Blackview Active 12 Pro 5G Rugged Tablet with Built-in Projector (12+256GB/16GB+1TB) 11-inch FHD+ Display MediaTek Dimensity 7300 108MP Camera & Built-in Camping Light
Hurry up, only 8 items left in stock.
✔5G Octa-core MediaTek Dimensity 7300 4nm Up to 2.5GHz
✔Built-in 200LM 1080P 120″ Autofocus Projector & 400LM Camping Light
✔30000mAh Big Battery w/ 120w Fast Charge
✔108MP Samsung HM6 AI Main Camera
✔Adjustable Aluminum Alloy Bracket
✔UL94 HB Flame-Retardant Certificated
The Blackview Active 12 Pro is a rugged 5G tablet built for field work, presentations, outdoor entertainment, and emergency power. Its 11-inch 90Hz FHD+ display, Dimensity 7300 processor, 30,000mAh battery, and 120W fast charging give it strong endurance and performance for demanding users. The built-in 1080P autofocus projector supports up to 120 inches, while dual 400LM camping lights add night utility. With a 108MP rear camera, 50MP front camera, WiFi 6E, NFC, GPS, and a reinforced rugged design, it is a mobile workstation for serious use.
Reasons
Top 11 Reasons to Choose Active 12 Pro
No.1 Pushing the Limits of Rugged Tablet Durability
Industry-Leading Water,
Dust & Drop Resistance with Flame RetardanceTop-tier IP69 & MIL-STD-810H & UL94 HB Certified
IronShell Body to Redefine RuggednessGlove Mode 2.01.5m Death-broke Drop
12m Fall
2.2-ton Pressure
1.5m 30mins Swim & Splash & Oil Proof
Underwater CameraExtreme Temperatures
(-20℃~60℃)Thermal Shock
(-55℃~70%℃)95% Humidity Resistant
UV & Sunlight ResistantMarine-grade Corrosion ResistantMold & Mildew Proof -
No.2 One of A Kind
120″ 1080P Widevine L1 200LM
Autofocus Projector Tablet120″1080P200LMWidevine L1180° Free-Floating Stand
Easy-to-use Projector AppBuilt-in Distance Sensor -
No.3 Industry-leading
Super-bright 400LM Dual-beam Camping Light400LMDual-beam606 Beads for Brighter, Wider CoverageMultiple Modes: Illumination/ SOS/ Strobe -
No.4 Industry’s Largest 30000mAh Titan Battery
Super-Large & Super Long-LastingAI-smart Charging&Discharging Management112
Days of Standby30000mAh120W6.75Hrs
Nonstop Projection19Hrs
Continuous Illumination -
No.5 Industry’s Most Powerful Performance
Flagship MediaTek Dimensity 7300 SoC5G4nm ProcessHyperEngine Gaming TechOver 700,000 Benchmark ScoresWiFi 6EMediaTek AI Computing NPU 65548GB RAM & 3TB StorageLPDDR5 + UFS 3.1Atomized Memory 2.0Smart Pre-Loading -
No.6 Industry’s Clearest Imaging
108MP AI Camera System108MP AI Camera -1/1.67" Sensor
-6P Lens
-Nona-pixel Plus
-Smart-ISO Pro
-0.01s Auto-Focus50MP Selfie Camera -1/2.76" Sensor
-5P Lens
-Super PDAFAI Imaging
EnhancementMagic AI
Photo Editor -
No.7 Dedicated to Creating
The industry’s Strongest Eye-comfort Technology11"650nitsFHD+90HzAI-Smart Day-readable DisplayIndustry-leading·TÜV-certified Low Blue LightDay or Night. All Comfort
Reading Mode/Night Light/ Dark Modes -
No.8 One of A Kind
Self-developed PC Mode 2.0PC Mode 2.0Smart Split ScreenMulti-window ViewWPS OfficeWireless Keyboard & Mouse SupportStylus Pen
Self-developed AI Suites
Next-level Customization, Fluency,
Convenience, Privacy & Security
Mode Atomized
Memory Performance
Mode
(From Android 15 to Android 17)
Comprehensive After-sale Service
Survives 1.5m
Death-broke Drops
25% Increased
Drop-proof Performance
Stands Free Fall from 12m High-drop
Resistance Improved by 10%
Withstands 2.2 -Ton Pressure
Heavy-duty Load Resistance
Enhanced by 10%
Remain Optional Under Extreme
Temperatures Ranging from
-20℃ to 60℃
(-4℉~140℉)
for Water- & Dust-Resistance
at 1.5-meter Depth Anti-Coffee & Oil-Proof Surface
Flame-Retardant Build. Confidence in Every Condition.
Increased Touchscreen Sensitivity Underwater Camera
1080P Projector Tablet
Distance Sensor Auto Screen
Orientation Smart/Manual
Keystone Correction Auto/
Manual Focus ±20° Vertical
Keystone Correction ±60° Horizontal
Keystone Correction
400Lumen Dual Super-bright Camping Light
One-Key Operation
303 LED Lights on Each Side
400lm High Brightness
Game20 hrs -
Video21 hrs -
Browsing26 hrs -
Calling149 hrs -
Music103 hrs -
Projection6.75 hrs -
Illumination19 hrs -
Standby112 Day
Lightning-fast 120W Wired Charging
Fast Fuel
for the Fearless
112 Days' Power Back in 136mins
Lightning-fast 5G ,Blazing-fast WiFi 6E
Extinct Lag. Shatter Limits.
45%
Faster Response &
Smoother Multitasking
Up to 22
CPU-intensive apps
running
concurrently
in the background
in the background
9%
More RAM Available
Atomized Memory
2.0
Industry-leading Capacity, Built to Handle More
Up to 3TB UFS3.1 Storage
Day Or Night. Capture It All.
1/1.67-inch sensor size
6P Lens
0.01s Auto-Focus
f/1.9 aperture
Samsung JN1 sensor
1/2.76-inch sensor size
5P Lens
f/2.25 aperture
Even in Action 0.01s Fast, Precise Autofocus. No moment missed! Whether you're capturing fast-moving machinery or split-second wildlife scenes, it ensures lightning-fast, ultra-precise autofocus across the entire frame.
Vivid Memories. Shine through the shadows. The HM6 combines nine pixels into one ultra-large 1.92μm pixel for dramatically brighter night shots with less noise. Smart-ISO intelligently adapts to your surroundings, so even low-light environments like tents, caves, or moonlit job sites look clear and full of life.
All-Day Clarity, All-Night Comfort
11" FHD+ Immersive Display
for a paper-like reading feel.
(Enhanced/Moderate/Gentle) Three tailored levels to reduce eye strain
and save power.
Spark Creativity.
PC Mode 2.0 with
Wireless Keyboard &
Mouse Support
Prioritize What Matters Most Turn your Active 12 Pro into a portable workstation with PC Mode 2.0. Enjoy a desktop-like multi-window viewing experience wherever you are — complete with wireless mouse and keyboard support, resizable windows, and an intuitive multi-window layout.
Doke AI That Goes With You Fueled By DeepSeek-R1 x Gemini AI x GPT-4o mini
Voiceprint Recognition Real-time Voice Interaction Screen-aware Assistance
Hi Doki App
ImageX App
VidGen App
Smart AI Video Editor
Turn moments into missions. From construction footage to camping clips, VidGen gives
your field videos cinematic polish in seconds. No editing experience needed.
Soundle App
*A 30-day free trial is available for all Doke AI apps, providing full access to
every AI feature with no limitations.
Smarter↑ Personalized↑ Efficiency↑ Fluency↑ Privacy↑
*EasyShare is only effective when you turn on Wi-Fi in the Settings but does not rely
on the network. The data transmission speed shall prevail as testing environments may vary.
Bespoke Timer
Navigate Anywhere L1/L5 BeiDou & Glonass & Galileo & GPS
Faster Signal Lock & Better Accuracy ↑
Stronger & More Stable Global Coverage ↑
Real-World Ready. Compass/HeightMeasure/Torch/SoundMeter/Protractor/Mirror/Alarm bell/Magnifier/Pic Hanging/Plumb Bob
Tuned for You Start Soundrecording
Open flashlight
Screenshots
Open UnderWater Camera
Open PTT
Open SOS
Open app
ModelActive 12 Pro
ColorBlack
Dimension267.7*179*28.3mm
Weight1522g
OSDokeOS_P 4.2 Based on Android 15
Display11-inch FHD+ IPS, 83% Screen-to-body Ratio, 90Hz Refresh Rate
CPUMediaTek Dimensity 7300, up to 2.5GHz
RAM&ROM12GB RAM + 256GB ROM, Up to 24GB RAM Expansion
16GB RAM + 1TB ROM, Up to 32GB RAM Expansion
LPDDR5+UFS3.1 -
Expandable Storage2TB
Battery30000mAh; 120W Fast Charging
Front Camera50MP Samsung® JN1
Rear Camera108MP Samsung® HM6
SpeakerDual-BOX Speakers
Rugged RatingIP68&IP69K; MIL-STD-810H
NavigationGPS+GLONASS+Galileo+Beidou (L1+L5)
Card SlotDual, 2*SIM/1*SIM + 1*TF Card
Glove ModeSupport
NFCSupport
ConnectivityWiFi6E
BT5.4
2G Band: B2/B3/B5/B8
3G Band: B1/2/4/5/6/8/19 (RXD) + BC0/BC1/BC10 (RXD)
4G Band:
B1/2/3/4/5/7/8/12/13/17/18/19/20/25/26/28A/28B/30/66+B34/38/39/40/41
5G Band: N1/3/5/7/8/20/28/38/40/41/77/78/79
Real Reviews. Real Proof. See Our Rugged Gear in Action.
| Design | |
| Product | Active 12 Pro |
| OS | DokeOS_P 4.2 Based on Android 15 |
| Color | Black |
| Weight | 1522g |
| Dimensions | 267.7*179*28.3mm |
| Screen | |
| IC | ICNL9951R |
| Panel Type | IPS |
| Display Resolution | FHD+ |
| Screen Size | 11 inch |
| Screen Resolution | 1920x1200 16:10 |
| PPI | 207 |
| Refresh frequency | 90HZ |
| Screen to Body Ratio (%) | 83% |
| Glass | CORNING® GORILLA® GLASS 5 |
| Connectivity | |
| 2G | GSM: B2/B3/B5/B8 |
| 3G | B1/B2/B4/B5/B6/B8/B19, CDMA:BC0/BC1/BC10 |
| 4G | FDD:B1/B2/B3/B4/B5/B7/B8/B12/B13/B17/B18/B19/B20/B25/B26/B28A/B28B/B30/B66 TDD:B34/B38/B39/B40/B41 |
| WIFI | IEEE802.11 a/b/g/n/ac/ax(WiFi6E) |
| Bluetooth | V5.4 |
| Hardware | |
| CPU | MediaTek Dimensity 7300(MT6878) |
| CPU Clock | 4*A78@2.5GHz; 4*A55@2.0 GHz |
| GPU | Arm Mali-G615 GPU |
| RAM | 12GB/16GB |
| RAM Type | LPDDR5 |
| ROM | 256GB/1TB |
| ROM Type | UFS3.1 |
| TF Card Slot | Support |
| Max TF Card Capacity | Up to 2TB |
| USB | TYPE-C |
| Speaker | Dual-BOX Speakers |
| Camera | |
| Front Camera | 50MP |
| Front Camera Aperture | F2.25 |
| Rear Camera | 108MP |
| Rear Camera Sensor | Samsung® ISOCELL HM6 |
| Rear Camera Aperture | F1.9 |
| Rear Flash | Yes |
| Power | |
| Battery Capacity | 30000mAh |
| Max Charging Current | 20V/6A, 120W Fast Charging |
| Additional Tool | |
| Projector | Up to 120'' 1080P 200LM Autofocus Projector, Built-in Distance Sensor (Recommended throw distance: within 2 meters) |
| Camping Lights | Dual 400 lumen (LM) LED, Multiple Modes: Illumination/ SOS/ Strobe |
| Multi-media | |
| Video | mp4\3Gp\3gpp\avi\x-flv... |
| Audio | ogg\aac\imy\amr\x-flac\mp3.... |
| Image | jpeg\png\gif\bmp |
| Features | |
| Navigation | GPS+GLONASS+Galileo+Beidou(L1+L5) |
| Motor | YES |
| Sensors | G-sensor/Light/Ditance-sensor |
| Gyroscope | YES |
| Magnetic | YES |
| Air pressure sensor | NO |
| Hall | NO |
| Compass | YES |
| Fingerprint | YES |
| RGB | NO |
| NFC | YES |
| Hotkont | NO |
| Coulomb Counter | YES |
| Wireless Charging | NO |
| Sim-Card Type | Dual nano, 2*SIM or 1*SIM + 1*TF Card |
| FM | YES |
| OTG | YES |
| Accessories | |
| User Manual | x1 |
| Aluminum Alloy Bracket | x1 |
| Stylus Pen | x1 |
| OTG cable | x1 |
| USB Cable | x1 |
Does the Blackview Active 12 Pro Rugged Tablet Have a Built-In Projector?
How Large Can the Blackview Active 12 Pro Projector Display?
How Bright Is the Blackview Active 12 Pro Projector?
Does the Blackview Active 12 Pro Projector Support Autofocus and Keystone Correction?
How Long Can the Blackview Active 12 Pro Run the Projector?
Can the Blackview Active 12 Pro Be Used for Outdoor Movie Nights?
Can the Blackview Active 12 Pro Be Used for Worksite Presentations?
Does the Blackview Active 12 Pro Have a Built-In Camping Light?
How Long Can the Blackview Active 12 Pro Camping Light Stay On?
What Can the 180° Stand on the Blackview Active 12 Pro Be Used For?
Can the Blackview Active 12 Pro Be Used as a Portable Workstation?
Does the Blackview Active 12 Pro Support PC Mode and Multi-Window Use?
How Long Does the Blackview Active 12 Pro 30,000mAh Battery Last?
Can the Blackview Active 12 Pro Be Used for Fieldwork and Construction?
What Can the Blackview Active 12 Pro Be Used For Outdoors?
Who Is the Blackview Active 12 Pro Rugged Tablet Best For?
