Blackview BV6600E 5.7-inch 4+32GB Android 11 8580mAh 16MP+8MP Ruggedized 4G Cellphone
$199.99 $145.99
✔8580mAh Big Battery
✔IP68&IP69K MIL-STD-810G
✔Octa Core 4GB+32GB
✔5.7" FHD 13MP Camera Android 11.0
Capacity: 4GB+32GB
4GB+32GB
Color: Black
Green
Add to Wishlist
paypalvisamastermaestrojcbamerican expressdiners clubdiscover
Description
Note:
bv6600e
Powered by an 8580mAh insane battery
bv6600e
8580mAh battery beast
Everlasting productivity
  • bv6600e
    53% above average capacity
    Network-off standby time up to 792 hrs and 4G/WiFi standby time up to 430 hrs. You will no longer suffer from battery anxiety.
  • bv6600e
    Advanced dual electric cores technology
    Safer and more stable. It delivers the best 8580mAh phone experience possible, without compromise.
bv6600e
IP68 & IP69K & MIL-STD-810G certified
Tougher than any big battery phone
As a serious rugged phone, BV6600E has outstanding resistance to water, drops, shock, and
daily abuse that cannot be matched by a mainstream device in a case.
  • IP68 Waterproof
  • IP69K Waterproof
  • MIL-STD-810G
bv6600e
bv6600e
Leading waterproof technology
BV6600E is specially designed to perform to high standards even in wet environments, with internal parts protected with waterproof membranes, as well as an anti-deforming charging cap.
bv6600e
  • * BV6600E can be submersible in up to 1.5 meters of freshwater for up to 30 minutes
  • * It’s suggested to air dry BV6600E after water immersion
A solid structure for outstanding
drops and shocks resistance
  • Metal frame fixed with screws
    bv6600e
  • Thickened rubber corner for great protection
    bv6600e
  • Tough unibody for reduced risk of falling apart
    bv6600e
  • Well-fixed dual batteries for enhanced stability and safety
    bv6600e
* BV6600E is drop-proof up to 1.2m based on the laboratory test
Serves as power bank
Buy one get two
Supporting reverse charging function, BV6600E can serve as an enormous 8580mAh capacity power bank to lend juice to another device on the go. The Type-C charging port makes it easier to plug.
bv6600e
Enhance photos with filters
Awesome snaps are guaranteed with various filters. Put fabulous photos and get a growing number of followers on Facebook/Instagram. Enjoy being awesome and have fun!
  • bv6600e
    Samsung® S5K5E2
    5MP front camera
    bv6600e
  • bv6600e
    Sony® IMX258
    13MP rear camera
    bv6600e
  • bv6600e
    Sony® IMX258
    13MP rear camera
    bv6600e
Get more light with HDR on
Capture more details in bright and dark areas. Clear images even against the light.
HDR OFF
HDR ON
bv6600e
HDR OFF
HDR ON
bv6600e
Good balance of toughness and
aesthetics on the screen
The 5.7 inches HD+ display uses in-cell technology to present natural vivid colors in every frame. Protected by the DragontrailTM glass, it has great resistance to scratches.
  • 5.7
    inches
  • 1440 x 720
    resolution
  • 18:9
    aspect ratio
bv6600e
  • bv6600e
    Unisoc SC9863A, octa-core
  • bv6600e
    4GB RAM 32GB ROM
  • bv6600e
    128GB expansion
Smooth experience and fast response to your demands
BV6600E is equipped with fast octa-core CPU for a smooth experience. Paired with 4GB of RAM, 32GB of storage with 128GB microSD card expansion, worry-free to save a number of movies.
bv6600e
GPS & GLONASS & Beidou
Always in the right direction
More is better when it comes to satellites. BV6600E’s triple navigation system enables faster and more reliable ambiguity fixing even in street canyons, mountains.
bv6600e
Doke 2.0 OS
As natural as breathing
Doke 2.0 OS is developed based on Android 11 and goes beyond the Android system in terms of aesthetics, interaction and efficiency.
  • bv6600e
  • BV6600ESystem Manager
    Get better and smarter control over trash cleaning, battery performance, gaming boosting, and background running of Apps.
    • bv6600e
      Free up more Space
    • bv6600e
      Smart Power Saving
    • bv6600e
      Game Speedup
    • bv6600e
      App Management
  • BV6600EData Migration Assistant
    Safely migrate photos, contacts, messages and more from your old phone to your new phone with the Data Migration Assistant. All can be done without Wi-Fi or mobile data.
    bv6600e
    • Old Device
    • New BV6600E
  • bv6600e
  • bv6600e
    bv6600e
    Before
    After
  • BV6600EApp Freezer
    One click to put rogue apps in the Freezer and stop their background running for maximum power saving and efficiency.
    bv6600e
    Before
    After
Even the little things
are a big deal
  • Fingerprint sensor & power button 2-in-1 key
    Easy to reach. Unlock in a wink. No need to input passwords or draw a complicated pattern.
  • bv6600e
  • bv6600e
  • Dual 4G VoLTE
    BV6600E supports 4G VoLTE in both slots simultaneously - enjoying faster data transmission, lower power consumption, and more reliable connection.
Fearless phone that crushes use limits
  • bv6600e
    Uninterrupted business regardless of harsh weather
  • bv6600e
    Taking photos underwater
  • bv6600e
    Pick up to use after a hard drop onto the rough ground
  • bv6600e
    Peace of mind whenever going out
Your ultra-reliable outdoor partner
Supreme battery life & toughness
  • Fishing
    bv6600e
  • Constructing
    bv6600e
  • Cycling
    bv6600e
  • Outdoor sports
    bv6600e
  • Skiing
    bv6600e
  • Climbing
    bv6600e
  • Skateboarding
    bv6600e
  • Running
    bv6600e
Pocket friendly
bv6600e
Green
bv6600e
bv6600e
Specification
Design
ProductBV6600E
OSAndroid 11.0
ColorBlack, Orange, Green
Weight325g
Dimensions159*79.4*18
Screen
LCD panelBOE
ICICNL9911C
Panel TypeIPS
Display ResolutionHD+
Screen Size5.7 Inch
Screen Resolution720*1440
Viewing angle (H/V)Full angle
PPI/DPI182
GlassDragontrail Glass
Connectivity
WIFI 2.4GHz, 802.11 b/g/n
Bluetooth V4.2
2G2/3/5/8
3G WCDMA:B1/B8
4G TDD: B40, FDD: B1/B3/B7/B8/B20
Hardware
CPUSC9863A
CPU Clock 1.6GHz
GPUGE8322 550MHz
RAM4GB
RAM TypeDDR4X
ROM32GB
ROM TypeEMMC
TF Card SlotSupport
Max TF Card Capacity128GB
USBTYPE-C
Camera
Front Camera 5.0MP
Front Camera SensorS5K5E2
Front Camera Aperturef2.2
Rear Camera 13.0MP
Rear Camera Sensor IMX258
Rear Camera Aperture f2.2
Rear FlashYes
Video 1080P 30fps H.264/H.265/vp8
Power
Battery Capacity8580mAh
Max Charging Current5v 2A
Multi-media
Videomp4\3Gp\mov\mkv…
Audioflac\ape\ac….
Imagejpeg\png\gif\bmp
Features
NavigationGPS+GLONASS+Beidou
SensorsYES
GyroscopeYES
MagneticYES
Air pressure sensorNO
HallNO
CompassYES
FingerprintYES
RGBYES
NFCNO
HotkontNO
Coulomb CounterNO
Wireless ChargingNO
Sim-Card TypeTwo nano card
FMYES
OTGYES
Earphones Jack TypeTYPE-C
Accessories
User Manualx1
Protective Film Separatelyx1
Power Adaptorx1
USB Cablex1
Earphonesx1
NOTE
