IPS Full View
450nits
Brightness
180Hz
Touch Sampling Rate
83%
Screen-to- body Ratio
90Hz AI Smart Refresh Rate
Smoother. Faster. Better.
Say goodbye to lag — smart switching ensures silk-smooth scrolling and maximizes battery life.
2.01" Multifunctional Secondary Screen
Small Screen, Big Difference
ROCK 1's smart sub-screen puts notifications, music control, customizable watch faces, and more at your fingertips — efficient, convenient, and uninterrupted fun.
2.01-inch
Size
240*296
Resolution
Panda
Glass
16:13
Aspect ratio
500nits
Brightness
Take Selfies with
Rear Camera
Check Time & Date
Play/Pause/Switch Tracks
Accept/Decline Calls
View Message
Notifications
Check Weather Updates
Use the Built-in
Compass
Track Your Steps
Personalize Clock Styles
Eye-Care Modes
Comfort That Lasts, Day and Night.
Four eye-care modes to protect your vision anytime—read, work, or relax with ultimate comfort.
Reading Mode
Night Light
Dark Mode
Light Mode
Glove Mode 2.0
Smooth Control, Even with Gloves.
8% More Sensitive Touch
No.3
Helio G81 Boosted, Performance Unleashed
Fast. Efficient. Reliable.
No lag—just go. With ROCK 1, seamlessly switch work apps, navigate off grid, and stream on the move—all day steady.
2*Cortex-A75@2.0GHz+
6*Cortex-A55@1.7GHz
Instant Opens, Smooth Multitasking
Arm Mali-G52 MC2
Smoother Graphics, Clearer Detail
345,548
AnTuTu Benchmark
Up to 24GB LPDDR4X RAM
Multitask Without Compromise.
Built to do more. ROCK 1 flies through work apps and entertainment with rapid loads, smooth swaps, and rock-steady speed.
Up to 24GB RAM=8GB RAM + 16GB Expansion
Atomized Memory 2.0
9% More RAM Available
256GB eMMC 5.1 Flash Storage
Instant Launch, Seamless Flow.
Install and open massive content in an instant, with apps launching in a flash for a seamless, always-on experience!
F2FS File System
25% Faster Random Read Speed
3× Faster Random Write Speed
EROFS Read-Only File System
Up to 300% Faster Random Read
2651mm² Cooling Mastery
Stay Cool, Perform Better
ROCK 1 harnesses triple-material cooling technology, delivering exceptional heat dissipation and a smoother, cooler user experience.
Graphite
Thermal Silicone Grease
Copper Foil
Stays cool at 38°C even after intense gaming
No.4
15,000mAh Powerhouse, Endless Battery Life
15,000mAh Giant Power
Limitless Energy, Unstoppable Fun!
ROCK 1 packs a massive 15,000mAh capacity, delivering unstoppable power for business, travel, and adventure. Always fully charged, ready to rock every moment!
Intelligent Charging
Protection
AI Power Saving
Algorithm
20hrs
Game
84hrs
Call
64hrs
Music
26hrs
Web
22hrs
Video
45days
*Data are tested by Blackview Lab based on continuous use. The actual use may vary depending on real-world usage conditions.
5W OTG Reverse Charging
Power Anytime,
Share Anywhere.
Effortlessly charge your earphone, smartwatch, and more—always ready for on-the-go emergencies.
No.5
Capture Every Moment, Day or Night.
16MP AI Main Camera
Clear. Vivid. Effortless.
From work to play, the 16MP main camera on ROCK 1 delivers sharp, vibrant shots—ready to share instantly.
13MP AI Front Camera
Perfect Selfies, Anytime.
The AI-powered 13MP front camera on ROCK 1 ensures you always shine, with smart adjustments for flawless results in any setting.
Portrait
Focus on What Matters.
AI-powered background blur highlights your subject with stunning depth for a professional, eye-catching look.
Beauty
Effortless Glow.
Naturally You.
Smooth skin, enhanced tones, and AI perfection—quick selfies never looked so real and flawless.
Night
Own the Night.
Bright, sharp, and vivid—AI-enhanced low-light shots capture every detail, even in the darkest moments.
20MP Sony Night Vision
See Beyond the Dark.
ROCK 1 breaks through the darkness to reveal every detail of the night, capturing what the naked eye can't.
No.6
Industry-Exclusive Doke AI Smart Assistant
Powered by integration with the world's top three AI models, Doke AI understands your needs with precision, delivering smarter, faster, and more personalized service experiences!
DeepSeek-R1
ChatGPT-4o mini
Gemini AI 2.0 Flash
Gemini AI
Smarter Assistant, Tailored to You.
Voice Wakeup &
Voiceprint Recognition
Unlocks instantly and securely with your voice, no hands needed.
Global Smart Control
One command, seamless control across apps and settings.
Full-Screen Assistance
Ask about your screen and get answers instantly.
Real-Time Interaction
Instant responses, natural conversations anytime, anywhere.
Industry's Only Self-Developed Doke AI Apps
Hi Doki App
Your AI Smart Chat Assistant
From tackling tasks to sparking ideas, Hi Doki is your always-ready companion.
Next-Gen
DeepSeek-R1
Deep thinking, next-level intelligence.
AI Online Search
Timely insights, smarter answers.
Document Parsing
Upload and analyze instantly.
Tutoring Assistant
Scan, solve, and learn smarter.
Chat with AI
19 AI personas, endless conversations
ImageX App
Your On-the-Go AI
Photo Editor
With 18 AI Photo Editing tools, ROCK 1 effortlessly transforms outdoor shots, field photos, and everyday moments into stunning visuals ready to share.
AI Remove Objects
Remove unwanted elements effortlessly with pinpoint accuracy.
AI OutPainting
Extend your canvas and broaden perspectives seamlessly.
AI Blur Photo
Highlight the subject with intelligent background blurring.
AI Replace Background
Effortlessly replace backgrounds and redefine your scenes.
AI Animate
Turn still images into dynamic moments— watch faces and memories come alive!
VidGen App
Your AI Video Magic Maker!
From text to video, photos to cinematic moments, VidGen’s smart AI turns your everyday adventures into stunning, share-ready creations with fun, dynamic effects—all in just a few taps!
Soundle App
Your AI Music Composer!
No instruments or studio needed—Soundle turns your phone into a powerful music lab, creating unique melodies for every moment.
No.7
Latest DokeOS 5.0 Based on Android 16
DokeOS has evolved from 4.2 (Android 15) to 5.0 (Android 16), delivering faster performance, smoother operation, cleaner interface, more personalized experience, and smarter features. A complete upgrade for an exceptional user experience.
Explore More, Just Within Reach
Up to 120lm Bright Torch
Powerful lighting with SOS
flash for emergencies.
Side Key Function
Simplicity at Your Fingertip!
One press, no hassle—instantly access your
frequently used functions or apps with ease!
Start Soundrecording
Open flashlight
Screenshots
Open Underwater Camera
Open PTT
Open SOS
Useful ToolBag
Tools That Fit in Your Pocket!
10 essential tools in one app, transforming your ROCK 1 into a versatile all-in-one toolbox for everyday tasks.
Quad-Core Navigation
Navigate Anywhere,
Conquer Everywhere!
Seamless and precise navigation powered by GPS, Beidou, Galileo, and Glonass, ensuring reliability even in the most remote or demanding locations.
Blackview ROCK 1 Specifications
| Model | ROCK 1 |
| Color | Black |
| Dimension | 177.9 * 83.5 * 24.7mm |
| Weight | 490g |
| OS | DokeOS 5.0 Based on Android 16 |
| Display | 6.56-inch HD+ IPS, 720 * 1612 Resolution 90Hz Refresh Rate, 83% Screen-to-body Ratio Secondary Screen: 2.01-inch, 240 * 296 Resolution |
| CPU | Octa-core MediaTek Helio G81 |
| RAM & ROM | 8GB RAM + 256GB ROM, LPDDR4X + eMMC 5.1 |
| TF Expansion | Up to 256GB Expandable Storage |
| Battery | 15000mAh; 33W Fast Charging |
| Front Camera | 13MP |
| Rear Camera | 16MP Main + 20MP Night Vision |
| VSpeaker | 1PC Smart-PA Box Speaker |
| Torch Brightness | Max 120 lm, Min 110 lm |
| Card Slot | Two; 2SIM/1SIM+1*TF Card |
| NFC | Support |
| Wi-Fi & Bluetooth | Wi-Fi 5; BT 5.0 |
| Network Connectivity | 2G Band: B2/B3/B5/B8 3G Band: WCDMA: B1/B8 CDMA: BC0/BC1/BC10 4G Band: TDD: B40/B41 FDD:B1/B3/B7/B8/B19/B20/B28A/B28B |
| Design | |
| Product | Blackview ROCK 1 |
| Color | Black |
| Display | |
| Main Display | 6.56-inch |
| Secondary Display | 2.01-inch |
| Refresh Rate | 90Hz |
| Performance | |
| Processor | MediaTek Helio G81 |
| Battery & Charging | |
| Battery | 15000mAh |
| Charging | 33W Fast Charging |
| Camera | |
| Night Vision Camera | 20MP Sony |
| Durability | |
| Connectivity | |
| Network | 4G |
