Blackview AirBuds 8 IPX7 Waterproof Sweat-proof Dust-proof Bluetooth 5.3 TWS Earbuds
$39.99 $29.99
AirBuds 8 Noise Down, Galas Up. Ergonomic Design Always Fit with All-day Comfort LED Power Display Active Noise Cancellation 4-mic Environmental...
Color: Black
White
HURRY! ONLY LEFT IN STOCK.
Frequently Bought Together
Total price:$119.98 $79.98
Description
Ergonomic
Design
Always Fit with
All-day Comfort
LED Power Display
Active Noise
Cancellation
4-mic
Environmental
Noise Cancellation
Crisper and
Clearer Calls
Super Punchy
Bass and Fine Details
13mm Dynamic Driver
400mAh Battery Up to 30hrs of
Audio Enjoyment
Ambient Sound Mode Enjoying Music While Remaining
Aware of the Ambient
Smart Touch Control
1-Minute Charging for
3-Hour Playback
Three sizes of
soft tips
Large Small
Medium
IPX7 Waterproof, Sweat-proof,
and Dust-proof
Latest
Bluetooth 5.3
Appreciate Real-life Sound in Your Ears Integrated with the enhanced active noise cancellation (ANC) technology,
AirBuds 8 eliminate the ambient noise and create the most attractive audio landscapes
for your mind to wander around in.
The Entry to Your Realm
For In-Ear Peace
A Good Partner for Commuters Metro, bus, street, etc.
Free from noise with active noise
cancellation
Enjoy Quiet Travel Time Reduced wind voice while running, riding, etc.
Enter into a quiet world at once with active
noise cancellation
Quiet Sleep-easy Solution Listen pure soothing sound with active
noise cancellation.
Sleep better and wake up refreshed.
4-mic Environmental Noise
Cancellation Technology for Calls
Calls like Face-to-Face Conversations
Thanks to the 4-mic Environmental Noise Cancellation Technology, AirBuds 8 capture your voice clearly even in a crowded environment. The result is that calls sound like face-to-face conversations.
Audio Quality Compensation Just Like in a Live Concert
In order to avoid loss of audio quality from noise reduction techniques, AirBuds 8 are equipped with the audio quality compensation algorithm, allowing every note to be restored to its original brilliance.
13mm Dynamic Driver Super Punchy Bass and Fine Details.
Just the Sound As It Is.
Featuring a 13mm dynamic coil driver with a sensitive PU and PEEK composite diaphragm, AirBuds 8 delivers powerful, punchy bass, richer mid-range tones and ensures every detail has minimal distortion.
Ambient Sound Mode
Stay Connected to the Outer
World While Immersing in Your Realm
Seamlessly blend your music experience with the world around you with Ambient Sound Mode. Whether you’re on a bustling city street or enjoying a peaceful hike, AirBuds 8 ensure you’re connected to the real world without taking out earbuds.
Stay alert to the surroundings
Latest Bluetooth 5.3 Music. Game.
Stay Synchronous and
Uninterrupted.
Enjoy fast and stable audio transmission powered by Bluetooth 5.3 technology. Thanks to its stable connection and a transmission distance of up to 10 meters, you can keep playing music smoothly and stay in sync with every step of your teammates and enemies while gaming.
During outdoor exercises
On bus/subway
In crowded environment
400mAh Battery
Up to 30-hour
Audio Enjoyment
AirBuds 8 have remarkable endurance,
providing 30 hours of battery life with the charging case, and offering nearly 3 hour of audio enjoyment from only a 10-minuite charging for the
charging case.
* The data were tested by Blackview Lab based on continuous use with AirBuds 8 at a volume level of 50% and ANC turned off. The actual battery life varies depending on music type, volume, connected devices, etc.
30hrs of listening time with
multiple additional charges
in the case
6.8hrs of listening time on one charge for the earbuds
3hrs of listening time from only 10 minutes of charging for the charging case
Smart Tap Control It Couldn’t Be Easier Play music, skip songs, pick up/end calls, turn on/off ANC, switch to the ambient sound mode, and more.
Music Playback
For the Left Earbud For the Right Earbud
Tap Once Volume - Volume +
Tap twice Play/Pause
Tap Thrice Previous track Next track
Calls
Answer/end a call Tap either earbud twice
Reject a call Long press for 2s
Switch among ambient sound
mode&ANC on/off
Long press the left for 2s
Activate Voice Assistant Long press the right for 2s
Ergonomic Design &
Scratch-proof Coating
Always Keep Fit &
Every Detail Perfect
Innovative structural design exists purely to serve your all-day comfort. AirBuds 8 have undergone hundreds of rounds of
optimization and upgrading to achieve a superb structural design. Additionally, the special coating protects your earbuds and charging case from scratches while
maintaining a stylish appearance.
Three Sizes of
Soft Tips
Find the Best Fit for
the Best Sound
The size of earbuds tips matters when it comes to noise cancellation. AirBuds 8 come with three sizes of soft tips for a custom fit. The result is an exceptional seal for noise cancellation.
Large Medium Small
IPX7 Rated
No Fear of Rain or
Sweat Challenges
AirBuds 8 are professionally designed for IPX7 water resistance. Whether you are in the gym or have an outdoor
activity, they are always reliable enough.
Blackview AirBuds 8
Model
Weight
Color
Driver
Frequency response range
Bluetooth
Audio codec
Battery capacity
Music play time (50% volume)
Charging time
Charging port
IP rating
AirBuds 8
4.1g*2 (earbuds) / 40g (charging case)
Arctic White / Polar Night Black
13mm dynamic driver
20Hz ~ 20KHz
V5.3
SBC, AAC
35mAh (earbuds)/ 400mAh (charging case)
ANC on: 6hrs (single charge)/ 27hrs(with charging case)
ANC off: 6.8hrs (single charge)/ 30hrs(with charging case)
1h (earbuds)/1.5hrs (charging case)
USB Type-C
IPX7 (earbuds)
Ergonomic
Design
Always Fit with
All-day Comfort
Active Noise
Cancellation
13mm
Dynamic
Driver
400mAh
Battery
Up to 30hrs of
Audio Enjoyment
4-mic
Environmental
Noise Cancellation
Crisper and
Clearer Calls
Super Punchy
Bass and
Fine Details
Smart
Touch
Control
1-Minute
Charging for
3-Hour Playback
Three sizes
of soft tips
IPX7 Waterproof,
Sweat-proof,
and Dust-proof
Latest
Bluetooth 5.3
Appreciate Real-life Sound in Your Ears Integrated with the enhanced active noise cancellation (ANC) technology, AirBuds 8 eliminate the ambient noise and create the most attractive audio landscapes for your mind to wander around in.
For In-Ear Peace
A Good Partner for
Commuters
cancellation
riding, etc.
noise cancellation.
Ambient Sound Mode
On bus/subway
Music. Game. Stay Synchronous and
Uninterrupted.
Smart Tap Control It Couldn’t Be Easier Play music, skip songs, pick up/end calls, turn on/off ANC, switch to the ambient sound mode, and more. Music Playback
Calls
mode&ANC on/off
Ergonomic Design &
Always Keep Fit & Every Detail Perfect Innovative structural design exists purely to serve your all-day comfort. AirBuds 8 have undergone hundreds of rounds of
Three Sizes of Soft Tips Find the Best Fit for the Best Sound The size of earbuds tips matters when it comes to noise cancellation. AirBuds 8 come with three sizes of soft tips for a custom fit. The result is an exceptional seal for noise cancellation.
Medium Small
Large
IPX7 Rated No Fear of Rain or Sweat Challenges AirBuds 8 are professionally designed for IPX7 water
resistance. Whether you are in the gym or have an outdoor activity, they are always reliable enough.
Blackview AirBuds 8
Model
Weight
Color
Driver
Bluetooth
Audio codec
Battery capacity
Charging time
Charging port
IP rating
AirBuds 8
13mm dynamic driver
20Hz ~ 20KHz
V5.3
SBC, AAC
USB Type-C
IPX7 (earbuds)
400mAh Battery Up to 30-hour Audio Enjoyment AirBuds 8 have remarkable endurance, providing 30 hours of battery life with the charging case, and offering nearly 3 hour of audio enjoyment from only a 10-minuite charging for the charging case.
in the case
