Blackview A70 Pro 6.517 Inches Quad Core 4GB+32GB 5380mAh 13MP + 5MP Camera 4G Android 11 Smartphone
$149.99 $119.99
A70 Pro Budget Big Battery King 5380mAh Battery | 6.517" HD+ Display 5380mAh Battery 6.517" HD+ Display 5MP + 13MP Camera...
Capacity: 4GB+32GB
4GB+32GB
Color: Green
Green
Red
Blue
HURRY! ONLY LEFT IN STOCK.
paypalvisamastermaestrojcbamerican expressdiners clubdiscoverklarnaafterpay
Frequently Bought Together
Total price:$269.97 $199.97
Description
A70 Pro
    • 5380mAh Battery
    • 6.517" HD+ Display
  • 5MP + 13MP Camera
    • Quad-core Unisoc T310
      4GB + 32GB
    • Doke OS 2.0
      Android 11
    • Fingerprint
      Unlock
5380mAh Massive Battery
Long-lasting Power for Never-ending Days
Live your day freely without worrying about where you can plug in your phone for an extra juice refuel. The far-above-the-average 5380mAh battery has the power that outlasts a day.
  • 7 hrs
    Game
  • 8 hrs
    Video
  • 9.5 hrs
    Web
  • 29 hrs
    Call
  • 45 hrs
    Music
  • 696 hrs
Light and Exquisite Design
Slim and Portable
While retaining a big 5380mAh battery, the A70 Pro is 9.6mm thin and 205g light only, without extra thickness and weight added, making no compromise on the portability.
Sleek and Stylish
With the pursuit of beauty and aesthetics, the fusion of streamlined curves and smooth finish of lively colors presents the modern stylish look for the A70 Pro.
6.517" HD+ Display
Stunning Visuals with Vivid Details
Get immersive visuals with perfect smoothness and responsiveness on the large 6.517-inch waterdrop display. The high-definition resolution brings you true-to-life clarity and vivid colors.
  • 720*1600
    HD Resolution
  • 87.6%
    Screen-to-body Ratio
  • 20:9
    Aspect Ratio
5MP + 13MP Camera
Capture Every Special Moment
Capture every sparkling moment in life with the A70 Pro. Combining high-class cameras with advanced algorithms, it turns what you see into stunning shots. With the BSI sensor that helps capture more light for both front and rear cameras, low-light performance is also enhanced.
  • 13MP
    Sony® IMX258
    Rear Camera
  • 5MP
    Front Camera
Ready for Most Demands
As the world’s first 4-core LTE chip with the introduced large core, the Unisoc T310 achieves high computing performance and lower power consumption, excelling in the current mainstream 4-core products. Paired with 4GB RAM, it smoothly runs and switches between more apps.
More Powerful than the Predecessor, A70
A70 A70 Pro
Processor Unisoc SC9863A Unisoc T310
Process 28nm 12nm
CPU 4*A55 1.6GHz + 4*A55 1.2GHz 1*A75 2.0GHz + 3*A55 1.8GHz
GPU PowerVR GE8322@550MHz PowerVR GE8300@800MHz
RAM 3GB 4GB
3 Card Slot Design
More Room, More Possibilities
While inserting two SIM cards, A70 Pro can support an external TF card of up to 128GB to store more. With 32GB of internal storage, keep all the favorites right on your phone.
Rear-mounted Fingerprint Sensor
Unlock in A Twinkling
Reach the rear-mounted fingerprint sensor area with your finger naturally to make phone unlock simple. Also support face and password unlock.
Rear Fingerprint Sensor
Doke OS 2.0
Based on Android 11, As Natural as Breathing
A70 Pro carries the Doke OS 2.0 based on Android 11 to improve aesthetics, interaction, and efficiency.
  • Clone Phone
    Transfer the privacy data safely from the old to the new device.
  • System Manager
    Support all-in-one controls such as trash cleaning and battery management.
  • Dual-window
    Entertainment
    View different contents on the same screen to enable entertaining while working.
  • Game Mode
    Clean up RAM to save memory and block popups for interference-free gaming.
  • Cold Room
    Freeze apps to avoid their stealthy background running and save memory.
  • Screenshot/
    Long Screenshot
    For important messages, make a screenshot or long screenshot and edit it easily.
  • 4G LTE
    4G LTE Connectivity
    Ensure more reliable connection and faster data transmission with the 4G LTE connection. Also offer 2.4G &5G dual-band Wi-Fi.
    4G LTE
    2.4G&5G Wi-Fi
3-in-1
Navigation System
Combine the world’s most utilized satellite navigation systems, including GPS, GLONASS, and Beidou, to locate your destination with accuracy.
GPS
GLONASS
Beidou
  • 165.2*77*9.6mm
    Dimension
    165.2*77*9.6mm
  • 205g
    Weight 205g
  • 6.517-inch 720*1600 HD+, 87.6% Screen 6.517-inch 720*1600 HD+, 87.6%
  • Octa-core SC9863A
    Processor Quad-core T310
  • 3GB + 32GB
    Storage 4GB + 32GB
  • 32GB
    Expandable Storage 128GB
  • 5380mAh; 5V/2A
    Battery 5380mAh; 5V/1A
  • 5MP Front + 13MP Sony® IMX258
    Camera 5MP Front + 13MP Sony® IMX258
  • Android 11
    Operating System Doke OS 2.0 (Android 11)
  • Yes
    Fingerprint Sensor Yes
  • GPS+GLONASS
    Navigation GPS+GLONASS+Beidou
  • 802.11 b/g/n; BT 4.2
    Connectivity 802.11 b/g/n/ac; BT 5.0
    Earphone Jack 3.5mm
Colors to Choose from
Express Your Style
With the impressively beautiful shades to choose from, A70 Pro suits your unique style — from cool and bold to simple and sleek.
  • Fantasy Black
  • Mint Green
  • Guava Red
  • Gradient Blue
Blackview A70 Pro
  • Model
    A70 Pro
  • Colors
    Black/Green/Red/Blue
  • Dimension
    165.2*77*9.6mm
  • Weight
    205g
  • OS
    Doke OS 2.0 (Based on Android 11)
  • Display
    6.517" 720*1600 HD+ IPS
  • CPU
    Quad-core Unisoc T310, 2.0GHz
  • RAM & ROM
    4GB RAM + 32GB ROM
  • Max TF Card Storage
    128GB
  • Battery Capacity
    5380mAh
  • Camera
    5MP Front Camera + 13MP Sony
  • Navigation
    GPS+GLONASS+BEIDOU
  • Wi-Fi
    802.11 b/g/n/ac;
  • Network Connectivity
    GSM spec: 2/3/5/8
    3G spec: WCDMA: B1/B8
    LTE spec: TDD: B40 FDD: B1/B3/B7/B8/B20
Specification
Design
Product A70 Pro
OS Android 11.0
Color Black, Green, Red, Blue
Weight 205g
Dimensions 165.2*77*9.6MM
Screen
Panel type IPS
Display resolution 720*1600
Screen size 6.517 inch
Screen to Body Ratio (%) 87.6%
PPI/DPI 270
Viewing angle (H/V) Full angle
Glass Panda
Connectivity
WIFI IEEE802.11 a/b/g/n/ac, 2.4G/5G dual-band
Bluetooth V5.0
2G B2(1900), B3(1800), B5(850), B8(900)
3G WCDMA: B1/B8
4G FDD: B1/B3/B7/B8/B20
TDD: B40
Hardware
CPU Unisoc T310
CPU Clock 2.0GHz
GPU IMG8300@800 MHZ
RAM 4GB
RAM Type DDR4X
ROM 32GB
ROM Type EMMC
TF Card Slot Support
Max TF Card Capacity 128GB
USB Micro 5pin
Camera
Front Camera 5MP
Front Camera Sensor GC5035
Front Camera Aperture F2.2
Rear Camera 13MP
Rear Camera Sensor IMX258
Rear Camera Aperture F2.2
Rear Flash YES
Power
Battery Capacity 5380mAh
Max Charging Current 5V 1A
Multi-media
Video mp4\3Gp\mov\mkv
Audio flac\ape\ac
Image jpeg\png\gif\bmp
Features
GPS GPS+GLONASS+BEIDOU
Sensors G-sensor /P-sensor /L-sensor
Motor Flat motor 0830
Gesture NO
Gyroscope NO
Magnetic NO
Hall NO
Fingerprint YES
RGB NO
NFC NO
Hotkont NO
Coulomb Counter NO
Wireless Charging NO
Sim-Card Type two nano card ,one TF card
FM YES
OTG YES
Earphones Jack Type 3.5mm Jack
Accessories
Gift Box x1
User Manual x1
Power adaptor x1
micro USB Cable x1
NOTE
