Oscal S80 6.583-Inch 6+128GB 13000mAh Massive Battery 4G Ruggedized Smartphone
Out of stock
Note:
S80
Endless Power for Rugged Lifestyle
33W
Fast Charge
IP68 & IP69K & MIL-STD-810H
NFC
6.583" FHD+ Display
12MP Sony IMX362 with 8MP Macro
ArcSoft technology
Dual Card Slots
Doke OS 3.0 (Android 12)
Ultrafluent & Ultrafast
Glove Mode
MediaTek Helio G85
2* Cortex-A75 2.0GHz 6* Cortex-A55 1.8GHz
128GB + up to 1TB Expansion
AnTuTu -281229
6GB RAM + up to 4GB Expansion
Battery Life Upgrade
The End of Power Anxiety
13000mAh Enormous Battery
Never run out of power
Enjoy Oscal S80 with the 13000mAh massive battery, which is the largest battery in Oscal smartphone so far. It’s the best response to the giant battery needs of smartphones. The adoption of cutting-edge dual electric cores technology ensures a safer and more stable experience.
*The data is tested by Oscal Laboratory based on continuous use. Battery life depends on the actual usage situation.
Game
15 hrs
Video
15 hrs
Web
23 hrs
Calling
50 hrs
Music
70 hrs
1152 hrs
33W Fast Charge
Charge it up in a flash
The time has come when 33W fast charge can juice up huge batteries within a short period of time. To fully charge a 13000mAh battery,only 3 hours and 20 mins are needed. You take complete control of your battery’s charge by quickly topping it off before it is fully drained.
Reverse Charging Support
Icebreaker to No Electricity Condition
If charging is not available when your electricity device is out of battery, Reverse charging enables to transfer power from Oscal S80 to any other chargeable devices, which eliminate the need to carry an additional power bank.
Reverse Charging Compatible Devices
1=1+1+1
One 13000mAh Battery = 3 x mobiles of regular battery capacity
S80
Other
Other
Other
1 =1+1+1+1+1
one 13000mAh mobile = 4 x outdoor adventure devices
one Portable power station
one Digital camera
one Wireless speaker
one Navigation compass
To discover more prospects with the 13000mAh mobile Be with you in any travel
To record more memories with up to 1TB TF expansion Be with you in any moment
13,000mAh = about 15 hours of shooting;
12MP = focus at 0.03s = burst shoot up to 99 pics
128GB ROM + 1TB TF storage = about 300K photos
128GB ROM + 1TB TF storage = about 50K shorts videos
≈15 hours of continuous photography
≈300K photos
≈10 hours of continuous video shooting
≈50K videos
To Pursue more Happiness with the 13000mAh mobile
To explore more possibility with the 13000mAh mobile Be with you in any adventure
Affordability Upgrade:
MIL-SPEC Upgrading from 810G to 810H Leading IP68 & IP69K Rated Waterproofness
Dare to take any challenge
Oscal has always prioritized rugged smartphones with unrivaled toughness and dependability for industry workers and outdoor adventurers, protecting devices against damage from water, shock, dust, and vibration.
Unfailing Performance with A Stable Framework
Thickened rubber corner for incredible shock resistance
Tightly-fit cap for charging port to resist water from infiltration
Double-shot molding TPU soft rubber for great protection from drops
Tough unibody for reduced risk of falling apart
Oscal S80 is certificated by the latest military-grade rating MIL-STD-810H, which is the gold standard for rugged products that built to withstand the toughest of conditions and survive in extreme conditions throughout its lifecycle.
Rain
Sand and Dust
Vibration
Shock
Acceleration
High Temperature
Low Temperature
Humidity
Altitude
Immersion
IP68 & IP69K occupy the very top of the IP rating scale, which is rated at a high enough level to withstand exposures to solids and water that you would anticipate during every aspect of its use in any damp condition.
Waterproof up to 1.5m deep for 30mins
Inspired by Nature, Designed for Nature
The Oscal S80 still maintains the tough appearance of rugged phones, but the rear cameras adopt a rounded and centered design in the back, which is visually softer than rectangular shape and looks like a penguin from a distance.
6.583" FHD+ Display
It keeps you entertained with a large 6.583" display whether you are reading books, watching Tvs or playing games and make every frame look rather crisp from every angle with the 2408*1080 FHD+ resolution.
2408 * 1080
FHD+ Resolution
20:9
Aspect Ratio
85%
Screen-to-body Ratio
480
nits
400
PPI Density
Get high-definition shots with Advanced Algorithm
Backed by advanced camera algorithms from ArcSoft, a leading algorithm and software solution provider, Oscal S80 works as a connoisseur in cameras.
Face Fill Light
ArcSoft technology
360°
Panorama Capture
8MP Selfie
Portrait
8MP 117° Ultra-wide
0.03s Autofocus Dual Pixel & Closed-loop VCM 12MP Sony® IMX362
8MP Macro
Night Mode 2.0
PortraitColor
Underwater Mode
2k
30fps video
Never Miss Any Wonderful Moments
Up the Light Sensitivity by 200%
Equipped with a 6P lens, large 1/2.55" sensor, native 1.4μm large pixel, and f/2.0 aperture, the 12MP Sony® IMX362 gathers more light, thus even the shakiest of conditions can’t interfere with capturing memories.
Autofocus as Fast as 0.03 Second
Admire every detail there is with our Dual Pixel autofocus technology and closed-loop Voice Coil Motor, and 0.03s autofocus speed is achieved by the 12MP Sony® IMX362 to capture any evanescent moments without sacrificing the photo quality.
Shoot More and Quicker in Seconds
By adopting a 12MP main sensor that supports up to 10fps continuous burst shooting, up to 99 photos can be taken at once in a matter of seconds. Oscal S80 is able to make continuous shooting for a compelling action sequence with consistently sharp images.
8MP 117° Ultra-wide
Broaden Your Field of View
Oscal S80 tenders 8MP ultra-wide-angle lens with a 117 ° field of vision, preventing distortion at the edges of the photograph or any loss of image quality , which is ideal for group shots or capturing landscapes in their full glory.
Explore the hidden tiny worlds
Oscal S80’s macro function supported by an ultra-wide sensor offers a closer look at small subjects which can’t be seen directly by the naked eye, giving us a chance to explore fresh perspectives of a hidden tiny world in high resolution with a shooting distance as close as 2cm.
360° Panorama Capture
Powered by the ArcSoft panorama stitching technology that supports dynamic shooting direction detection, exclusive access to ArcSoft real-time stitching, and more, S80’s Panorama Mode achieves the best possible stitching results.
Upgrade to HDR 2.0 by ArcSoft HDR technology
Oscal S80 adopted the ArcSoft HDR technology to the new-gen HDR mode which boosts performance by 200% and helps us see real images in both shadows and highlights.
Upgrade to Night Mode 2.0 by ArcSoft night mode technology
Backed by the ArcSoft night mode technology, Oscal S80 allows you to capture brighter and stunning images without pressure in low light conditions
Upgrade to AI Beauty Mode by ArcSoft Beauty Technology
Powered by ArcSoft Beauty technology, AI Beauty Mode adjusts the best camera setting to strike your beauty by enhancing your skin and complexion.
Portrait
Thanks to ArcSoft technology, Portrait Mode allows you to take pictures with a sharp focus on the subject in a blurred background.
2K 30fps Video Recording
What you record is what you see by the naked eye, storing your real world.
Underwater Mode
Though it’s underwater, you are free to seize those fleeting moments as you like.
Face Fill Light
It helps fill in shadows and balance the exposure if you are in a low light situation, making you shine like a diamond even at night.
Smoothness Upgrade:
Everything changes by one touch
Graphite Cooling System
Max 1GHz GPU
Frequency
MediaTek Helio G85
LPDDR4X + eMMC 5.1
RAM 6GB + 4GB Expandable
AnTuTu -281229
10GB + 128GB
+1TB TF Expandable
8℃ CPU
Temperature Reduction
MediaTek Helio G85
High-performance octa-core processor
The octa-core chipset boosts the Arm Mali-G52 GPU to 1GHz, providing blistering performance for avid gamers. The built-in MediaTek HyperEngine technology aids in the execution of resource-intensive games.
35%
HYPERENGINE
Lower power consumption
30%
GPU OF UP TO 1GHZ
Faster & smoother response
Up to 10GB RAM + 128GB ROM + up to 1TB TF
Stress-free Multitasking & Open-ended Storage
6GB RAM + 4GB RAM = 10GB RAM
By adding 4GB RAM, the total RAM is up to 10 GB so that you’ll be able to switch effortlessly between applications while multitasking, gaming, browsing, printing and more, which stays away from the terrible experience of a stuck phone.
128GB ROM + 1TB TF
Open-ended Storage
You can achieve storage freedom with 128GB of internal and 1TB of external storage, having no worry about the limited memory for a mass of photos, files, and apps.
Say goodbye to overheating
The S80 utilizes a graphite-based cooling system that can reduce the CPU temperature by up to 8°C in order to sufficiently exhaust heat and prevent overheating.
13685mm² Graphite Area
Personality upgrade:
Upgrade to the Latest Android 12
Define Your UI Interface
Your Privacy Permissions at a Glance
Smoother, More Responsive
Highlights of Android 12 in Doke OS 3.0
Upgrade to
Harnessing the power from the newest Android 12, S80 takes personalization, privacy safety, and efficiency to the next level.
You can easily personalize the look and feel of the phone to match your mood and style with this most expressive, dynamic, and personal Google OS ever.
The newly-added privacy dashboard gives you a clear and comprehensive view of when apps access your location, camera, or mic over the past 24 hours.
The UI feels alive with every tap, swipe, and scroll—responding quickly and expressively with smooth motion and animations.
Highlights of Doke OS 3.0
Upgrade in Design, Smoothness, Convenience
Combining the latest Doke OS 3.0 developed by Oscal, which features a bunch of useful tweaks and add-ups over its predecessors, S80 achieves a breaking-through UI performance.
Versatile Desktop
Ready for Revolution?
Doke OS 3.0 renders all the magic tricks that amuse you and save your time. You can install apps, dismiss folders, rearrange icons, access apps with shortcuts and customize your themes, wallpapers, or icons with a breeze.
The Upgraded Notebook
A Corner of Your Private Space
Sometimes it might be inappropriate to express your feelings in public on social media, and that’s why you need a private Notebook to write down what you think, probably your whimsical thoughts, creative scribble, or to-do lists.
Smart Floating Windows
Next-Level Design
Swipe up, down, right or left or try more gestures to navigate Doke OS 3.0 that facilitates your control with convenient floating windows.
RAM Fast
Ready, Fast, and Intelligent
By learning users’ patterns of app-opening, Doke OS 3.0 with Pre-Loading can foresee which apps you’ll launch and help preload your apps before you actually open them, improving the average app-launching speed by 7%.
Catch up with
You All the Time
Doke OS 3.0 witnesses faster and smoother animation of screenshot and all types of floating windows. Always be in sync with you without latency.
Multicolored Indicator Light
S80 enriches your life with more colors and exciting rhythms thanks to the multifunctional indicator light.
During Charging :
Solid red below 20% of battery level
Solid yellow between 20-80% of battery level
Solid green over 80% of battery level
Incoming Calls:
Flash rapidly with random colors
Unread messages and notifications:
Flashing red
Playing Music
Flash randomly with 65,535 colors according to the rhythm of your music
Incoming calls are the top priority of indicator light.
Screen that Works with Gloves
Glove Mode enables to recognize inputs made while wearing gloves by increasing the touch sensitivity of the screen, perfect for those outdoor workers and adventurers if gloves must be worn.
Note: When Glove Mode is enabled, the screen responds more sensitively to touches with glove on. Turn Glove Mode off when ungloving to avoid accidental screen activation.
Fingerprint Sensor Sensor & Power Button 2-in-1 Key
Easily unlock your phone with fingerprint via the power button.
Customized Shortcut Button
By programming the custom key, you can easily access to 7 different
functions or other favorite apps quickly.
Start Soundrecording
Open Flashlight
Screenshots
Open Underwater Camera
Open PTT
Open SOS
Open Game Mode
Multifunction NFC
Quick answer to Google pay, public transport ticket purchase, and file sharing with other devices.
Combining 4 navigation satellite systems, Oscal S80 help you stay connected and centered whether you’re navigating in a crowded city or a vast desert.
Useful Toolkit
Good helper is easy to find in professional apps out of the box.
Convenient Lanyard Hook
Just hooks up to keep your smartphone safe so you can do anything without any concern.
Dual Card Slots
Choose the way you like - insert two 4G SIM cards to enjoy the dual 4G VoLTE or insert one SIM card and one TF card to expand the room for storage.
Mecha Orange
Navy Green
Conquest Black
ModelS80
ColorsNavy Green, Mecha Orange, Conquest Black
Dimension174*81.4*18.9mm
Weight460g
Display6.583-inch 1080*2408 FHD+ IPS, 85% Screen-to-body Ratio
CPUMediaTek Helio G85
RAM & ROM6GB + 128GB, LPDDR4X + eMMC 5.1
RAM ExpansionExpandable to up to 4GB
SIM SlotDual SIM; Two Nano Card or Nano Card + TF Card
Max TF Card Capacity1TB
Front Camera8MP Samsung® S5K4H7
Rear Camera12MP Sony® IMX362 + 8MP Ultra-wide with Macro + 2MP Depth
Battery Capacity13000mAh
Charging Speed33W
Wi-Fi802.11a/b/g/n/ac
Connectivity2G Bands: 850/900/1800/1900
3G Bands: WCDMA: B1//B8
4G Bands: FDD:B1/B3/B7/B8/B20 TDD:B40
NavigationGPS/Beidou/Glonass/Galileo
OSDoke OS 3.0 based on Android 12
Glove ModeSupport
