Blackview R7 Pro IP68 Waterproof Fitness Smart Watch with On-Wrist Phone Calls
$79.99 $49.99
✔IP68 Waterproof
✔Heart Rate Monitoring
✔Up To 7-10 Days of Battery Life
Color: Black
HURRY! ONLY LEFT IN STOCK.
Frequently Bought Together
Total price:$119.98 $79.98
Description
Enjoy Every Extreme Challenge
Ruggedness against Water, Drops and Dust
IP68 Water- & Dust-proof
Play in Water, Unconcerned
R7 Pro is ready all the time to join you at the beach or in the gym. Splash- and water- and sweat-proof as it is ,
R7 Pro can withstand water immersion 1.5 meters below water surface for up to 30 minutes.
Metal Body & Corning Glass
Let Time Elapse Elegantly
1.28'' LCD display is paired seamlessly with zinc alloy frame with vacuum plating and stainless buttons to reveal a refined sense of delicacy. The 2.5 D screen makes every tap delighted and smooth. With skin-friendly rubber back and Corning Glass, R7 Pro ensures the lightest wearable joy and outstanding anti-drop.
Abundant Watch Faces
Try Different Fashions on the Wrist
How much fun would be lost if you can’t change your everyday look on the wrist? R7 Pro would never pass up every chance to make you look on your best with the help of its various and customized watch faces.
Keep Track of Sport
9 Workout Modes
Explore Your Rhythm in Exercise
Curious about how to improve your workout efficiency and discover your potential in exercising? R7 Pro is here to help by keeping track of your real-time miles, calories and heart rate when you are running, walking, cycling, rowing or more.
Care about Your Health
    • Keep Track of Sleep Pattern
      A Sound Night's Sleep
      Eager for a high-quality night sleep without waking up often in the middle of the night? Give R7 Pro a try! It can record the hours of different sleep patterns, which in turn enables you to know your bed time routine better so as to improve sleep quality.
    • Heart Rate Monitoring
      Know Yourself
      Better By Heart
      With improved VC32 heart rate sensor, R7 Pro now can send intelligent reminder to you if your heart rate goes above normal levels, whether you have just met your love at first sight or are having a heart attack.
    • Sedentary Reminder
      More Active Hours, More Robust Body
      Have you been feeling uncomfortable due to sedentary life style day after day? Lack the motivation to stand up? R7 Pro presents timely alert to tell you when to stand up and stretch your body more to alleviate your muscle soreness and stiff back.
Embark on a Joyful Journey
    • Messages and Calls Notification
      Keep You Updated
      Too occupied to notice incoming calls or check your messages from smartphone when you are outdoors? With ringtone and vibrating alerts from R7 Pro on the wrist, you would never miss any important moments by answering calls or reading messages with R7 Pro.
    • Alternative to a Selfie Stick
      Shake Your Wrist,
      Take a Picture
      Always feel embarrassed to ask for help when you want to take a selfie in a place of interest? R7 Pro is your handy selfie stick by connecting itself with your smartphone camera. Simply shake your wrist and you can have any nice selfies without help from others.
Calls Making & Receiving
A light Tap to Start
Your Conversation
Without taking your smartphone out of your pocket or bag, R7 Pro allows you to receive or make your calls with a simple tap. You would find it particularly helpful when your hands are full.
More to Be Explored
    • Weather Forecast
      Sunny or Rainy,
      Today or Tomorrow
      R7 Pro lets you know when to bring your umbrella or raincoat with you outdoors. Providing real-time weather forecast today or tomorrow, R7 Pro allows you to protect yourself from heavy rain or scorching sunlight.
    • Brightness Adjustment
      Nothing in the Way
      Hard to see the screen under bright sunlight? R7 Pro always presents itself clearly no matter what! Enjoy the tuning of screen brightness for your comfortable sight of time with R7 Pro.
    • 23-language Support
      No Matter
      Where You Are from
      Localize R7 Pro easily with 23-language support. No matter where you from, you can read the content in R7 Pro effortlessly.
280mAh Battery
Better Endurance,
More Interaction
R7 Pro lasts longer than it is normally expected. With 280mAh large battery, a single charge would provide R7 Pro with enough juice to run for days.
Typical Use: 7-10 Days
Standby: >30 Days
Blackview R7 Pro
  • Dimension
    Φ46*11.1mm
  • Weight
    38.4g
  • Color
    Black watch + Black strap
  • CPU
    Goodix GR5515
  • Screen Size
    1.28 inches
  • Resolution
    240*240 pixel
  • Battery
    280mAh
    Standby: >30 days
    Typical Use: 7-10days
  • Language
    English, German, French, Italian, Spanish, Chinese, Portuguese, Russian and Japanese.
Specification
Design
ProductR7 Pro
ColorBlack
Weight 38.4g
DimensionsΦ46*11.1mm
Mechanical
Screen Size 1.28" 240*240 pixel
Screen TypeTFT-LCD
Screen Cover2.5D-curved Corning gorilla glass
Bottom MaterialZinc alloy frame, Plastic bottom shell, vacuum plating & stainless buttons
Strap MaterialSilicone strap + metal buckle
Hardware
CPUGoodix GR5515
G-sensorSupport
Blood Oxygen MonitoringNo
Heart Rate MonitoringSupport
MotorSupport
GPSNo
MicSupport
SpeekerSupport
Screen 1.28" TFT-LCD
Screen Resolution240*240
Flash64MB
RAM256KB
Bluetooth3.0&4.0
Power
Standby time with Bluetooth connected >30 Days
Typical daily use 7-10 days
Battery typeLithium polymer battery
Battery capacity 280mAh
Charging methodMagnetic charging
Charging time≤ 2 hours
Function
23 Languages Support English, German, French, Italian, Spanish, Japanese, Russian, Portuguese & More
Remindercall reminder, text message reminder, sedentary reminder, alarm clock reminder
Dial 4 Customized Dials
Pedometerexercise step count, calorie consumption calculation, exercise mileage record;
Sleep monitoringsleep quality monitoring
Heart rateAll-day heart rate monitoring: 24-hour uninterrupted high-precision heart rate detection, focusing on and understanding your health
9 Workout Modes Outdoor Running, Outdoor Walking, Indoor Running, Indoor Walking, Hiking, Mountaineering, Indoor Cycle, Outdoor Cycle, Rowing
0ther functions stopwatch; countdown; music control; raise the hand to brighten the screen; APP download QR code;
Notification reminder (IOS \ Android) Wechat, QQ, Twitter, Facebook, Linkedin, whatsApp, Line, lnstagram, snapchat, skype, Gmail and other timely information;
SMS push, incoming call push;
Time setting synchronization;
Package List
R7 Pro Smartwatchx1
Strap x1
Charging Cablex1
User Manualx1
